Old 05-08-2013, 12:48 PM   #151
Botch
Botch's Avatar
Oddometer: 409
Originally Posted by macadamia View Post
I also bought a Kruz Locker from Adventure Designs...
I wouldn't have known about this if you hadn't posted the pic, thanks! I just ordered one.
I have the ThrottleMeister on my FZ-6, and its beautifully made but kind've fussy, if not dangerous to engage, hope this one works a bit better.
Botch is offline   Reply With Quote
Old 05-08-2013, 01:51 PM   #152
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
So far, mine works much better than the Kaoko throttle lock it replaces... I hope you find it works for you as well...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 05-29-2013, 06:18 PM   #153
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Leo Vince Headers and Leo Vince Carbon Slip-On Exhaust installed... This is much lighter than stock and I had the headers ceramic coated inside and out (similar to Jet-Hot coating)...
New headers assembled...
Old headers and can removed... (removed @ 11,800 miles, note the bluing...)
New headers installed... (photo also shows the BMW HP Carbon Fiber Alternator Belt Cover installed...)
New carbon slip-on ready for installation...
New carbon slip-on installed... (note the circular bracket I used to mount the slip-on hanger to the frame; this is my temporary fix until they send me the correct bracket...)
Photo of the lower heat shield... I wanted to show this because it is made to fit around the exhaust valve, instead of just coming up to it. Very well thought out...
macadamia screwed with this post 05-29-2013 at 06:46 PM
Old 05-29-2013, 06:40 PM   #154
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,567
oh those beautiful jugs!
BTW, where did you get the Exhaust system please kind sir!
Cheers!
Dave
Racegun is offline   Reply With Quote
Old 05-29-2013, 06:44 PM   #155
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
why, thank you...
Everything I've done is listed in post #2 of this thread, including the links...
They are Leo Vince items that I bought from ADVMotorrad.com
Old 05-30-2013, 11:16 PM   #156
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Today, I completed some of the miscellaneous installations I have left to complete before I depart on my adventure.
The BMW frame guards...
Left side frame guard and the SideKicker side stand, stowed...
Right side highway peg... also, this photo shows the right side fuel tank guard, previously installed...
Left side highway peg, stowed... and the left side fuel tank guard, previously installed...
SideKicker side stand, deployed and extended to its longest length... (it is not sitting on the ground, although it looks like it is)
Front, left side of bike, showing the Aux Light guard (previously installed), the carbon fiber alternator belt cover (previously installed), and the skid plate reinstalled after headers installation...
Old 05-30-2013, 11:39 PM   #157
Big bike
Big bike's Avatar
Oddometer: 12
Saddlemen seat
Sorry if I missed it somewhere in here, but whatcha think of the seat?
I've been looking at the driver solo but hate to drop the cash if it's not 'all that'
Big bike is offline   Reply With Quote
Old 05-30-2013, 11:59 PM   #158
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
The seat works nicely, but for my weight it is a bit soft. The top layer of foam is gel based and spongy soft. Other people I've met who use the seat say they love it. They weigh much less than I do. I'm over 300 lbs. I can say it is much better than the Sargent seat it replaced.
I recommend, if you can, try one first... Some places that stock them allow test rides - try before you buy...
Old 05-31-2013, 11:55 AM   #159
Hubbman
Hubbman's Avatar
Oddometer: 723
Spindrift!
More photos from my trip...
HA! Good for you finding Spindrift on your journey! Most people have no clue where that is!
Hubbman is offline   Reply With Quote
Old 05-31-2013, 12:12 PM   #160
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
I found it by accident, riding by and needing a break... Just behind me, opposite of the beach, was an outhouse...
Old 06-02-2013, 09:25 PM   #161
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Completed the installation of the Large, with clear lens, AdMore Lighting LED LightBar from TwistedThrottle.com.
An overhead view of the final wiring, before wire-tying in place...
For more detailed installation information, see this thread...
Old 06-02-2013, 10:16 PM   #162
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Sound clip of my Leo Vince Complete Exhaust System... Please ignore the shaking of the license plate bracket - I removed the luggage grid and rear support to install the LED light bar... Near the end of the sound clip, I demo the LED light bar...
Old 06-04-2013, 08:13 PM   #163
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Reassembled the rear of the bike after installation of the AdMore Lighting LED LightBar. Installed the LaminarLip, the Tornado Final Drive Hub Cover, the yoke protector, the replacement mirror glass, and the shorty levers.
I also found a problem with the side stand switch. I installed it incorrectly after installing the SideKicker side stand. I did not have it aligned correctly, so the bike thought the side stand was always down and would kill the engine when I put it into gear. I removed the clips and washer from the back of the side stand bolt, realigned the side stand switch to its correct position, and reinstalled the washer and one of the clips. The little clip (the one that goes in the groove) went somewhere in my garage and I never found it. I used a piece of lock wire twisted around the groove to keep the switch, the larger clip, and the washer in place.
I'll post some photos of these items later tonight or tomorrow...
Old 06-06-2013, 01:39 AM   #164
macadamia OP
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
I must say I'm very happy so far with my new exhaust. Today, i went out for an afternoon ride, mostly freeway. The pipe has a nice growl when opening the throttle for passing, but is only slightly louder than stock at cruising speeds.
There is no discernible power gain in the butt dyno department...
I am also noting here the highway pegs I installed are way too high to be comfortable for more than a minute or two of use... I'll try and remount them lower on the supplemental crash bars I have. If that does not work, they will be going up for sale on the flea market...
Old 06-06-2013, 10:00 AM   #165
spook120
Oddometer: 304
Dibs on the highway pegs! Spook LoL!
spook120 is offline   Reply With Quote
Times are GMT -7.   It's 12:05 AM.
