Old 01-19-2013, 09:20 AM   #1
backdrifter OP
Wannabe rider
backdrifter's Avatar
Oddometer: 1,366
Removing oil from stainless headers before first start up
Fellow inmates,
I installed a set of new stainless steel headers from BMW Hucky. I used rubber gloves and touched them by hand as little as possible, but through other work in and around them, I have touched them a few times with bare hands. I can see a few marks where I touched them. What is the best way to clean these off in an effort to avoid nasty blued handprints when I start the bike for the first time?
Thanks in advance!
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter is offline   Reply With Quote
Old 01-19-2013, 09:47 AM   #2
Ron Seida
Adventman
Ron Seida's Avatar
Oddometer: 1,256
Brake cleaner and a clean cotton rag works well.
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?"
Van Gogh...
"Your the only guy i've met driving a BMW who isn't an asshole."
D. Irwin...
Ron Seida is offline   Reply With Quote
Old 01-19-2013, 09:52 AM   #3
Mike V.
Mike V.'s Avatar
Oddometer: 65
When I installed new SS Keihans on my R65 restoration project I wiped the exhaust system down with a clean towel soaked in Isopropyl Rubbing Alcohol prior to the first startup. I had no problems with staining. Expect the headers to slightly discolor to a golden or copper hue from heat. I've found the system pretty easy to maintain. Heel marks from a passenger were removed with polishing.
Mike V. / San Diego
1978 R100/7 (original owner)
1981 R65 (fully restored)
ABC-MOA-AMA-VBMWMO
http://tinyurl.com/4df7hgs
Mike V. is offline   Reply With Quote
Old 01-19-2013, 09:59 AM   #4
backdrifter OP
Wannabe rider
Oddometer: 1,366
Perfect - two great suggestions.
Thanks, gents!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 01-19-2013, 10:00 AM   #5
chasbmw
Oddometer: 2,120
Easy enough to remove the browning of stainless steel with acid based alloy wheel cleaner, followed by solvol autosol. It's just an annual thing for me.
Waxing the system when you wax the bike seems to help
Charles
1971 Commando Fastback
chasbmw is online now   Reply With Quote
Old 01-19-2013, 10:18 AM   #6
Kai Ju
Kai Ju's Avatar
Oddometer: 1,818
...and here is a tip for more severe cases of contamination such as plastic bags, melted riding pants etc.
Realize that the item melted on to a hot pipe, so get the pipe nice and hot again, take a clean rag/towel etc and soak it in cold water and wring out the excess. Now, while wearing heavy leather gloves, wipe down the affected area with the wet towel. Make sure the towel you use is linen or cotton, not a synthetic.......
The melted plastic will instantly stick to the wet towel and most of it will come off the pipe. Repeat till clean, follow with 0000 steel wool or polish.
I discovered this method when a plastic bag melted across all four of the headpipes on my '82 650 Seca. That bike also taught me that 0000 steel wool works great to get tree sap of the chromed mufflers without scratching the chrome.
Kai Ju is offline   Reply With Quote
Old 01-19-2013, 10:39 AM   #7
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,463
Just make sure that the brake cleaner doesn't touch anything hot enough to vaporize it! Read the warning labels on the can. Brake cleaner when heated releases phosgene (sp?) gas which can kill you or severely damage your respiratory system, liver, etc.
Big Bamboo is offline   Reply With Quote
Old 01-19-2013, 12:27 PM   #8
photorider
photorider's Avatar
Oddometer: 283
Windex works too.
photorider is offline   Reply With Quote
Old 01-19-2013, 03:35 PM   #9
backdrifter OP
Wannabe rider
Oddometer: 1,366
Thanks for all the suggestions!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 01-20-2013, 03:06 AM   #10
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,418
Shellite. Non residue metal cleaner.
It's also excellent for wiping oil from rubber.
boxerboy81 is online now   Reply With Quote
Old 01-20-2013, 11:21 AM   #11
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 973
GOOP...wipe on, wipe off. cleans anything off the stainless steel
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 01-20-2013, 12:13 PM   #12
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,462
x2
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 03:07 AM.
