Old 12-30-2012, 11:12 PM   #1
spencergt66 OP
Oddometer: 794
Abs delete kit?
Does any one make an abs delet kit with all the hoses and parts needed? If not does any one have a parts list this abs is driving me nuts........ I think it's trying to kill me 2007 990 adv with S suspension
spencergt66 is offline   Reply With Quote
Old 12-30-2012, 11:19 PM   #2
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,949
While we are discussing this is possible keep the ABS for the front and bypass it for the rear?
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 12-30-2012, 11:28 PM   #3
spencergt66 OP
Oddometer: 794
Bet you can just put a line right to the caliper and by pass the abs pump might throw a code though I want to take mine out completely and throw it in the garbage
Old 12-31-2012, 12:34 AM   #4
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,841
Look up my DIY: ABS removal thread. I had a part list and instructions there.
You can also run a line from the rear caliper straight to the brake to bypass the rear ABS and then block off the open ABS holes in the pump with bolts. Nothing electrical with this so it shouldn't throw a code.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 12-31-2012, 05:40 AM   #5
DirtJack
DirtJack's Avatar
Oddometer: 1,531
Put a switch in the rear sensor line. When open, the default is no ABS. When closed, normal operation. Cheaper and easier than plumbing new lines. Google finds a few threads giving HOWTO.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 12-31-2012, 09:38 AM   #6
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,800
I did this, easiest way if you want factory is get a set of lines for an 05 S model 950 front and rear.
Done.
I just went to local shop and for 1/4 the cost had three lines made up two front one rear.
I then unplugged the pump, removed the sensors and was done.
Then I got rid of the EFI but that is another story.
It is quite easy to do, and if you take your time you can also remove the harness left behind.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 12-31-2012, 09:59 AM   #7
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,949
But that is not what I want for myself - I want the ABS to function on the front but not the rear.
Old 12-31-2012, 11:11 AM   #8
DSM8
DSM8's Avatar
Oddometer: 3,800
Someone plumbed the rear line straight to the master, then plugged the two ports on the pump.
So long as there is fluid in the pump when you plug it that should work for you.
An idea.
Old 12-31-2012, 11:23 AM   #9
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,949
An idea.
Old 12-31-2012, 02:34 PM   #10
spencergt66 OP
Oddometer: 794
Sweet thanks
Old 12-31-2012, 06:07 PM   #11
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,437
I have an 07 standard Adventure.
I bought the 08 "S" model brake lines and 08 "S" model speedo sensor.
Pretty easy job really.
I removed all hoses and wire harnesses and entire unit in a few hours.
New brake lines are way shorter, and should likely feel better....
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 01-02-2013, 08:39 AM   #12
Katoom119
Katoom119's Avatar
Oddometer: 1,841
They will. You can actually tell what's going on since there is so much more feel in the lever.
Old 01-02-2013, 11:00 AM   #13
corndog67
Oddometer: 1,281
I don't understand why you would get an expensive option when you don't want ABS? Or is the ABS standard? Personally, I don't want it myself. I'm one of those old fucks that thinks (probably wrongly) that I can brake better than the computer. Just wondering.
corndog67 is offline   Reply With Quote
Old 01-02-2013, 11:40 AM   #14
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,949
The ABS bikes were cheaper than the non-abs bikes.
Old 01-02-2013, 11:42 AM   #15
DSM8
DSM8's Avatar
Oddometer: 3,800
^^ THIS
Plus the number of non abs bikes depending on the year you bought it was also much different.
When I got mine the non abs was practically impossible to find in my area within 300 miles.
Times are GMT -7.   It's 03:51 PM.
