Old 01-03-2013, 01:59 PM   #76
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 389
Screw driver
Screw driver and hammer will still be the easiest in this situation. The base of the filter is where it is strongest.
Kiwi Tinkerer is offline   Reply With Quote
Old 01-03-2013, 03:59 PM   #77
WindSailor
WindSailor's Avatar
Oddometer: 686
Originally Posted by qman8 View Post
Would you recommend a hot-air gun to apply heat?? Certainly dont think you'd want to use a torch!!!
Try the hot-air gun (or an existing hair dryer) - good and warm should be fine - not *smoking hot*. If you burn that seal I think your problems will be worse.
See if that helps you...
WindSailor is offline   Reply With Quote
Old 01-03-2013, 04:04 PM   #78
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,574
omg....does anyone read starting from the top?
the same suggestions continue to be re-cycled over, and over, and over...
btw, where's the pic of what the oil filter looks like, today?
2014 Ducati MTS1200S
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well.
oalvarez is offline   Reply With Quote
Old 01-03-2013, 04:39 PM   #79
WindSailor
WindSailor's Avatar
Oddometer: 686
True... I still think heating it up to around 150* to 175* or so will definitely help.
Old 01-03-2013, 05:07 PM   #80
LaurelPerryOnLand
Oddometer: 3,480
How many people does it take to change an oil filter?
Well, as of right now:
2,652 have read about the problem
78 have responded with 'suggestions'
BTW...I understand that the oil filter/remants thereof remain solidly in place due to freezing temps in the OP's home state.
Perhaps we should give the OP a week or two of slack to accomplish this task...WITHOUT additional 'help' .
Otherwise the above stats will most likely grow.
LaurelPerryOnLand is offline   Reply With Quote
Old 01-03-2013, 05:34 PM   #81
Frostback
Frostback
Oddometer: 234
Oh this is fun. I was actually able to get my wife's strap-style . . .wait for it . . .jar opener between the filter and flange of my R12 GS. Tightish filter came off fine.
Alternatively, JB Weld a couple of 1 inch nuts on the bottom and tell some man-hater that your bike has two big nuts down there. They will twist it right off for you.
This problem is apparently one of those irrational worry things to generate this much interest or maybe it is the right level of complexity that even us ham-fisted wrenchers have an opinion and a shred of experience (hence, WE ARE EXPERTS!)
Good luck with your project.
Lee
Frostback is offline   Reply With Quote
Old 01-04-2013, 09:43 AM   #82
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,826
At this point I think it's time to suggest unscrewing the bike from the filter.
Old 01-04-2013, 09:48 AM   #83
Osmin C
Oddometer: 106
Someone beat you to it. They told him to put the filter in a bench vice and turn the bike....voila!
Osmin C is offline   Reply With Quote
Old 01-04-2013, 09:53 AM   #84
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,826
Dammit!! That is a mad scientist.
Ok, I'd better settle down before GB starts pruning.
Old 01-04-2013, 10:02 AM   #85
LaurelPerryOnLand
Oddometer: 3,480
For those arriving late to the thread...
Post #59, Page 4
LaurelPerryOnLand screwed with this post 01-04-2013 at 12:48 PM
Old 01-04-2013, 10:25 AM   #86
seniorasi
Oddometer: 816
post whore
This thread is useless without pics. I ain't beleevin it neether!!!! I'm thankin' the op just put this up ta C how many posts he cud git. A'in't that so?????
seniorasi is offline   Reply With Quote
Old 01-04-2013, 11:58 AM   #87
a1atcs
Oddometer: 83
Emory Cloth
I found this trick somewhere on this forum when I had this issue with my 09 GSA. Get a cup type filter wrench from auto store, one that fits the closest, lay a strip of emory cloth across filter, push on the cup type filter wrench and turn. This has served me well on 2 occasions now!
09GSA
05 Road King Classic
IBA #49425
a1atcs is offline   Reply With Quote
Old 01-04-2013, 12:52 PM   #88
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 3,041
before i actually found one that fit used and cheap. i had the $2 one from the autoparts store that was just a little to small. Put 4 vertical cuts down the sides and taped it on. worked like a champ for years!
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 01-04-2013, 01:19 PM   #89
rattis
rattis's Avatar
Oddometer: 1,166
Talking
I can't be bothered to change my oil, I change bike instead.
And a new bike is cheaper than a new SO
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 01-06-2013, 12:32 AM   #90
V@lentino
Inspektor
V@lentino's Avatar
Oddometer: 820
Try this
Go to post 16 of this thread,
Works like a charm
http://advrider.com/forums/showthrea...=752826&page=2
FEAR ===> False Expectation About Reality. GSA08
Work is just the time you have to spend between rides.
The motorcycle chronicles of Jackie & Valentino
The Southern Episode
V@lentino is offline   Reply With Quote
Times are GMT -7.   It's 09:59 PM.
