Old 03-11-2013, 03:51 PM   #16
chillycoot
chillycoot's Avatar
Oddometer: 1
You can re-use this o-ring (white or orange) as long as it is in good shape.
*You can re-use this o-ring (white or orange) as long as it is in good shape.
NOT SO!!! Pardon the shout, but both Snowbum http://bmwmotorcycletech.info/Oil.htm
(almost half way down the page) and Oak have said the used white O-ring may deform during use,
and both say to renew the white O-ring.
That is one of the reaons it's called the $2000 or now the $3-4000 O-ring.
Personally, I've always replaced the O-ring during filter changes.
The cost is really minimal when compared to the risks. But I'll leave it up to you to decide.
Also, I have some information from WIX Filters regarding bulk purchasing for oil cooler models:
Shelf life on a paper filter is 5 to 7 years. After that the paper gets brittle and
I wouldn't recommend using it. 24947 was not superceded to a new number.>
And now I'm stuck with at least 8 old oil filters.Oh well, live and learn.
Some ride to be seen, I'm seen to ride!
chillycoot is offline   Reply With Quote
Old 03-11-2013, 04:52 PM   #17
supershaft
because I can
Oddometer: 9,116
Re-using the white O-ring works great if you mind what you are doing although I usually replace it.
Aftermarket oil filters? I am out of the loop as to what works and what doesn't. I have seen too many lunched engines for aftermarket oil filters to experiment on my engines OR my customers.
Old 03-11-2013, 05:34 PM   #18
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 521
I agree no after market filters!
Where's the best (cheapest) place to get OEM oil filters?
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Old 03-12-2013, 07:54 AM   #19
dm635 OP
Let's Roll
Oddometer: 382
Well, finally got around to the first filter change yesterday. Old single piece filter seemed collapsed inside. Had the white O-ring and it was there for a while. Had deformed to fit the space it was in. The o-ring was still proud of the flange so I feel it was still sealing. Sides had squared off & a ridge where fitted to the canister. No rips or tears noted.
And it appears a shim was not used where it should have been. As far as I could tell the canister does not have a rolled lip. The white O-ring looked to have still had a good seal, but due to the way it had taken shape I went with the reddish/orange seal & will order some white ones or a couple filters on next parts order. First filter change went OK, no leaks. But I haven't looked yet today.
Will cut open the old filter today and check for any contamination, EI, metal chunks. The Wix filter did say made in Poland. Same as the canister Wix, Napa Gold filters I get for my old Bimmer.
1978 R80/7
dm635 is offline   Reply With Quote
Old 03-12-2013, 09:30 AM   #20
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,406
If you really want to save $$$$ you could always go this route:
Single ply for normal use....Double ply for heavy duty service....
"Perfumed" is available for those "anal" riders.
I saw a "remote" toilet paper filter set up on a Guzzi once...
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 03-12-2013, 10:34 AM   #21
dm635 OP
Let's Roll
Oddometer: 382
After all the reading up now regarding which filter to use. I'll not cheap out on this crucial maintenance item. I'll make sure to order at least a couple filters when ordering next batch of parts. And swap filter again just as a precaution since the filter I removed appeared had been there a long time. Probably way too long.
1978 R80/7
Old 03-13-2013, 04:59 AM   #22
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,601
Man, I am so glad I have an early engine and don't have to worry about this stuff!
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 03-13-2013, 06:15 AM   #23
dm635 OP
Let's Roll
Oddometer: 382
Pulled the pleats apart the check for metal. There may have been just a few that I could see. Will get it out in the sunlight to check again. The few (less than 10) I saw were very, very small flecks. Filter looks old, must have been there for a while. I'll leave the Wix in till I get more correct filters. I haven't had a problem using Wix in my old bimmers that I've been driving since '96. Napa Gold is exact one from Wix & have used Mann all these years. Throw in a couple dealer filters. But I do realize these are completely different engines and I do want this boxer to last me a very long time.
1978 R80/7
Old 03-13-2013, 02:55 PM   #24
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,601
If Mann filters were available for boxers I'd be happy to use them. I've cut apart a lot of them (Porsches) and they are good stuff.
Old 03-13-2013, 08:32 PM   #25
craydds
craydds's Avatar
Oddometer: 1,165
Mann
Originally Posted by chollo9 View Post
If Mann filters were available for boxers...
Mann filters here - http://www.euromotoelectrics.com/pro...of-570mh57.htm .
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 03-14-2013, 02:18 PM   #26
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,063
So, I take it Mann filters are good? The pricing on a 5-pack looks good, even compared to the NAPA prices.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 03-14-2013, 02:52 PM   #27
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,601
I'm switching to them, thanks to craydds! I'm not knocking Wix or any other aftermarket filters, it's just that I've only ever run BMW filters in my bike, but I have experience with Mann filters elsewhere and trust them well enough to use them. I really hate spending almost $20 for an oil filter.
Old 03-14-2013, 03:12 PM   #28
jackd
Oddometer: 3,046
I use Mahle OX36 filters - my local airhead specialist sells these in Vancouver. The quality has been great - I've never found a crushed one.
I've been reading for years about the deformation of the big white o-ring. I had never actually seen one take a set in the last seven years that I've been working on this machine - until today. Finally I now can claim to see the difference between a new one and an old one. I would never consider re-using a deformed one a second time around. And yes, I measure my cansister every time - it's still at 3.65 mm.
Old 03-14-2013, 03:17 PM   #29
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,601
I believe the Mahle OX36 is the original BMW factory filter and is NLA in the US, Not 100% sure though.
Old 03-14-2013, 04:12 PM   #30
jackd
Oddometer: 3,046
The box says OEM. You can get them up here in Canada.
Times are GMT -7.   It's 09:33 PM.
