Old 01-04-2013, 06:36 AM   #1
woodly1069 OP
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,083
Maintenance manual for R75
After looking in the wisdom area and paging through Google a bit I can't seem to find a service manual for a 1973 LWB R75. Are they available on line or will I have to buy one. If so, where, BMW still have them? It appears that I have a rear main leaking and I guess I will use this cold weather to take the old girl apart for repair...hopefully it hasn't wetted the clutch plate!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 01-04-2013, 06:43 AM   #2
oldroadie
/5 dirt road wannabe
Oddometer: 340
http://www.clymer.com/Book.aspx?bid=...S+PD+1970-1996
I have this one and it's fairly comprehensive. Augmented with this forum it's awesome.
oldroadie is offline   Reply With Quote
Old 01-04-2013, 06:44 AM   #3
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,083
thanks old roadie, the only thing I found so far was more expensive on Fleabay
Old 01-04-2013, 07:00 AM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 4,980
The Clymer manual is a good choice. They are not cheap but if you look you may do better than $47.95.
There is also the Haynes manual that I have heard some prefer.
http://www.haynes.com/products/productID/129
It might come down to shipping charges, which one is cheaper? The Haynes is $45.45
There are shop manuals published by BMW. I couldn't find one for /5 vintage but think it does exist. Still if you found this it would cost a Hundred dollars or more.
Both these sources you have been given are the actual publishers web pages. For some reason you may find these same manuals cheaper from other sources.
I have both of these and can't really say which one I prefer. I think I use them all. There are also many web pages and blogs on the web. There are 3 or 4 forums that will help walk you through the process.
We will give a lot of help here at Adventure Riders but really want you to get the manual so we don't have to repeat too much stuff. Rear main seal will mean taking the clutch off to get at it and you will be checking the clutch for wear before putting it back. Most of the time this job requires the replacement of the clutch. There are alternatives that save a little bit of moola but it ain't cheap.
How many miles on new machine?
---Albert Einstein
Old 01-04-2013, 07:03 AM   #5
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,083
thanks for the info. Disston, I think the old girl is still new at just under 20K but...she sat a bunch! Hopefully I will make up for that!
Old 01-04-2013, 09:06 AM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 4,980
Well taking the mileage into effect it does look like you shouldn't need a clutch. Not hard to measure and it has to come off to do the seal, so check it anyway.
I suppose there is oil on the shelf under the trans and this is why the rear seal is suspected? Also check the neutral indicator switch and the front trans seal. Both sources of oil leakage at this spot.
---Albert Einstein
Old 01-04-2013, 10:05 AM   #7
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,083
correct as usual my friend! And yes I will check the other items when I get in there!
Times are GMT -7.   It's 11:52 AM.
