Old 01-02-2013, 11:25 AM   #1
Sabre170 OP
Sabre170's Avatar
Oddometer: 283
Hand grip removal
Anyone have any good techniques/methods to remove hand grips with out destroying them? I'm converting to clip ons.
Sabre170 is offline   Reply With Quote
Old 01-02-2013, 11:28 AM   #2
pkboxer
Oddometer: 95
Blow em
If you have access to a compressor, plug anyholes in the end of one grip and fill the handlebar with compressed air from the other end.
Make a quasi-air tight seal around your air nossle.
Sometimes the grips will shoot off without even touching them.
Or have someone else wiggle it off.
Other than that, squirt something liquid (WD40) under the grip and wiggle it off.
pkboxer is offline   Reply With Quote
Old 01-02-2013, 11:50 AM   #3
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,532
Windex is the bomb! I wedge a small flat head under the grip to have a channel to spray the windex into, then i slowly work the screwdriver around. Then grab the end and shes off!
Old 01-02-2013, 11:53 AM   #4
dualsportride
Oddometer: 258
Muscle and lubrication. The air compressor trick works, but if you run bark busters you have to cut the end off the grip and that makes it a little harder. If you get wd-40 with the red little straw that helps get under the grip, and I have found that the warmer the grip the easier it is to peel off.
dualsportride is offline   Reply With Quote
Old 01-02-2013, 12:07 PM   #5
Sabre170 OP
Sabre170's Avatar
Oddometer: 283
Just my luck....it is 39F in my garage. I don't see warming them up too much of an option. Haha!
I was kinda thinking WD-40 myself. Thanks for confirming that!!!
Old 01-02-2013, 12:13 PM   #6
Kai Ju
Kai Ju's Avatar
Oddometer: 1,892
Personally I would not use any type of lubrication, +1 on blowing them off with air. There is no guarantee that you'll get all the lube off and there is nothing worse than a loose grip while you're riding.
If you have an open end it still works and you don't have to plug any of the holes.
You may have to ask a helper to hold the other side on while you're installing the grip because it may blow off on it's own.
Kai Ju is offline   Reply With Quote
Old 01-02-2013, 01:38 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,733
No, No, No. The worst thing is a big bug flies into your mouth when you are going 85 mph and you have to swallow it.
---Albert Einstein
Old 01-02-2013, 02:23 PM   #8
norwstrider
Oddometer: 6
Ok here is my "I'm to cheep to by new grips" trick. Slide your thinnest long blade, flat screw driver as far under the grip as you can, then slide the plastic tube on your contact cleaner spray can in beside the screw driver, squirt, pull the plastic tube and screw driver out and then twist the grip off the handle bar. If that doesn't work someone must have glued them on with super glue. And its time for the utility knife.
norwstrider is offline   Reply With Quote
Old 01-02-2013, 02:53 PM   #9
motog
Oddometer: 87
I've used my wife's hairdryer to heat them up to make them easier to remove. Also soaked a towel in boiling water and wrapped it around them and pulled them off (after putting on some leather gloves).
motog is offline   Reply With Quote
Old 01-02-2013, 07:01 PM   #10
DaveBall
DaveBall's Avatar
Oddometer: 1,163
Hair dryer to warm them up and make them more plyable. Then take your air hose with a nozzle on it and stick it under the edge of the grip. Have that compressor cranked up and work the air nozzle around the grip as best you can. Even if somebody used some glue, the heat and then forced air usually breaks them free.
DaveBall is offline   Reply With Quote
Old 01-02-2013, 07:41 PM   #11
squish
Out of the office.
Oddometer: 6,308
Rallypro grips cost ten bucks. My time to remove a grip is worth morer then that.
But heres what I do. Using a little plastic syringe I squirt a little dish soap under the grip. Then using compressed air I blow the grip off.
On vacation for a spell
squish is offline   Reply With Quote
Old 01-02-2013, 07:46 PM   #12
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,791
+1 I use air, but if not available, some windex will do the trick, and does not leave the grip lubed, semi permanently, like wd-40
Old 01-02-2013, 08:24 PM   #13
Kai Ju
Kai Ju's Avatar
Oddometer: 1,892
I was ready with a witty reply but my mouth was full.....
Old 01-02-2013, 09:05 PM   #14
old paul
old paul's Avatar
Oddometer: 226
I always slide a hacksaw blade under the inner edge and work it around several times. Soon it breaks loose. To install I simply pour in some rubbing alcohol and slide it on. In a few minutes it is on tight, never slips and comes off pretty easy next time.
old paul is offline   Reply With Quote
Old 01-02-2013, 09:28 PM   #15
konaunit1
konaunit1's Avatar
Oddometer: 86
I have found that a little electrical cleaner with the little plastic straw works great work it under the grip spray and twist. takes a bit but the grip comes right off. The elctrical cleaner evaporates quickly leaving no gunk. I do the same putting my grips on also. Never had one slip.
konaunit1 is offline   Reply With Quote
Times are GMT -7.   It's 07:31 PM.
