Old 01-02-2013, 10:59 PM   #1
ParaMud OP
ParaMud's Avatar
Oddometer: 626
Heated Controller DIY?
I know this is a beat to death subject, but hey, what isnt on the internet? For christmas, my girlfriend and I got heated gloves from my dad. He did not get us a controller. So I am now stuck buying a controller.
If I just needed one controller, I would just suck it up and buy one. But I need 2. Its 70 bucks for a single temp controller, so it would be 140 for both.
We live in So Cal so any coldness is usually just the gloves. We are also doing an alaska trip in the summer. No chance in getting a jacket liner any time within the next 3 years.
We are on separate bikes.
Any cheap methods?
Basically any saved money goes directly into the Alaska gas fund for this summer.
Thanks for any help beating this dead horse.
edit
See the 20 buck one DIY. hmmm
Edit
08 wr250r
04 xt225
ParaMud screwed with this post 01-02-2013 at 11:11 PM
ParaMud is offline   Reply With Quote
Old 01-03-2013, 08:05 AM   #2
duck
duck's Avatar
Oddometer: 10,403
Forget the details but I made one a couple of years ago for some heated insoles using a PWM (pulse width modulator - a.k.a. "LED dimmer") that I scored on Fleabay inside of a little metal "project box." Works great.
duck is offline   Reply With Quote
Old 01-03-2013, 08:47 AM   #3
duck
duck's Avatar
Oddometer: 10,403
Not sure what the connectors are but you could probably find something at Radio Shack that would mate with them:
http://www.ebay.com/itm/12V-5A-0-100...item4605cff166
Not sure how waterproof it would be but for the price....
Old 01-03-2013, 09:22 AM   #4
mwood7800
Oddometer: 612
http://www.amazon.com/gp/aw/d/B007TH4EN6. I have used this. I have 2 mounted on my rt. one for the seat and 1 for gear. You can dip it in glovit to insulate it or coat it with a hot glue gun. The 2 on the rt are 7yr and still working. I might have used a 15 amp but 10 should work for you.
mwood7800 screwed with this post 01-03-2013 at 09:27 AM
mwood7800 is offline   Reply With Quote
Old 01-03-2013, 09:24 AM   #5
Simplyred
Simplyred's Avatar
Oddometer: 593
That's only 5 amps..... I wonder if that will be enough....
And it is not a dead horse by a long shot. I am waiting myself as well on some dyi scheme that one can easily assemble (without lots of electronics experience I mean).
I can tell you however that you will need some type of PWM modulator, and you would need to know how much amps your glove will take on full power.
This one comes up regularly and will handle 15amps. More then enough for your gloves. My guess is, that your gloves will take about 10amps.
Simplyred is online now   Reply With Quote
Old 01-03-2013, 09:37 AM   #6
mwood7800
Oddometer: 612
http://store.qkits.com/moreinfo.cfm/MX033. That's the one I used it works jacket and pants, gloves. Make sure you get the one already assembled
Old 01-03-2013, 09:43 AM   #7
duck
duck's Avatar
Oddometer: 10,403
FirstGear heated gloves are 15W each, 30 total. A 5 amp circuit can easily handle that.
Old 01-03-2013, 10:52 AM   #8
Simplyred
Simplyred's Avatar
Oddometer: 593
Duck, Watts is something else as Amps. WebBikeWorld says the following about these gloves:
Firstgear also provides a motorcycle battery harness with the Carbon gloves. The harness has round terminals for the battery and a 15-Amp blade-type inline fuse.
So, if 5 amps would be enough, then why would the manufacturer deliver a 15 amps fuse??
Simplyred screwed with this post 01-03-2013 at 10:58 AM
Old 01-03-2013, 11:10 AM   #9
ParaMud OP
ParaMud's Avatar
Oddometer: 626
From the gerbing website it says
Source 12V DC
Current 2.2A
Watts 27
I am hoping that is for both gloves combined. It should be. That small led dimmer looks perfect.
08 wr250r
04 xt225
Old 01-03-2013, 11:18 AM   #10
MeRide
Me like bikes!
MeRide's Avatar
Oddometer: 1,157
Watts = Volts x Amps
As to the fuse supplied by the manufacturer.......... the heated gloves can be plugged into a heated jacket so a bigger fuse is required in that case. They don't know what you are/aren't using for gear.
Fall ride on a 1935 motorsickle
MeRide is offline   Reply With Quote
Old 01-03-2013, 11:43 AM   #11
ParaMud OP
ParaMud's Avatar
Oddometer: 626
I ordered 2 of those, 6 bucks. It should come in about 3 weeks and I will update you guys.
08 wr250r
04 xt225
Old 01-03-2013, 11:51 AM   #12
MeRide
Me like bikes!
MeRide's Avatar
Oddometer: 1,157
Not sure how you are going to route the wiring from the battery to the gloves but dependent on that the waterproofness of the controller might not be a factor. Set the controller and stuff it under your jacket.
Old 01-03-2013, 11:54 AM   #13
ParaMud OP
ParaMud's Avatar
Oddometer: 626
The gloves come with a battery harness, I will just put the dimmer in line. It should be easy to waterproof the plastic seams.
08 wr250r
04 xt225
Old 01-03-2013, 12:08 PM   #14
duck
duck's Avatar
Oddometer: 10,403
That's similar to what I used for my heated insoles above. I didn't bother including a fuse because the outlet has a dedicated 15A fuse in the bike's factory fuse block.
Old 01-03-2013, 12:09 PM   #15
duck
duck's Avatar
Oddometer: 10,403
Source 12V DC
Current 2.2A
Watts 27
Since the FirstGear ones are 15 each, I'd guess that 27 is for the pair.
Times are GMT -7.   It's 01:00 AM.
