01-03-2013, 05:07 AM
#1 |
G/S nut
Oddometer: 187
shim plate and parallel rules G/S trans
Before I go the internet road was wondering if any of youz might have a shim plate and parallel rules for reassemble a G/S transmission. Might be a long shot but you never know. Starting to get geared up to go in, I really miss riding this time of year in AZ.
Bwayzee |
01-03-2013, 08:32 AM
#2 |
Oddometer: 1,025
I'm in the same boat but just purchased a cracked rear cover that I'll have machined into a shim plate.
Parallel bars would be nice as well, but I've seen folks measure the bearing seat from the gasket surface. If the cover is straight that should work, if..... Another option might be to have a glass place cut you a strip of plate glass to substitute as parallel bar. Just a thought. |
01-03-2013, 08:56 AM
#3 |
More tacos than you
Oddometer: 5,114
There's always this option too:
http://www.bmwboxersupplies.com/gear...g2bmue2s4hvpu3 Shipping from holland isn't nearly as bad as you'd think.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
01-03-2013, 10:17 AM
#4 |
Oddometer: 609
The outer edges of the cover plate is the best place to measure the pockets in my opinion.
If the cover is warped, as mine was recently, measuring at the pockets will give a false reading. Tip: To get an idea of the end play required, set a micrometre @ .05mm/.002" and hold it up to the light. It ain't much. That is why consideration must be given to things that will vary your measurement results. To dismiss such analyty (is that a woid?) when setting such a close tolerance is fumbling in the dark, imo.
Lord of the Bings |
01-03-2013, 01:17 PM
#5 | |
because I can
Oddometer: 6,074
The outside races rock. Even if your cover plate is flat the bearing boss floors almost never are. Personally, I think it helps to measure from the inside race to an depth average in the cover plate but there is always going to be an element of guesswork no matter how careful you are. Even experienced tuners disagree on whether to shoot for loose or tight. Personally, I think they shift better and hold up better on the tight side. Loose lets bearing walk IMO. I set them up snug enough that they might feel too tight after you install the input seal. Remember that they almost always loosen up quite a bit after a heat cycle or two. I forgot to add that if you set one up too tight be sure and rap it real hard a couple of more times before you take the cover back off. That can make all the difference! supershaft screwed with this post 01-04-2013 at 01:51 PM |
01-03-2013, 01:52 PM
#6 | |
lost in the '70s
Oddometer: 462
I continue to rely on two lengths of precision ground 3/4" keysteel.
'76 R90S silver smoke '75 R90/6 hybrid "Don't worry, it's not loaded." last words of Chicago's Terry Kath before shooting himself in 1978 |
01-03-2013, 03:40 PM
#7 |
BMWAirheadsDownunder
Oddometer: 155
CNC your own
Jorgs MC webpage has a well designed precision drawing if you're up to the challenge and cost of having one CNC machined. http://jhau.maliwi.de/mot/gear/dist-plate.png
____________________ "The only reason people get lost in thought is because it's unfamiliar territory" (Joe Garcia) "BMW Airheads Downunder", (The Australia and New Zealand Airhead Community). "B.A.D" ![]() http://www.facebook.com/groups/anzairheads/ patanga screwed with this post 03-19-2013 at 01:16 AM |
01-04-2013, 01:06 PM
#8 |
Old Enough To Know Better
Oddometer: 5,517
I don't have the link handy - its on my other computer that just died, but search for my thread "A Tale of Two Transmissions" to see the simple oversized bridge I made for my depth gauge to take the place of a shim plate. It spans the case/cover flanges sufficiently to measure each bearing at several points.
It must have worked well, cause the box shifts like buttah since the overhaul.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
01-04-2013, 03:38 PM
#9 |
Oddometer: 3,734
Don't forget Dan at Cycleworks.net sells shimming plates along with other tools.- $88 http://www.cycleworks.net/index.php?...products_id=39
01-05-2013, 05:41 AM
#10 |
G/S nut
Oddometer: 187
Thank you guys!
Thank you for the input gentlemen, and I use the term loosely. RF has done some amazing work on these tranys and I will probably go to Cycleworks to the necessary tools. When this thing shifts like "buttah" I hope to offer the same to other inmates. Actually it already shifted like "buttah".
Also wanted to gear up for another overhaul on another G/S I have had my eye on for about 15 years. I think it is an 1985 and a PD as well, what a huge fuel tank.
Bwayzee |
01-05-2013, 06:17 AM
#11 |
Chronic Noob
Oddometer: 2,293
alternate method.
Reassemble without the shims substituing a strip of solder over the bearings.
The solder get squashed. Disassemble and measure the thickness of the squashed solder. Insert a shim stack of the same thickness less whatever clearance.
If the Earth is flat why are my tyres round? |
01-05-2013, 12:59 PM
#12 | |
Oddometer: 609
Resulting in a tight fit. Just my thoughts after dissecting the solder method. 'Course, I might be completely wrong.
Lord of the Bings |
01-05-2013, 05:09 PM
#13 |
Oddometer: 1,025
experimental method
The only way to determine that would be to do both methods, similar to the cover edge vs. bearing bore conundrum.
01-05-2013, 05:25 PM
#14 | |
Oddometer: 609
I found it not at all difficult to distort the cover by .002" by hand pressure. The fact that solder will offer 'some' resistance to crushing will distort the cover. and of course the cover cannot be 'whacked' to help crush the solder because it could well go too far. It all comes back to the ridiculously fine end play tolerance of .002" specified, that can be exceeded in a bowed cover, or from one side of a bearing to the other. It's all good fun tho'
Lord of the Bings |
01-05-2013, 06:23 PM
#15 | |
Oddometer: 359
I agree with your findings. I always set them up at around .004". These things are not the precision devices some think they are. The cases as well as the cover get distorted through heat cycles and running stress over the years. The best you can do is put them together without binding with reasonable clearance. I have put hundreds of them together over the years loose rather than tight with success. Sometimes you just have to play it by ear. |
