01-03-2013, 06:26 AM
#1 |
Oddometer: 760
Turn signals Front & Rear
I am turning to my inmates here for suggestions on what is available. I am looking for the smallest turn signals that anyone here has on their f8....compatible with the factory wiring and just bolts into the existing hole where the oem bulky units sit.
01-03-2013, 06:40 AM
#2 |
Cosmopolitan Adv
I'd suggest the TT ones... They seem pretty small to me
http://www.sierrabmwonline.com/produ...48-0295-p-1298
Keep the smile on your face! An Otter on the road: From Lille to Limoges in 12 Days An Otter on the road: I'm coming up so you better get this party started! |
01-03-2013, 07:41 AM
#3 | |
Oddometer: 760
Thanks for the link...I like that they're supplying the resistors with the kit. |
01-03-2013, 11:58 AM
#4 |
tarmac xplor
Oddometer: 4
The BMW led signals are only about $50 more and they just about the easiest plug and play item you can get. Based on looking at the picture of the TT ones, the BMW led signals are just as short (horizontal) and narrower in height (vertical).
If you do go the BMW led route, make sure you order and receive the right ones, the front and back are different. The rear has longer brackets to line up with the tail light while the front has shorter brackets to sit flush with the mounting point. Plus, you can get some M&Ms for free depending on where you buy them... (click on lighting) http://www.maxbmwmotorcycles.com/fic...8&rnd=08102012
Chris |
01-08-2013, 09:14 PM
#5 |
Oddometer: 113
I saw the both the BMW and the TT ones at the Calgary show. The TT lights were much more flexible if that is a consideration. They are on my list now just for that as I seem to keep popping one or another out of the plastics...
P
EEUC |
01-09-2013, 07:16 AM
#6 |
Oddometer: 760
Thanks for this info. Do you know if the TT ones are plug n play?
01-09-2013, 09:54 AM
#7 |
Oddometer: 113
I don't know. I'm sure that the highly educated German engineers that designed the parts thought about adding a feature such as that...
EEUC |
01-09-2013, 11:27 AM
#8 |
Moore Gas!!!
Oddometer: 51
Sorry for my bad english
01-10-2013, 06:30 AM
#9 |
Oddometer: 4,903
I've got a new in the box set of Touratech LED signals, sold my bike before I got to install them.
If anybody is interested, send me a PM.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
01-10-2013, 11:01 AM
#10 |
Oddometer: 760
Thanks for the info guys. Since the F8 is not a cummute bike for me, I think I will just dremel an opening where the rear blinker brackets bolt and basically jam the oem blinkers in.
01-10-2013, 06:02 PM
#11 |
Oddometer: 91
Rubber mounts
[QUOTE=Loutre;20384853]I'd suggest the TT ones... They seem pretty small to me
http://www.sierrabmwonline.com/produ...48-0295-p-1298[ I have set of TT on my 1200 and after a summer of riding .The rubber mounts are starting to crack and the lights hang loose. I end up using tape to keep in the robber tube mount . They do come with resistors you must use put they are not plug and play. I will be replacing this spring with the factory LED
Waterdog |
