Go Back   ADVrider > Riding > Regional Forums > Australia > OZ Vendors & Flea Market
Old 10-26-2013, 04:03 PM   #61
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,381
Originally Posted by Sean-0 View Post
I can say Ryan is a great guy and i want these suckers to work as well ....brilliant idea
seems will's is the 1 with the most kms ..so here's hoping it hangs in there
agree would love it work out
here is my 7000km report
after a 150ish km of dirt yesterday
i think it might be buggered
teeth are still good
bulged rubbers now torn
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 10-26-2013, 05:59 PM   #62
Shawnee Bill
Shawnee Bill's Avatar
Oddometer: 2,164
How many tires did that outlast?
That's not a lot of distance for a street bike but maybe enough for what it's being used for? Should be easy to just replace the rear sprocket, looks like the chain and front sprocket may outlive two rear Kush Sprockets? Maybe more?
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Shawnee Bill is offline   Reply With Quote
Old 10-26-2013, 08:26 PM   #63
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,514
same issue i had seems its back to the drawing board ......had about the same amount of k's on my other 1 and same thing happened
Sean-0 is offline   Reply With Quote
Old 10-27-2013, 12:58 AM   #64
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,381
Chain sprockets & tyre went on at the same time.Got more km out of tyre with the kush.
I ride around 50 street 50 dirt,was hoping for km out of it.
Old 10-27-2013, 03:03 PM   #65
DRjoe
DRjoe's Avatar
Oddometer: 5,318
7k is a lot for a dirt bike to get out of a rear sprocket so I think it pretty acceptable amount of k's.
Be nice to see a fatter sprocket so that the rubbers have more surface area in contact with the metal.
Old 10-27-2013, 06:04 PM   #66
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,286
Even with the amount of road use though?
What may make it worse is that the rubber Cush area is stuffed but the teeth look like there is a fair bit of wear left in them. Riders will feel they are throwing away something not worn out.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 10-27-2013, 06:28 PM   #67
Kenno
Kenno's Avatar
Oddometer: 800
True, i got 7500k from front and 14000k from rear on cross Australia mainly dirt ride with JT sprockets, chain is still on and ok. Was going to test kush but it arrived in stock too late for departure.
D606 rear 5300k on same ride.
Ken is mobile.
Ken
"Parts left out cost nothing and cause no service problems" (Kettering)
Kenno is offline   Reply With Quote
Old 10-27-2013, 06:30 PM   #68
Kenno
Kenno's Avatar
Oddometer: 800
Now that is logical, would work well.
Ken is mobile.
Ken
Old 10-27-2013, 08:36 PM   #69
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 2,085
I would think 7,000k is roughly either side of 12 months for the average 50/50 dirt bike, and 12 months from a 100 buck sprockets sounds ok to me. I would normally budget 7,000 - 10,000k from a chain and sprocket set from the relatively easy life I give a bike so it seems like a good option to me, unless im missing soemthing and im sure youll jump in and let me know if i am
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 10-28-2013, 12:45 AM   #70
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,381
I mustn't be average i did 7000 in 4 months. I was just comparing km to the sprocket i removed which had 7000km on it and was just showing slight wear but not needing replacement prior to fitting the kush. Maybe i need to ride my bike less .
Their must be a solution to getting these to wear in the rubbers but not fail.The teeth are hardly worn maybe due to the cushion effect of the design.
I like the idea and would like to see it work well.
Old 10-29-2013, 03:42 AM   #71
0405canvet
Oddometer: 454
Idea
Hey Ryan! Just saw your sprockets for the first time. Great idea! Seems that 5-7000kms is your max now? What if you double drill the sprockets, countersink from each side and then flip the sprocket at 5000 kms?? Paul, have you ordered one yet??
0405canvet is offline   Reply With Quote
Old 10-29-2013, 04:41 AM   #72
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,514
flipping sprockets aint to good for chain wear and at 250 a chain stuff that
7,000kms is bugger all my last jt sprocket got 20,000 the supersprox i have on atm has 9,000kms on it and looks new
i want them to work but seems just cant get over the bump of the rubbers squishing on the weight side ..same as my original ..the 1 i have now only has small k's on it so it still holds up but looks like it will fail
Old 10-29-2013, 05:16 AM   #73
0405canvet
Oddometer: 454
Consumables
Sprockets are consumable items, why throw them out if half the rubbers are still good and the teeth are new on one side. Wear the chain quicker?? Of course but I will throw away parts when they are completely warn out.
Old 10-29-2013, 05:19 AM   #74
BygDaddee
BygDaddee's Avatar
Oddometer: 2,085
No Gordon, Ive got a talon cush drive wheel
Old 10-30-2013, 03:50 PM   #75
watagans300exc
watagans300exc's Avatar
Oddometer: 115
Like most on here I suspect, I am a "Time Poor" rider and while I fully support any idea that adds a bit of mechanical sympathy to the drive line, these sprockets seem not entirely ideal. I just could not enjoy the ride thinking my sprocket my self destruct mid ride in the middle of but fuck nowhere.
I went with a RADMfg cush drive hub (Direct copy of a KTM unit only billet aluminium and prettier) and will stick with SuperSprox sprockets where I get over 14,000k per unit.
Keep going with the idea Ryan, it is a fantastic solution to an age old and expensive problem with adventure riders on non cush drive wheels.
watagans300exc is offline   Reply With Quote
Times are GMT -7.   It's 01:33 PM.
