Old 01-03-2013, 03:34 PM   #1
LanceR75 OP
LanceR75's Avatar
Oddometer: 44
Alternative Handlebar Switches
Looking to replace the original, beat-up, and not quite working left and right control switches with a modern pair. I obviously want the same functionality (start, blinkers, horn, lo-hi beam) but keep it simple. Anyone done this? Any suggestions on what to look for that would work?
Cheers!
1971 BMW R75/5
LanceR75 is offline   Reply With Quote
Old 01-03-2013, 03:46 PM   #2
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 513
Laugh Assuming a 71 BMW r75/5
Assuming a 71 BMW r75/5 by your signature.
Please confirm.
You have the /5 switch gear also used on the /6 model.
Ok - do not know of any modern switch gear you can use. Maybe some UJM switch gear will work but would not be easy.
Biebs is offline   Reply With Quote
Old 01-03-2013, 03:55 PM   #3
oldroadie
Two wheel addict
Oddometer: 468
Surely you could pick something here that would work and order It off Amazon:
http://www.kandstech.com/index.php?p...itchescontrols
oldroadie is offline   Reply With Quote
Old 01-03-2013, 03:59 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,524
I think the real problem would be the diameter of the bars, wiring can be faked. Our bars are metric and all the switches are made for something else? Is it 22 mm vs. 7/8" ?
---Albert Einstein
Old 01-03-2013, 04:17 PM   #5
LanceR75 OP
LanceR75's Avatar
Oddometer: 44
Please confirm.
Yep, 71 /5
1971 BMW R75/5
Old 01-03-2013, 04:40 PM   #6
oldroadie
Two wheel addict
Oddometer: 468
No argument about the size diff. I was just responding to the alternative request in the thread title assuming a 1/64th inch shim wouldn't pose a dilemma.
Old 01-03-2013, 05:11 PM   #7
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,626
Originally Posted by LanceR75 View Post
Yep, 71 /5
I'd stick with stock, for many reasons, but mostly so the next owner doesn't wonder WTF was the PO thinking...
I was was riding in the hills last week and a damn goat came and knocked me off my bike. There behooves all up in my face and shit...
Big Bamboo is online now   Reply With Quote
Old 01-03-2013, 10:11 PM   #8
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,576
The biggest problem with going that route is where are you going to fit it? Mounted inboard of the existing housing would be a pretty long reach.
I did, at one point, run one of those type switches (actually an OEM Yamaha), and a Magura dogleg clutch lever. Certainly not plug & play though. You should be able to get all of the functions except starter button in the LH switch. I would use a momentary kill switch as a starter button on the right so you wouldn't have to modify anything else.
When I had a /5 I loved the switches, but I see they are almost $100 now!
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Times are GMT -7.   It's 01:01 PM.
