Old 01-04-2013, 06:12 AM   #1
Northwest Cajun OP
Northwest Cajun's Avatar
Oddometer: 170
Lowering the KLR for my 5'1"wife
I'll be lowering my 08 KLR 685 to fit my 5'1" wife. It already has the corbin extra low seat and I have 2" Kuba lowering links on the way. I plan on pushing the forks up 3/4"-1" also.
If she's still not comfortable on it, we will resole her DS boots w/1" spacers and a good lug sole. Then I guess it's a custom shock rebuild? We are trying to avoid getting a new BMW factory lowered G-650gs but will if need to.
Has anyone done this much suspension modification to their KLR and if so, what is the seat hight with the corbin seat and 2" links installed? Our goal is 30"
This is her on her 1.5" lowered Super Sherpa. She likes the bike but doing 2500 miles on a 9 day DS trip around Utah this summer just won't cut it.
Laisses Les Bon Temps Rouler
Northwest Cajun screwed with this post 01-04-2013 at 06:18 AM
Northwest Cajun is offline   Reply With Quote
Old 01-04-2013, 08:56 AM   #2
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,315
I had a freind do that plus installed a Recluse clutch. All of a sudden the seat height wasn't such an issue anymore. The Recluse turns the tranny into an automatic of sorts. No more clutch work in parking lots, driveways or intersections on a grade.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 01-05-2013, 02:23 AM   #3
greer
Oddometer: 3,859
Before you jump into this, would you consider a DR650 instead? The DR weighs a good bit less at 360 lb wet, and it'll feel and handle much more like her little Sherpa. I've dropped my DR per the factory method along with sliding the forks and adding 1.5" lowering links. I can measure seat height if you like.
Sarah
'08 DR650, '13 TU250X
greer is offline   Reply With Quote
Old 01-05-2013, 06:15 AM   #4
Northwest Cajun OP
Oddometer: 170
Beings that the KLR is paid for, suspension work (links or shorter shock& fork)would be done before going out and buying another bike. Whatever that might be. But please measure yours to see how low it is. It's more info on options and we could look at that instead of a BMW. A lower DRZ 400 (with suspension work) would be on the table too, I guess.
Old 01-05-2013, 07:11 AM   #5
greer
Oddometer: 3,859
33"
Sarah
Old 01-05-2013, 11:35 AM   #6
cjw
Oddometer: 6
i would not use the lowering links and would do all lowering by internally modding the suspension units themselves.
you will probably need stiffer springs after lowering to prevent bottoming the reduced travel units.
cjw is offline   Reply With Quote
Old 01-05-2013, 11:40 AM   #7
Kommando
Kommando's Avatar
Oddometer: 7,390
Originally Posted by greer View Post
33"
Sarah
I'd have figured at an inch or 2 lower. The stock height in the lowered position is listed as 33". The sliding of the forks and the lowering links should have taken it down to 32" or lower. The seat can still be lowered 1-2" too.
Kommando is offline   Reply With Quote
Old 01-05-2013, 11:40 AM   #8
marc11
Oddometer: 147
Progressive offers a shock 1 inch lower than stock. That with some modest lowering links and your seat should get you very close. Its the forks I would be concerned about. Not sure how much you can drop them.
Sent from my Nexus 7 using Tapatalk HD
2007 BMW R1200RT
2002 Honda XR400r
marc11 is offline   Reply With Quote
Old 01-05-2013, 11:42 AM   #9
Kommando
Kommando's Avatar
Oddometer: 7,390
The DR-Z400S is taller than the DR650SE. Many 250s are even taller than the DR.
Old 01-05-2013, 01:49 PM   #10
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,945
Don't forget tire choice, side wall heights vary widely.
Has anyone gone so far as swapping out rim sizes?
Hurricane Bob is offline   Reply With Quote
Times are GMT -7.   It's 08:23 AM.
