Old 01-04-2013, 10:32 AM   #1
Steveman OP
Steveman's Avatar
Oddometer: 471
F8GS tire balancing question
I never balance the knobbies I use on my KTM EXC (w. rimlocks) or on my Honda XR650R (w/o rim locks) but I thought it may be a good idea to balance the fron tire of the F8 (TKC 80) so 20 grams did the job. I did not balance the rear TKC (150/70/17) and for me everything was fine till a mechanic from the nearby garage stopped by. He said I will run into trouble. I said I did not balance the Michelin Anakee and it was fine, same with K60. He meant that this was pure luck and happened by sheer chance and the TKC will cause wobbles and so on...
I admit I am a bit worried now. What do u think?
Thanks Steve
Steveman is offline   Reply With Quote
Old 01-04-2013, 10:40 AM   #2
runnin4melife
Oddometer: 806
I balance my front and rear, if you have a balance throw it on there and see what how far out of balance you are. It may not be a huge problem, but it also maybe a nuisance.
runnin4melife is offline   Reply With Quote
Old 01-04-2013, 10:52 AM   #3
Bayner
Oddometer: 1,609
Out of balance won't cause a wobble, but you may feel some vibration at certain speeds that you wouldn't notice if the tire was balanced. Non balanced tires are harder on suspension parts as the suspension is forced to absorb extra motion. They will also sometimes wear unevenly or quicker than the same tire (balanced).
Bayner is offline   Reply With Quote
Old 01-04-2013, 01:24 PM   #4
RobbieO
Muskokatard
RobbieO's Avatar
Oddometer: 9,005
Only a biker knows why a dog sticks his head out of a car window.
RobbieO is offline   Reply With Quote
Old 01-04-2013, 01:51 PM   #5
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,768
Originally Posted by RobbieO View Post
isn't that a kit to brew some beer?
Loutre is offline   Reply With Quote
Old 01-04-2013, 03:24 PM   #6
Oz_Gordo
Oz_Gordo's Avatar
Oddometer: 46
Tyre Seal or Slime
You can also run tyre seal, slime or similar goop as a preventative. They will act the same as Dynamic Beads.
Oz_Gordo is offline   Reply With Quote
Old 01-04-2013, 03:37 PM   #7
Steveman OP
Steveman's Avatar
Oddometer: 471
0K guys. I will go and take that fookin wheel out again.
Thank you.
Steve
Old 01-04-2013, 05:15 PM   #8
TowPro
Lets ride
Oddometer: 3,236
I mount mine then put the tire on the balancer before I put any air in them. I leave the tube nut a couple turns loose. If the balance is real bad I spin the tire on the rim until I find the best balance spot. Once I find spot, I turn the tire just a little more, then back to the sweet spot so the valve stem sticks out straight.
When I air them up I leave the core out. Fill the tube with air until bead seats, then let all the air out so the inner-tube can relax and find its comfertable position, then put the core in, fill it again and set the pressure.
All my dirt bike days cause me to leave the valve stem nut several turns loose so I can see if the tire is moving on the rim (valve stem will no longer be straight). if you tighten the nut and the tire spins on the rim, you will rip the valve stem out of the tube (and you end up walking).
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 01-04-2013, 06:39 PM   #9
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,737
I balance the rim with a loosely inflated HD tube on it. Then I put the tire on, and do what TowPro does to get it as close to balance as possible, but I don't add anymore weight. I mark where the valve is, so I can get it back in place when I get a flat.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 01-04-2013, 07:38 PM   #10
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
Uh, I thought Pirate bikes were tubeless?
Do knobby tires have the red dot at the light spot like most tires? My TKC's did but others too? That goes a long way in getting a low lead balance. Course the RDC sensors on the other bikes tend to need lots.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 01-05-2013, 05:57 AM   #11
Steveman OP
Steveman's Avatar
Oddometer: 471
Done. Balanced the rear wheel with 20 grams. Not sure if I'd feel a difference. However, knowing that everything is OK is fine for me
Times are GMT -7.   It's 06:40 AM.
