Old 01-04-2013, 03:23 PM   #1
Honda55 OP
Oddometer: 196
Motor Change out
I'm about to change the motor on my 07 Fz6. (Second gear was starting to slip.) I picked up a motor with only 1500 miles on it locally. It still has all the injectors and fuel rails etc so it should just be a plug and play swap? Any tips or pointers? anything to watch out for?
Andrew
Honda55 is offline   Reply With Quote
Old 01-04-2013, 05:00 PM   #2
manic mechanic
manic mechanic's Avatar
Oddometer: 161
So, why was the "new" engine in the boneyard? Check out second gear on that also. Most likely your problem is a bent shift fork. We've replaced on a couple bikes, usually caused by power-shifting into second. We also have seen rounded engagement dogs from similar antics. Means replacing gears and maybe other parts.
'76 R90/6, '07 K1200GT
Rounder #6
MOA Ambassador
RA WI Regional Rep
manic mechanic is offline   Reply With Quote
Old 01-04-2013, 09:40 PM   #3
Honda55 OP
Oddometer: 196
Swap
The other motor was there because it was a totalled bike, but the motor is fine. Just going the swap route, not going to tear these apart.
Times are GMT -7.   It's 02:29 PM.
