Old 01-06-2013, 01:56 PM   #16
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,494
the plywood is a good idea.
I would run several 2" wood screws through it around the perimeter and into the floor to keep it from sliding around also. ( make sure you dont go into any wiring or fuel/brake lines. haha
and do NOT put the bike on its centerstand for transport!
tie it down as the PDF shows above.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 01-06-2013, 04:08 PM   #17
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 637
Hijack clue..."Spinal Tap"
Originally Posted by troyslegacy View Post
I am moving a few states away in a couple of days and I am looking for a good way to ship my GS in a 26" Penske.
Am I the only one who picked up on that?
---'99 BMW R1100GS
---'96 BMW R1100GS Mod Project ???
---'80 Honda CB750 Street Tracker Project
---'09 Vespa GT200 Granturismo
wrysingfeenix is offline   Reply With Quote
Old 01-06-2013, 05:12 PM   #18
backroadbill
backroadbill's Avatar
Oddometer: 247
moving van
I put mine on it's side stand, then put twice the cam style straps to the side rails in a penske truck that seemed needed. 700mi, i checked on it a few time. I had some soft house stuff around it.......no problem.
backroadbill is offline   Reply With Quote
Old 01-06-2013, 05:19 PM   #19
rdwalker
Oddometer: 2,542
OK, I give up. I've seen Spinal Tap several times (I even have a dial that "goes to 11" taped above my desk) - but I missed the clue. Care to enlighten the clueless?
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 01-06-2013, 06:34 PM   #20
Nuclear biker
Nuclear biker's Avatar
Oddometer: 18
2x8
I did what your talking about with my old Harley. We used 2x8. One down the center with a wheel stop then three more to brace. One in front and behind the wheel well to keep it in place them put I bolts in the coners for tie down point. I was in a uhaul.
I hope this helps.
Nuclear biker is offline   Reply With Quote
Old 01-06-2013, 07:05 PM   #21
troyslegacy OP
PigGS Feet
troyslegacy's Avatar
Oddometer: 134
You caught me, I'm actually running a mobile meth lab and using the bike for deliveries. Haha. I went with a 3/4 inch piece of plywood, two eye bolts in the front, two in the back, and built a wheel chock out of some old 2x4's and mounted that to the plywood. I have a 4x8 heavy rubber mat that I use under my weight bench, it weighs about 90lbs and will be under the plywood. I think it'll be a solid option. I'll post pics when I get it loaded up. Thanks for all the recommendations, and I would never tie it down on the center stand! I have always tied down on the lower fork brace.
troyslegacy is offline   Reply With Quote
Old 01-06-2013, 07:15 PM   #22
SpeedwayRN
Go Spies!
SpeedwayRN's Avatar
Oddometer: 80
You can use one of these:
http://www.harborfreight.com/motorcy...ock-97841.html
bolt a 2x4 to widen it to prevent tip overs. Tie it down from the bars to the two eyelets on the chock
SpeedwayRN is offline   Reply With Quote
Old 01-06-2013, 07:27 PM   #23
wrysingfeenix
Oddometer: 637
This reminds me that I need to watch it again...for the 100th time
The Stonehenge set that wound up being about a foot tall and almost brained the dancing dwarf when it was lowered on stage!
Christopher Guest (I don't recall his name in the movie) used quote marks indicating an inch instead of an apostrophe indicating a foot when he made a sketch on a napkin.
I immediately pictured a 26 inch model of a Penske truck with the OP's bike sitting right behind it with everyone scratching their head.
---'99 BMW R1100GS
Old 01-06-2013, 07:41 PM   #24
rdwalker
Oddometer: 2,542
Yup. Now I get the Stonehenge reference. Gotta watch the movie again - it was great!
Old 01-06-2013, 08:17 PM   #25
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,378
Lay it down on it's side and pile crap all over it. That's where its going to end up anyway.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 01-06-2013, 09:02 PM   #26
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 465
I too am skeptical of the plywood idea. I don't believe it's strong enough to withstand the forces placed on it by the tie-downs, let alone when you start taking corners, etc.
At best it's risky, at worst you'll damage it more if it falls over than if you drain the fuel tank and lay it on it's side on that heavy rubber mat to keep it from sliding. Some strategically placed chunks of 2x4 under the mat and bike may keep it from rocking around during the trip.
Good luck!
ElMartillo is online now   Reply With Quote
Old 01-06-2013, 09:47 PM   #27
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 339
buy 4 long 1/2 inch shank eye bolts with threaded shanks
drill 4 holes through the floor of the truck,
make sure to use thick washers on the bottom side of the truck bed,
secure the bike to these,
then put a 2x4 in front of the front tire with 2 screws into the bed,
then put a 2x4 in back of the rear tire to act as a chock.
Leave the bike in neutral.
When your finished with the move remove the bolts,
then find a stick and tap it into the hole ,
use a razor blade to cut it off flush with the bed.
NOTE this drilling/ bolt fitting operation is easier with a helper.
Mrmerlin is offline   Reply With Quote
Old 01-07-2013, 09:48 AM   #28
pedalmike
Horizontally Opposed
pedalmike's Avatar
Oddometer: 145
I hauled a 1997 BMW R1100RS from VA to CT in a box truck with no tiedown points several years ago. The bike only had 225 miles on it at the time so it was pristine and I didn't want to put a scratch on it.
I built a t-shaped grid using wood 2x4s on edge with the front of the 'T' capturing the front wheel and eye bolts for tie-down points on each end of the 'top part of the T'.
I built it with lag bolts so I could break it down and stow it in a duffle bag because my trip was fly to VA, pick up rental truck and bike and drive back.
If you had enough time, I could ship you mine to keep if you were willing to cover shipping costs or I could take a photo of my setup if it would make it easier for you to put one together yourself.
PM me if you are interested in either offer.
pedalmike is offline   Reply With Quote
Old 01-07-2013, 11:20 AM   #29
rgb2cmyk
rgb2cmyk's Avatar
Oddometer: 255
We hauled a R1200GSA and a Vstrom 650 in the back of a Uhaul. We connected the straps to the wood side rails. They are a little high, but it worked perfectly.
I couldn't tell you how specifically we strapped them, because honestly I'm tie-down illerate and can't move a bike unless it's I'm riding it under it's own power. The bikes were tied down by my brother-in-law, but I know it's possible.
_
14 R1200 GSA (Hopefully lasts longer than 2yrs)
12 R1200 GSA ("Sandy") (Hit by DUI)
09 R1200 GSA (Totaled by SS Sandy)
06 Husky TE450, 04 R1100s BCR, 03 F650CS
rgb2cmyk is offline   Reply With Quote
Old 01-07-2013, 06:28 PM   #30
Mrmerlin
Mrmerlin's Avatar
Oddometer: 339
FWIW the side hooks on most of the trucks can pull loose,
the floor deck is much stronger
Times are GMT -7.   It's 05:26 PM.
