Old 01-06-2013, 11:23 AM   #1
Lee 303 OP
razryadka
Lee 303's Avatar
Oddometer: 69
What is a good way to treat seat pan rust
I bought this bike last month and now I'm considering uncovering the seat to repaint the rusted areas. I have seen plenty other rust buckets for sale online. Any tips would be appreciated.
(If it moves salute it otherwise paint it gray)
Lee 303 screwed with this post 01-06-2013 at 08:13 PM
Lee 303 is offline   Reply With Quote
Old 01-06-2013, 11:35 AM   #2
pbarmy
pbarmy's Avatar
Oddometer: 1,818
These people have some great products,perhaps one would work on your seat.
http://www.eastwood.com/rust-solutio...FYpFMgodExMA8g
"Nostalgia ain't what it once was"
pbarmy is offline   Reply With Quote
Old 01-06-2013, 12:37 PM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,231
The POR-15 products are excellent and everything sold by Eastwood's is top of the line. But I don't know if you want to go to that much trouble. Remove the rust with a mild acid syuch as Naval Jelly, that's made to do just this. Then a good primer and paint. May last as long as the more expensive treatments.
The seats do become unsaveable if left to rust for too long. Yours doesn't look too bad yet. The metal where the seat hinges bolt to is a trouble area.
---Albert Einstein
Old 01-06-2013, 01:31 PM   #4
ML WYDELL
NED
Oddometer: 498
I'm currently repairing my seat pan which is in much worse shape, using POR 15 and fiberglass matting. Hinges were in good shape but alot of holes on the rest of it. If you're getting the seat redone powder coating is always an option.
ML WYDELL is offline   Reply With Quote
Old 01-06-2013, 03:15 PM   #5
Overdog
'Burghherfer.....
Overdog's Avatar
Oddometer: 243
Rustoleum Rust Reformer works pretty well....it leaves a black, paintable surface. Rust on the battery box and other bits of frame rust (like the little rust areas on the OP's picture) go away quick.
1983 Goldwing Interstate
1974 R90/6
1971 Honda CL 350 (shed queen)
Overdog is offline   Reply With Quote
Old 01-06-2013, 06:08 PM   #6
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,638
There are products, such as POR15 that work by encapsulating the rust. I have used most all the rust converters, POR 15, and similar, but prefer phosphoric acid because it allows determining the metal condition. I found using a small brass or stainless wire brush and some naval jelly and/or 'etch and prep' works well. The brush is to remove any flaking/crumbling rust to allow acid to contact the rusted metal. Phosphoric acid chemically changes the rusted metal to a grey surface that can be primed and is somewhat rust resistant. YMMV.
Stan_R80/7 is offline   Reply With Quote
Old 01-06-2013, 07:06 PM   #7
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,625
+1 on Rust Reformer. A good wire brushing first, to the point where dust no longer rises, then a rinse and dry is sufficient prep.
It's not the same as blasting it, but it's nowhere near the work. Just depends on how thorough (or anal) you wanna be.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 01-06-2013, 08:52 PM   #8
gertiektn
KetchikanBeemer
Oddometer: 76
POR 15 Paint
I blasted and painted... this is the result.. came out good.
but have yet to figure out how to upload a pic to the thread from my pic album!
1959 R60 Hack "Slipper"
1960 R50 "Hanz"
(2) 1977 R75/7 "Gertie" & Green Lantern
2004 R1100S "RFAR 1"
No chains here!
gertiektn is offline   Reply With Quote
Old 01-06-2013, 10:09 PM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,231
AdvRider does not host pictures any more. You need a photo account that you can link to for photos. There are various ones that you can use Free. Many like Photo Bucket. I have trouble understanding that site so I use Image Shack, it seems easier to me. Here are directions for posting photos;
http://advrider.com/forums/showthread.php?t=919
---Albert Einstein
Old 01-07-2013, 07:26 AM   #10
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,548
POR-15. Works better on rust than clean metal. Just knock off the loose scaling stuff and hit it. I really like the way it works.
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is offline   Reply With Quote
Old 01-07-2013, 07:34 AM   #11
jackd
Oddometer: 3,071
If your pan is that ugly on this side, then the back side which is up against moisture retaining foam is probably worse. I wouldn't waste time treating the one side only - take it apart and do it right.
jackd is online now   Reply With Quote
Old 01-08-2013, 01:05 PM   #12
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,683
Mine was pretty rough too, disassembled, media blasted, and powder coated.
It is typically worse where you can't see it against the foam like jackd said.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is online now   Reply With Quote
Old 01-08-2013, 01:20 PM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
I think I can see some rust on the foam at the vent holes. I hope it doesn't smell as bad as one I removed years ago, bloody foam was black from molds.
I usually glue some 1/4" or so "close cell" foam over the OEM. Waterproof so gives the OEM foam an extra barrier in case water seeps in from the cover. I don't like the wet butt thing.
Have tools, will travel!
Old 01-08-2013, 03:01 PM   #14
Lee 303 OP
razryadka
Lee 303's Avatar
Oddometer: 69
It was much worse inside but still worth saving.
glad I did't defer this task
at least the paint stuck to the foam
passed the smell test ok
Old 01-08-2013, 03:18 PM   #15
Lee 303 OP
razryadka
Lee 303's Avatar
Oddometer: 69
Thanks to everyone who responded. I will try to post some photos of how the seat comes out. Right now I'm leaning towards good old Rustoleum red primer and a black top coat.I still have a can somewhere that I used on a sidecar project. Kind of surpising that Soviet paint held up better than the German stuff.
Lee 303 screwed with this post 01-08-2013 at 03:26 PM
Times are GMT -7.   It's 04:51 AM.
