01-06-2013, 01:31 PM
#1 |
Oddometer: 120
No hole in clutch oil jet
My clutch has been feeling kind of sticky lately and I figured I would clean the clutch oil jet. I got it out and saw some muck in there tried to push it through and did not budge. All the oil and muck was cleaned out with carb cleaner. I looked into the hole and all I saw was clean brass that blocked the orifice. I tried pushing through with a tiny allen head head wrench and it just hits the solid brass "wall". No compresssed air goes through it as well. ???????
on a 2004 GO!!!!!
01-06-2013, 01:46 PM
#2 |
Oddometer: 26
On the early bikes like yours there was no hole in this, it is a blanking plug.
You can fit an oil jet as a mod. Hope this helps.
01-06-2013, 01:47 PM
#3 |
Oddometer: 120
01-06-2013, 01:49 PM
#4 |
Oddometer: 26
It lubes the clutch actuator rod. The early bikes did not get enough oil through the case to stop them sticking AFAIK
01-06-2013, 01:51 PM
#5 |
AWD please!!
Oddometer: 3,866
Lubes the internal parts of the clutch, booster system.
.3 is standard KTM. We offer a modified .5mm for more oil flow and cooler clutch running. More info here. Might want to upgrade to the one piece pushrod too at that time.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
01-06-2013, 01:56 PM
#6 | |
Oddometer: 120
01-06-2013, 02:06 PM
#7 |
Life is a trip
Oddometer: 3,120
Early bikes had a plug in made of plastic.
Since yours is made of brass, I would think it has the tiny hole. However it seems yours is blocked. #30 is the original, not the same with 0.30mm. I would advise 0.50mm gives better results.
There is always a reason!! |
01-06-2013, 03:51 PM
#8 |
Oddometer: 221
My 2011 was sealed as seen under my super duper Mr. Magoo Magnifying glass so I clamped her to the drill press and kept nudging the glob until the hole showed up. Cost me clutch in clay mud to discover it.
2013 KTM 690 (Thanks FLHRCI Buyer! ) 2011 990 Adventure Dakar (Thank you Honey!) 2010 Aprilia RSV4 Factory 2010 Ducati 1198S |
01-06-2013, 03:57 PM
#9 |
Oddometer: 243
I had a .3 and wanted to get a .5
I took it to a watch maker and he drilled it for free ! |
01-07-2013, 02:03 PM
#10 |
Oddometer: 270
My 03 950A had a solid brass plug
. Bought ten 0.5 drill bits for $2 off eBay and wasted five of these trying to drill a hole in that sucker. So bought an 0.3 oil jet and had no trouble hand drilling to 0.5mm |
01-07-2013, 06:42 PM
#11 |
Oddometer: 460
Can someone elaborate on this? What it's the pushrod's function? Is it what presses on/releases the clutch plates? And why go to a one-piece?
not all those who wander are lost | two earthlings ride around the world Home | Photo Blog | The Route | The Bike | About Us | Participate! |
01-07-2013, 06:56 PM
#12 |
AWD please!!
Oddometer: 3,866
the 3 peice units have shown to collapse over time.
Are you not getting full release of your clutch system? This might be part of the problem. A search might find old posts where this was found to be the issue. Deadly99 was one if I recall.
01-08-2013, 01:18 AM
#13 |
Oddometer: 328
If you have a spare case/engine, piston jet 0.6 works fine and same size OD
01-08-2013, 11:07 PM
#14 |
Zoob
Oddometer: 989
The three piece push rod did not have enough clearance, would rub and generate metal filings, and it would fall apart. The oil was supposed to travel down the center of the rod to oil the clutch.
The one piece is steel and a much smaller diameter. The oil flows on the outside. It doesn't fall apart or rub. I've never heard of a plastic plug, the early ones had brass with no hole, then about early 2005 KTM put in an orifice. These need to be cleaned every 20k or so.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
01-09-2013, 04:05 PM
#15 |
Oddometer: 514
I suspect they have a grab-bin of jets... I have a 2011 Adv R and utterly no hole from new, an obvious cock up by the factory... Bored it out, but then eventually replaced it with a 0.50 from CJ - a very good mod with shifting
---------- Current Bike (number 66!!): 2008 KTM SE 950 R ------------ http://950SuperEnduro.com |
