Old 05-12-2014, 04:31 PM   #46
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,869
Originally Posted by 1coolbanana View Post
There are two types available here in Oz, the CJ's which is the KKA www.efipurgemodules.com which requires removing the check valve from the pump and fitting an alternate one in the fuel line.
Then theres the other one from www.dalbymoto.com.au/adventure (about halfway down the page) which claims to do the same thing but does not require disassembly of the pump or removal of the internal check valve.
Just wondering if anyone can comment on the difference between the units.
Which check valve is this? I only know of a quick connection but not of a check valve on 990 injected models?
Old 05-12-2014, 04:50 PM   #47
1coolbanana
1coolbanana's Avatar
Oddometer: 1,425
About half way down
http://www.efipurgemodules.com/fitting-purge-units.html
Cowabunga dudes................Wuuuuka Wuka
2012 990 R
2004 950 A..........sadly missed
1coolbanana is online now   Reply With Quote
Old 05-12-2014, 10:57 PM   #48
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,869
I see. Thanks.
Old 05-12-2014, 11:01 PM   #49
1coolbanana
Oddometer: 1,425
I just got off the phone to the manufacturer and they are the same units.
The details on the Dalby Moto site are incorrect and they do require the pump surgery of removing the internal check valve.
Have ordered one and should be here tomorrow
2012 990 R
Old 05-13-2014, 12:07 AM   #50
boulder
jersey boy
boulder's Avatar
Oddometer: 125
I have had one on mine since new and only changed filters at 30,000ks they were stained but still looked ok, replaced with gefr filters and carry a spare set on long outback trips just in case.
step up or step aside
boulder is offline   Reply With Quote
Old 05-13-2014, 12:12 AM   #51
1coolbanana
Oddometer: 1,425
Cheers Boulder
Ive just fitted a set of gefr filters today, taken out the check valve and hopefully get the purge module tomorrow.
My filter has only lasted 13,500k's, just copped a bad load of fuel.
The inner filter looks spotless and new, the external one looked clogged!
The Safari makes life a little more difficult but hopefully should be good for a long time to come
2012 990 R
Old 05-13-2014, 12:29 AM   #52
boulder
jersey boy
boulder's Avatar
Oddometer: 125
Hear you with the safari tanks, we had trouble with both our bikes leaking where the pump mates against plastic and have fixed it with a cork gasket, was going to replace cork with viton rubber but the cork has never failed so just left it. Was a worry when Brothers bike decided to start leaking on the french line but lucky we had made a spare cork gasket when we fixed mine at MT Dare.
Old 05-13-2014, 12:34 AM   #53
1coolbanana
Oddometer: 1,425
I just fitted a thick rubber gasket, hopefully Viton, that I got from Safari recently and two 3.5mm section O rings.
Hopefully it will last.
2012 990 R
Old 05-13-2014, 02:05 AM   #54
1coolbanana
Oddometer: 1,425
I see. Thanks.
I took this picture of the check valve as I was removing it this afternoon
2012 990 R
Old 05-13-2014, 07:53 PM   #55
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,869
I wonder why is that neccesary?
I mean what if this check valve was omitted? The fuel would return back to the tank, when the engine would stop working. I understand the fuel is now more readily available to supply fuel to the engine, making it more easy to start, but would be simpler to not have this extra valve.
Cheers.
Old 05-13-2014, 07:58 PM   #56
1coolbanana
Oddometer: 1,425
It keeps the fuel line pressurised but wont allow reverse flow.
The reverse purge wont work with this in place and why a new check valve is installed into the line to do the same job but still allow reversing.
2012 990 R
Old 05-16-2014, 06:00 AM   #57
1coolbanana
Oddometer: 1,425
So got mine and
Fitted up here
New check valve
Also added an extra filter on the crossover so half the fuel gets a pre filtering
Should be good for a while I hope
2012 990 R
Old 06-09-2014, 12:39 AM   #58
1coolbanana
Oddometer: 1,425
Ive been running with this RP module for a couple thousand k's now and so far so good except for one thing.
When cold, after sitting for a couple days, it takes quite a lot of cranking to start.
Up to the point prior to fitting its always been nearly instant start from cold.
Fine when hot though.
Anyone one else experiencing the same that has the module?
2012 990 R
Old 06-09-2014, 01:28 AM   #59
DirtyADV
DirtyADV's Avatar
Oddometer: 2,184
Not sure if the gasket I used was from the safari tank, got blanking plate from a guy through this forum and several gaskets came with it but from the look of it after a few years in place the gasket was quite damaged:
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 06-09-2014, 01:40 AM   #60
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
I've had mine for 2+ years. No issues. You shouldn't have any as it only reverses the pump. Is the check valve correctly functioning?
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Times are GMT -7.   It's 05:34 PM.
