01-06-2013, 08:39 PM
#16 |
because I can
Oddometer: 6,046
That oil could not only be from the tranny input seal but it could also be from the clutch rod. You need to look at ALL the possibilities. It might be from the RMS too. I can't tell from those pictures. If that isn't the original seal it is the original type. The later types are SO much better. I would replace it. I would be tempted to replace that original oil pump cover for the same reasons. Plus it very well could be a big source of the oil.
01-06-2013, 09:24 PM
#17 |
Oddometer: 583
My later type oil pump cover sent me on a freakin' wild goose chase when it developed a hairline crack in the top left counter-bored hole.
It presented symptoms of a leaking rms or worn guide ring or guide ring o-ring. I was advised (by GSPD) to run the motor without the tranny and clutch installed. Bingo! the leak identified itself almost immediately. The earlier angled counter-sunk type covers could not present this issue imo. I am proud to be the recipient of never before heard of airhead problems. True pioneering
Lord of the Bings |
01-06-2013, 09:59 PM
#18 |
Beemerguru...G/S guy
Oddometer: 635
Make sure you chase out the bolt holes for the oil pump cover. Previous owners/mechanics may have used Locktite to hold the bolts. Since the torque is only about 7lbs, any interference means the cover isn't seated..and will leak...again.
Actually, I think you should use some blue so the bolts stay in place.
Greg Hutchinson BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club http://gregsgssite.shutterfly.com/ ![]() |
01-06-2013, 10:11 PM
#19 |
because I can
Oddometer: 6,046
I always heat them up in case some numnut has put red loctite on them. I always chase those threads. Not with a cutting tap but with a thread cleaner or a roll tap.
01-06-2013, 10:22 PM
#20 | |
Oddometer: 583
I know exactly what the numbnut has done.
Lord of the Bings |
01-06-2013, 11:40 PM
#21 | |
Oddometer: 1,025
I realize that I'm comparing apples to oranges ( plastic vs. steel ) but I saw so many leaking neutral switch plates on RDs due to cracks from over torqued C/S screws. The key was loctite and just snug the screw enough to seat the cover and compress the O-ring. Let the loctite take care of the bolt retention. |
01-07-2013, 01:06 AM
#22 | |
Oddometer: 583
Mind you, this cover was at least 25 years old and had only been taken off once. Possibly over torqued.
Lord of the Bings |
01-07-2013, 05:25 AM
#23 |
Shit for brains
Oddometer: 4,851
Woodly, don't know how far you are into the disassembly so apologies if this is 205. Please disconnect the neg cable on the battery BEFORE you remove the front cover. You could damage your diode board.
01-07-2013, 05:28 AM
#24 | |
turd polisher
Oddometer: 770
Oops. Sorry for the drive-by posting there. I see you acknowledged the fact that it's plastic.
I wouldn't bring her home to Mama, but Mama ain't home tonight. JonnyCash screwed with this post 01-07-2013 at 05:50 AM |
01-07-2013, 05:45 AM
#25 | |
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,083
If you can't fix it with a hammer, you've got an electrical problem! |
01-07-2013, 05:48 AM
#26 |
Oddometer: 1,109
Yep RMS = Rear Main Seal
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
01-07-2013, 05:51 AM
#27 |
Oddometer: 1,109
One thing. have you tried smelling the oil residue ? Transmission oil smells completely different from engine oil. That could give you a clue where it's coming from.
01-07-2013, 06:17 AM
#28 |
Wannabe rider
Oddometer: 1,308
Not to beat a dead horse - but please be sure to check if the crank has moved forward as jackd prescribed. If it has not, block it immediately. If it HAS, I've read of a few last ditch tricks that may help you re-seat the thrust bearings. If that fails, unfortunately, it's time for total engine disassembly.
I got lucky in that I read about blocking the crank just before I got that deep into my engine. For the record, both my rear main seal and oil pump cover were leaking, but then again, so was every gasket and o-ring on the entire bike!
"We are very good at preparing to live, but not very good at living." -Thich Nhat Hanh 1973 BMW R60/5 |
01-07-2013, 01:38 PM
#29 |
because I can
Oddometer: 6,046
01-07-2013, 01:45 PM
#30 |
call me iggy
Oddometer: 600
SS, Me109 was referring to himself - he is his own numbnuts PO.
Current: 93 R100GS, 04 XR650L Prior: 73 CB350, 77 R100/7, 83 R100RTI love every motorcycle I've owned and even some that I haven't. |
