Go Back   ADVrider > Riding > Regional forums > Alaska
Old 01-06-2013, 05:48 PM   #1
aklizzard OP
aklizzard's Avatar
Oddometer: 72
doohicky
Who got the best doohicky and should I get the tension spring or just the coil springs
aklizzard is offline   Reply With Quote
Old 01-06-2013, 05:50 PM   #2
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,557
Get the kit with the torsion spring.
Eagle Mike
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is online now   Reply With Quote
Old 01-07-2013, 05:55 PM   #3
AlaskaSolstice
Alaskan Adventurer
AlaskaSolstice's Avatar
Oddometer: 126
doohickey
aklizzard, definitely get the Eagle Mike doohickey, it is really the only choice to consider. Both his product and his customer service are outstanding. As for your choice of springs, I lean towards the torsion spring, even though installation is slightly more involved. (mostly just drilling a small hole for one end of the spring to reside) But if you go with an EM coil spring it is more than adequate, and an improvement over the OEM spring.
Originally Posted by Unstable Rider View Post
[/LEFT]
Unstable: that's a great representation of an OEM "doohickey" (with about 9000 miles on it) and the motion it goes through as it is being adjusted. (just before it gets replaced)
'12 v-Strom, '04 KLR650
AlaskaSolstice is offline   Reply With Quote
Old 01-07-2013, 09:36 PM   #4
TxLoneRider
TxLoneRider's Avatar
Oddometer: 343
Use the force Luke.
Sorry, when I did my KLR, the factory spring was loose, I started to try to get one of the new coil springs on, and quickly determined, it was actually easier to get the Torsion spring on there!
Just take your time, and be really careful and keep pressure on the, bar, crap, can't remember the name, too tired to re-read the instructions, rod, what ever, it has a thrust washer in there, and if you allow it to come out to far when pulling the side case off you can loose the washer in the bottom of the case.
Wish I got the doo-hickey before I rode the KLR to AK, the engine was noticeably smother after it was done, well, when the tensioner was actually placing the correct tension on the chain that is
TxLoneRider is offline   Reply With Quote
Old 01-07-2013, 10:01 PM   #5
Beezer
Oddometer: 5,849
in the end there can be only one... EM
I've done over 3 dozen, there is a lot of bad ones. the "new" generation lever is better but fits loose on the shaft, and the spring is too long. if yours is still attached it will be just laying there... as in not doing anything
Beezer is offline   Reply With Quote
Times are GMT -7.   It's 05:51 AM.
