Old 01-07-2013, 07:54 AM   #1
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,569
Oil filter o-ring and shim part numbers?
I ordered a few new oil filters for the GSPD a while back from max and received only the filter itself, not the "kit" with o-rings, gasket, and shim. The fiche doesn't show part numbers for the o-rings and shims anymore. Any of you ex-parts-counter-guys/gals out there know where I can dig up part numbers to order those separately? I need #4, 5, and 6.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-07-2013, 08:18 AM   #2
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,569
oops, I was looking at the wrong sheet. Here's the correct one:
11 11 42 1 337 098 RING - 44X4 1 $2.05
Recommend replacing when changing oil filter.
12 11 42 1 336 895 WASHER - 51.9X45,3X0,3MM 1 $0.88
14 11 42 1 337 575 OIL FILTER OIL COOLER 0.22 1 $21.30
They still don't list the block square seal that goes on the filter cover. Anybody?
Airhead Wrangler screwed with this post 01-07-2013 at 08:24 AM
Old 01-07-2013, 08:25 AM   #3
craydds
craydds's Avatar
Oddometer: 1,167
Is this what you seek? http://www.euromotoelectrics.com/pro...of-shim895.htm
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 01-07-2013, 08:27 AM   #4
craydds
craydds's Avatar
Oddometer: 1,167
or this? http://www.euromotoelectrics.com/pro...-gasket600.htm ?
I am not sure what you are looking at on the parts diagram.
ABC #12947
'75 R90S
Old 01-07-2013, 08:28 AM   #5
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,569
Originally Posted by craydds View Post
Nope, I'm looking for the black square section o-ring. (as seen below in Anton's excellent illustration)
The black one here:
Airhead Wrangler screwed with this post 01-07-2013 at 08:36 AM
Old 01-07-2013, 08:38 AM   #6
craydds
craydds's Avatar
Oddometer: 1,167
Oh, sorry. Seems like that should come with the oil filter ?? Like this, http://www.euromotoelectrics.com/product-p/of-575.htm . But, I don't know anything about that setup. My filters are different.
ABC #12947
'75 R90S
craydds screwed with this post 01-07-2013 at 08:40 AM Reason: o-ring
Old 01-07-2013, 08:42 AM   #7
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,312
Given the supply I purchased a few years ago my recent knowledge is nil but, max's filters always came as the kit in my experience. Confirm w/ max?
Is it possible your gaskets,etc were "borrowed" out of the box?
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 01-07-2013, 08:45 AM   #8
georgesgiralt
Oddometer: 102
Hello !
Could it be that you had the filter for NON oil cooled bikes delivered ? These two filters looks the same but one is shorter that the other if I'm not mistaken.
This would explain that there are no seals delivered as the non cooled engines does not use them....
georgesgiralt is offline   Reply With Quote
Old 01-07-2013, 08:53 AM   #9
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,569
I don't think so, all three of them came the same, just the filter. Like you, I'd never seen the filter sold without the o-rings, shims before. It also came in a different smaller box than I'd seen before.
Originally Posted by georgesgiralt View Post
Hello !
Yep, I know the differences and these definitely ARE for oil cooler bikes.
Old 01-07-2013, 08:57 AM   #10
craydds
craydds's Avatar
Oddometer: 1,167
I would suggest a call to http://www.euromotoelectrics.com/product-p/of-575.htm .
ABC #12947
'75 R90S
Old 01-07-2013, 09:03 AM   #11
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,569
WOW! A 5 pack of filters for $23.00!?! Not bad.
Old 01-07-2013, 09:07 AM   #12
craydds
craydds's Avatar
Oddometer: 1,167
Not bad.
I bought some recently, the ones for non-oil cooler bikes. They are not BMW OEM filters, but appear to be good quality (subjective, I know).
ABC #12947
'75 R90S
Old 01-07-2013, 10:39 AM   #13
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,297
I have had no luck trying to source this o-ring independent of the filter kit.
the 5-pack does not include that particular o-ring.
hopefully someone will identify a source for the item
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 01-07-2013, 10:46 AM   #14
craydds
craydds's Avatar
Oddometer: 1,167
This picture seems to show the o-rings with the filters - http://www.euromotoelectrics.com/product-p/of-575x5.htm . Is this deceptive advertising?
ABC #12947
'75 R90S
Old 01-07-2013, 10:58 AM   #15
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,569
Oh balls.
I guess I'll give Max a call and see what's what.
Times are GMT -7.   It's 09:28 AM.
