Old 01-07-2013, 06:35 PM   #1
some_guy OP
some_guy's Avatar
Oddometer: 144
95 R100RT Brake Problem
It looks as though my left caliper is leaking between the two halves. So I was thinking about getting a couple rebuild kits and going to work. But...the bolt holding the two halves together nearest the brake line and bleeder is completely stuck and the head is pretty damn stripped out. So far I've only managed to make it worse. Suggestions?
some_guy is offline   Reply With Quote
Old 01-07-2013, 06:42 PM   #2
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,522
Heat, drive a torx bit into what's left of the hole, and use a hand held impact driver.
or, weld a nut to it...
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 01-07-2013, 09:04 PM   #3
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
Or you could drill off the head. Once it's apart, You could work it out with vice grips.
Old 01-08-2013, 03:49 AM   #4
some_guy OP
some_guy's Avatar
Oddometer: 144
Yeah that's what I was thinking. Gonna soak in PB Blaster for a couple days, heat, and go after it with an impact.
Old 01-08-2013, 05:21 AM   #5
bmwrench
Oddometer: 2,181
Remove the other bolt and clamp the threaded half of the caliper in your vices soft-jaws. With a plastic mallet, whack the bolted half so as to loosen the caliper half and bolt. PB won't hurt, either.
bmwrench is offline   Reply With Quote
Old 01-08-2013, 04:36 PM   #6
some_guy OP
some_guy's Avatar
Oddometer: 144
Anyone know off the top of their heads whats in this kit? 34112310493
I can't seem to find its contents.
Old 01-08-2013, 05:57 PM   #7
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,570
Rebuild kit usually has piston dust seal x 2, piston wiper ring x 2, small o-ring x 2, new bolts, a small tube Brembo rubber grease.
Have a look here. It should help some.
http://www.bmbikes.org.uk/Forum/view...p?f=70&t=16046
boxerboy81 screwed with this post 01-08-2013 at 06:11 PM
boxerboy81 is offline   Reply With Quote
Old 01-09-2013, 04:17 AM   #8
some_guy OP
some_guy's Avatar
Oddometer: 144
Old 01-09-2013, 06:05 PM   #9
some_guy OP
some_guy's Avatar
Oddometer: 144
This ended up working great.
Looks like someone had a hard time getting the pistons out in the past, they're all gouged up on from someone trying to pry on them. Popped right out (and shot across the garage) with a little air and look pretty clean with the exception of the gouges.
Old 01-10-2013, 06:20 AM   #10
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,570
The lip on the piston helps seat the dust seal, so if you can tidy them up they might still be fine.
Times are GMT -7.   It's 03:07 PM.
