Old 01-09-2013, 03:14 PM   #16
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 1,722
Originally Posted by crazybrit View Post
That's good as you'd have to sell the OEM pannier racks to be able to afford the Siskiyou panniers. $649 for a set of soft panniers. I'm sure there very nice and all that, but wow.
interesting, I had not seen a price on those yet. Thanks
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 01-09-2013, 03:17 PM   #17
crazybrit
crazybrit's Avatar
Oddometer: 8,039
http://www.giantloopmoto.com/collect...kiyou-panniers
I'm not much of a fan of the clone/knock-off Nomad-rider stuff but they had traction because (IMO) the GL stuff is overpriced (even for made in USA). With this new product it seems there going in even more of the wrong direction. The Orliebs are $200. Hard to see how you can justify that price difference. Just my $0.02
crazybrit screwed with this post 01-09-2013 at 03:24 PM
crazybrit is offline   Reply With Quote
Old 01-09-2013, 03:21 PM   #18
bikyto
bikyto's Avatar
Oddometer: 1,722
you're editing your posts faster than I can reply
I have the ortliebs as well. It's for a different market plus you need some kind of racks.
I am not arguing about the price point. I was just answering the initial question
Old 01-09-2013, 03:28 PM   #19
crazybrit
crazybrit's Avatar
Oddometer: 8,039
You do? Not according to the webpage.
http://www.ortlieb.com/_pdf_en/moto_saddlebags.pdf
http://www.rockymountainatvmc.com/p/...dle-Bags-Black
"No additional rack adapter required."
The ones I have are the older design.without the thermomoulded rear side.
I didn't think you were.
Old 01-09-2013, 03:49 PM   #20
bikyto
bikyto's Avatar
Oddometer: 1,722
I was referring to another ortlieb setup but i did look up the ones you mentioned. It says "no addition rack adapter required" indeed which implies you have racks but don't need an adaptor.
But I am not familier with these anyhow.
I can only attest of the quality and easy of use of the GL that I have been using.
Old 01-09-2013, 03:53 PM   #21
crazybrit
crazybrit's Avatar
Oddometer: 8,039
I have a Coyote and a Mojavi. Good quality indeed and functionally excellent also. I did wear a hole through the underside of my Coyote on the TAT because I also had a PMB rear-rack, but that's not the fault of GL. You may well be correct on the rack adapter bit. So you have a pre-release of the GL Siskiyou bag?
Old 01-09-2013, 03:58 PM   #22
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 4,831
Originally Posted by snowhawk jockey View Post
The new Siskiyou Panniers would be the most passenger friendly high volume alternative in the line.
Harold just posted some 2013 pics and discriptions in the Vendor's forum.
http://advrider.com/forums/showthread.php?t=854141
if you are referring to the model above, no you don't need the pannier racks.
I've ridden with them for several months.
....So you have a pre-release of the GL Siskiyou bag?
We demand a report, bikyto !!
.....Ride Oregon First
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 01-09-2013, 06:02 PM   #23
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,301
I think the best option for soft bags out there are the Walter Colebatch designed Magadan Panniers!
http://www.adventure-spec.com/defaul...-panniers.html
I have Ortliebs that I use on my DR650 but they don't fit on the KTM racks.
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Chad Berger KTM950ADV, DR650
Lone Wolf Expeditions
rokklym is offline   Reply With Quote
Old 01-10-2013, 12:42 PM   #24
Hipster
Hipster's Avatar
Oddometer: 1,435
Those are nice bags but, did you see they're $560.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 01-12-2013, 08:51 PM   #25
DirtClaudeKilly
DirtClaudeKilly's Avatar
Oddometer: 149
I have the GL great basin and i don't think riding 2 up would be feasible for more that a short trip to the store, unless you are lilliputian. It is a nice bag though.
Emoticon illiterate
DirtClaudeKilly is offline   Reply With Quote
Old 01-12-2013, 10:47 PM   #26
modeselector
Common as muck
modeselector's Avatar
Oddometer: 482
It was definitely NOT Harold
modeselector is offline   Reply With Quote
Old 01-14-2013, 10:56 AM   #27
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 744
Maybe we are referring to different posts or threads?
Originally Posted by OlafofOregon View Post
Quick camparo:
Wolfman Expedition Dry Saddle Bags
$219.99
$215-$304 for rack, depending on bike make/model
EX-T Stuff Sacks (set of 4)
$36.99
TOTAL PRICE: $471.98-$560.98
Volume: 38 liters (19 liters each side)
Warranty: 1 Year on RF Welded Bags
Giant Loop Siskiyou Panniers
Volume: 70 liters (35 liters each side) ALMOST DOUBLE THE VOLUME
Included components: 2 waterproof inner bags, 2 laser-cut aluminum exhaust heat shields
Warranty: Lifetime of product for original purchaser against defects in materials and construction.
TOTAL PRICE: $649
Plus: No rack required. Strap it on and ride! Load is positioned closer to the center of the bike, maximizing performance and handling when carrying gear. Fewer parts to break. Multiple attachment points to secure additional bags. Easier access. Mesh internal pockets, exterior pockets large enough to carry 2 liters of fuel in each side. Ballistic nylon reinforcements in impact zones . . . .
Wait until you see them on a bike! These are the final protos in our EICMA 2012 booth - and the proud owner of the display Super Tenere, Raoul. The graphics look even better on the final product bags.
I've logged thousands of miles riding with the prototypes - on- and off-road. And yes, you can ride 2-up. My son has travel many miles with me testing the Siskiyou Panniers (Bend, OR to Cambria, CA for Horizons meeting 2011, Bend to Stevenson, WA + Dualsport Ride, Rally In The Gorge 2012). But he's young, light and tough. Most passengers would prefer to have a cushion strapped on top of the Siskiyous - which is easily done with Panniers's multiple lash points on top. That's a Fort Rock Top Case proto riding on top of the Siskiyou protos.
My friend Brad and I rode the Oregon Backcountry Discovery Route from Bend to Prospect, forest roads from Talent, OR to Klamath River Hwy, CA, northern CA's Lost Coast and all of CA Hwy 1 to Cambria in October for the HU Traveler's Meeting. Not since the original Giant Loop Saddlebag has any of our products been so thoroughly test and punished.
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good!
justin@giantloopmoto.com
snowhawk jockey is offline   Reply With Quote
Times are GMT -7.   It's 11:16 PM.
