Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 03-09-2013, 07:53 AM   #31
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
The AMPS mount is the best solution Garmin has come up with to date. Easy to use, very sturdy and appears to have very few weak points for failure.
Why the hell Garmin doesn't use the AMPS for their so called "motorcycle" units the Zumo's is such a huge oversite it's pathetic. It really shows how out of touch the designers there really are.
Old 03-09-2013, 07:59 AM   #32
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,022
Garmin specs and "in the box" are the same for the Oregon and Montana units, so I wondered if the power supplies were the same (as stated on Garmin's site).
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 03-09-2013, 02:33 PM   #33
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
You mean the "Rugged Mount"? I haven't heard it called the AMPS mount.
Emmbeedee is online now   Reply With Quote
Old 03-10-2013, 06:18 AM   #34
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Yes the AMPS rugged mount. That's what GARMIN calls it. A little easier to type AMPS then rugged mount.
https://buy.garmin.com/shop/shop.do?pID=89575
Old 03-10-2013, 11:43 AM   #35
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
There may be hope for audio from the Oregon 6xx yet! As the unit has no audio jack, it would have to be transmitted via bluetooth connection.
Inspecting the GarminDevice.xml file on my Oregon 650, I found this reference:
Having trouble getting the code to display properly here so....
'VCTVoices' data type with 'VCT' identifier and 'VPM' file extension, location path set to 'Garmin/Voice' and transfer direction set to 'InputOutput'.
As for the Unlimited *.GGZ geocache files, the same file has no reference, so I am assuming this file format is not finalized at this time.
atlas cached is offline   Reply With Quote
Old 03-10-2013, 12:52 PM   #36
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
The more I hear about this model, the less I like about it. I think Garmin may have shot themselves in the foot with this one. It may appeal to new handheld gps buyers but I've seen nothing yet which tells me I "must" have one, unlike the Montana which immediately sold me.
Old 03-10-2013, 01:04 PM   #37
atlas cached
OX Ambassador
Oddometer: 688
I also just completed loading nearly 30,000 geocaches on the device in GPX format.
The unit booted, loaded caches, never complained, and as far as I can tell, they are all present and accounted for.
Old 03-10-2013, 01:28 PM   #38
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
Geocaches don't excite me the way they once did. I haven't found a decent one which wasn't full of McCrap and Mould ® in ages. And don't get me started on travel bugs and coins. What a complete waste of time and money that turned out to be for me.
Old 03-10-2013, 01:50 PM   #39
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Does it have the TTS files?
Old 03-10-2013, 02:56 PM   #40
atlas cached
OX Ambassador
Oddometer: 688
The unit I received does not have any TTS files, or even the Voices directory referenced in the GarminDevice.xml file.
I assume they will be included in a future update.
Old 03-10-2013, 03:04 PM   #41
acesandeights
Asperger
Oddometer: 4,022
Looking at the specs side by side they look to be about the same. What are the things different that sway you?
Old 03-10-2013, 04:07 PM   #42
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
What is better about the Montana, you're asking?
Old 03-10-2013, 04:58 PM   #43
acesandeights
Asperger
Oddometer: 4,022
Right, going to the Garmin site and looking at the specs they look very similar.
Old 03-10-2013, 05:05 PM   #44
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
Garmin's specs are notoriously unreliable. Even the GPSCity site has better specs.
Here's a comparison of the Montana 650 and the Oregon 650, on the GPSCity site.
The biggest advantages, to me anyway are these:
  1. Larger screen size
  2. Better power connector
  3. Decent lockable Rugged Mount
There are others, but these are the most important.
I won't consider buying a gps if it's powered by USB, now. I've had too much trouble with those.
Emmbeedee screwed with this post 03-10-2013 at 05:13 PM
Old 03-10-2013, 05:21 PM   #45
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
Just to show you a few of the differences:
So to recap, the unit size is different, screen size is larger on the Montana, the Montana allows Landscape or Portrait mode orientation, resolution is higher on the Montana, the PC interface on the Montana appears to be faster, and also has NMEA. (I just noticed the Oregon can be powered by AA batteries too so I removed that reference)
Now there may be some facts wrong in the specs, but it seems clear to me that the Montana is a better all-around gps if you want to use it on a motorcycle. If you plan to use it handheld and powered by the battery, then you can save a little weight and size by going with the Oregon.
I dunno, maybe it's just me but for $50 more, why not get the best?
Times are GMT -7.   It's 03:48 AM.
