Old 01-08-2013, 12:35 PM   #1
Murf2 OP
Oddometer: 832
Replace My Uly with ?
Hey all, I'm thinking of replacing my Uly & the wife's SuperTT but I'm not sure what bikes to look at. Please give me your thoughts.
I really like the Buells except for the heat, I could use a lower seat height, although the Uly could be lower and I'd like a larger front wheel & better "off-pavement" handling.
What bikes would you suggest we look at? Money IS an object, I'm sorry to say.
I looked in the "what bike after a Uly"thread but most of those answers seemed to be more "road" oriented.
Murf2
Murf2 is offline   Reply With Quote
Old 01-08-2013, 12:49 PM   #2
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,099
What's the realistic budget?
pluric is online now   Reply With Quote
Old 01-08-2013, 01:02 PM   #3
Murf2 OP
Oddometer: 832
Yeah, That would help, wouldn't it? Not set in stone but maybe $7,500ish. I'm thinking used, of course.
Old 01-08-2013, 01:06 PM   #4
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,099
A Wee for you and a KLX 250 for her.
The Wee may not be the answer to off road exactly.
Old 01-08-2013, 01:58 PM   #5
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
What to ride after Uly?
My brother was faced with the same question and had basically the same requirements. He chose a Suzuki DR650 and set it up with Adventure bike farkles (or rather essentials) after riding mine. This choice does require work on the part of the owner to do the inatallations but personalizing the bike to your own personal needs and desires is part of the fun. There is one other requirement. You might need to park the old ego and get over yourself because you won't get many oohs and aahs while parked in front of the tavern from the Euro bike affecianados. What you will get is a very reliable, low maintenance bike that is lighter than a KLR (no disrespect intended) and can be pretty much anything you want within reason and will do anything from 75 mph on the freeway for days in a row to fairly technical off road work and it will do it comfortably and and for a long time properly equipped. Obviously, there are a lot of choices but if you would rather have fun setting up the bike and then riding, more than doing lots of routine maintenance the DR650 could be the one. I have owned 2 KTM 640 Adventures and ridden a BMW GS800, Triumph 800 Tiger, KTM 950 Adventure, V-Strom, Versys and plenty of off road bikes and dual sports and I just keep coming back to the Suzuki for its economy, simplicity of air/oil cooling, aftermarket parts availability, low vibration under 80 mph, decent handling, relative light weight. It's the Swiss Army knife of motorcycles in my opinion. For ADV work it needs suspension work, help breathing, comfortable seat, big tank, low windscreen and whatever else you want. You can buy other more expensive bikes that already have many of these areas covered but they are often much more expensive to maintain. Bottom line...I have had more smiles per mile and more bang for the buck from the two DR650s and earlier SP600 I owned than any other for Adventure touring. All that being said, I would say try to balance what you will need to best do the intended job, with what will put the biggest lasting smile on your face.
Aleeoop70
Aleeoop70 is offline   Reply With Quote
Old 01-08-2013, 02:30 PM   #6
Murf2 OP
Oddometer: 832
Funny you should mention the DR. There's one of them in the garage. It was my first thought also. I guess I haven't given it a fair chance yet. Bought it just when it started to turn cold and haven't ridden it much. I'm not too impressed with it on the highway, tho. I guess I should wait to make up my mind.
Murf2
Old 01-08-2013, 03:43 PM   #7
biker128pedal
Super Lurker
biker128pedal's Avatar
Oddometer: 3,125
Murf2
So you already have one and can spend $15k on the wife.
Really the DR is rock solid and bullet proof. I keep telling DLJocky since he has one but he won't believe me. He wants an S10. One can buy two new DRs for a new S10. Well almost.
Wee Strommin along.
biker128pedal is offline   Reply With Quote
Old 01-08-2013, 06:14 PM   #8
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,983
Yea!
But an S10 is twice the fun!
RED CAT is offline   Reply With Quote
Old 01-08-2013, 06:46 PM   #9
JTucker
JTucker's Avatar
Oddometer: 2,270
Husky 650 Terra? Smooth engine, fun to ride in the short 15 miles or so I was on it.
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 01-09-2013, 04:59 AM   #10
ronandkat
Oddometer: 155
That big twin
Im a Uly owner, and been a harescrambler for a few decades, Have spent some time on a few of the big singles.
That being said, after getting used to the Uly and that magic motor, I would be VERY hard pressed to drop back down to a single simply for more dirt ability. There are good offerings to do what your asking , that are well within your price range. KTM 950 would be great for what you wanting, as would a last generation Tiger before the remake.
An older Multistrada, or Beemer. All can sport a set of TKC80's to help out in the dirt. Just a thought, good luck!
ronandkat is offline   Reply With Quote
Old 01-09-2013, 05:44 AM   #11
Murf2 OP
Oddometer: 832
ronandkat, I hear you, that hugh torque is fun! I think the Multistrada deserves a look. I had a GS1150 for a while. We just never really meshed. I really like the Uly. The only issues are seat height & heat. both of which I can work around. The only real issue I'm having is a lack of stability on rough gravel/dirt roads at speed. I am going to try a more aggressive front tire and maybe a steering stabilizer. The front seems to get sucked in to loose gravel real bad. Would you have any suggestions.
JTucker, I think I'll have to give the TR a look. I hope to get a test ride when the weather is nice.
RED CAT I think they are out of my price range but seem very cool. I'll keep my eyes open on them too.
Thanks again to all that have replied!
urf2
Old 01-09-2013, 06:23 AM   #12
ejbeert
Oddometer: 50
In 09, I bought an 09 klr650. Farkled with jd jetting, drilled out muffler, 16 tooth cs sprocket, mad stad windshiel, springs for my weight, pelican cases with givi top case. To me it is a better commuter; better on gravel road, more suspenson and lower, easier to get a foot down, better turnig radius, good gas mileage, goes were I want it. I do not use highways expressways; mostly two lane roads and plenty of gravel. I like it. If every thing else had to go, it would stay. It is slow; Electra glide slow. It is a little cramped two up but for 200 miles or so with ice cream and coffee stops it is very doable two up. It is a good handleing bike and fun to ride and I think comfortable solo. I still own the buell, 06 ulysses. I like it as well. I think I would I really would like a cross betwenn the two; may be a 800 cc 6 speed comfortable for two klr. This months dirt bike mag has a nice article on a klr. Greg Frazier has some good stores as well. good hunting
ejbeert is offline   Reply With Quote
Old 01-09-2013, 08:13 AM   #13
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,730
urf2
Funny, I have a GSA and a DR650 and I want a Uly in the stable!
I think that you are always going to find the Uly is a poor gravel bike because the front wheel is so small. There is a reason that sport bikes have 17" fronts, GS's have 19" fronts and real dual sports and dirt bikes have 21" wheels. There are a lot of threads in GSpot about how much better the GS is off road with a 21" front wheel and Woody sells a lot of conversions.
The thing that makes the Uly rock on pavement is the same thing that makes it poor on gravel. A damper and a TKC would help but it's never gonna be great. I'd also be worried about getting rocks in the belt (but most people think that is a non-issue).
Life's full of compromises - if it were me, I'd keep the Uly and ride the DR650 in the gravel.
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is online now   Reply With Quote
Old 01-09-2013, 08:30 AM   #14
gplassm
gplassm's Avatar
Oddometer: 588
I would look for a very nice, street registered WR250F, a KTM 250-530RFS, or maybe the Husky 250 (with it's low seat height). I had a DR650, and it was a great run about street bike, as long as I kept it off of the slab, but it was a horrible dirt bike. It was just too heavy. Look for lighter weight bikes. Light weight is the gift that keeps on giving. If you do try to replace your Uly, you might have to look at a Multistrada, the KTM990's, or, well, that's about it for the lighter end of the Adventure bike class. Everything else is just much heavier.
Street bikes for the street. Dirt bikes for the dirt. Let's keep it that way.
gplassm is offline   Reply With Quote
Old 01-09-2013, 09:38 AM   #15
Thrux181
Thrux181's Avatar
Oddometer: 31
Murf2,
I went from a Uly to a Triumph Scrambler. It's not the lightest but the 19 in front and a 5 inch longer wheel base make it more stable off road. I seat height fits me well and it's got all the power I need.
Bill
Thrux181 is offline   Reply With Quote
Times are GMT -7.   It's 10:46 AM.
