Old 01-08-2013, 01:55 PM   #1
mtntrails OP
Oddometer: 317
2012 R1200GS - Battery Charging
Howdy folks. It's good to be back in the GSpot. I haven't had a BMW for a few years.
I just picked up a new Triple Black 2012 R1200GS. There is a Gerbings plug wired directly to the battery. Using an adaptor, is it OK to use a standard Battery Tender on this bike or do I need to buy the BMW charger that goes in to factory pigtail with the LED flashies on it? I use the Gerbings plugs with an adaptor to hook up Battery Tenders on all of my other bikes with no issues.
Thanks in advance.
mtntrails is offline   Reply With Quote
Old 01-08-2013, 02:01 PM   #2
SourKraut
Oddometer: 6,261
That will work fine. I put the powerlet socket wired directly to the battery in place of the factory bmw socket on mine.
It is just a regular 12V battery.
SourKraut is offline   Reply With Quote
Old 01-09-2013, 01:24 AM   #3
mtntrails OP
Oddometer: 317
Thanks SourKraut - much appreciated!
Old 01-09-2013, 02:46 AM   #4
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,189
Dealer
will say different. Says Can-Bus can get fried. Dealer will say
John Hart McComb MS
2009 Triumph Speed Triple "the mistress"
2008 BMW R1200GSA-" the wife"
2005 Chaparral 210ssi " Native Sun II "
" Damn a motorcycle, if somone would buy this thing I would take the bus home "
onesaintsfan is offline   Reply With Quote
Old 01-09-2013, 03:29 AM   #5
everycredit
everycredit's Avatar
Oddometer: 267
Also, BMW uses state-of-the-art technology in terms of electrical circuits being tri-phased. Meaning, the circuit has a positive, neutral, and negative (ground). A BMW tender is required as a regular DC circuit battery tender will void your warranty and melt your electronics.
everycredit is offline   Reply With Quote
Old 01-09-2013, 03:41 AM   #6
freyke
Oddometer: 329
I have used a basic battery tender directly connected to my battery on my 2011 R1200GS (18,000 Miles) since I bought the bike new in Nov of 2011. NO issues. Here is the one I have.
freyke is offline   Reply With Quote
Old 01-09-2013, 03:53 AM   #7
freyke
Oddometer: 329
Not to be a jerk, but what you're decribing is applicable to AC thoery? It seems you're really only decribing a single phase of which would require a HOT, NEUTRAL (AKA return) and GROUND (AKA Safety Ground). Typically most AC houseold systems are two phase "Y" Alternating Current.
The Battery is 12VDC - no phase is applicable. Just Positive and Negative (ground).
Regards,
Kevin
Old 01-09-2013, 03:54 AM   #8
marty hill
The Energizer Bunny
Oddometer: 3,795
I have a battery tender wired direct to the battery. Have done this on every year 12GS since they came out in '04. Anyone who says this isn't possible or is incorrect is WRONG!
ride till you can't.
1200GS black
Cagiva Gran Canyon Italiano/rosso
marty hill is offline   Reply With Quote
Old 01-09-2013, 05:35 AM   #9
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,498
So long as you run the tender directly to the battery there is no risk to the BMW electronics!
No need for the BMW tender either. IMHO put the Battery Tender on the bike over night once a week and you are done. If you ride more than an hour straight, and do not do a lot of short trips all the time, a tender is not necessary.
Jim
Old 01-09-2013, 06:08 PM   #10
def
I have little to say
def's Avatar
Oddometer: 6,310
Send a message via Skype™ to def
Regards,
Kevin
That would be single phase and there is no delta Y involved.
def is offline   Reply With Quote
Old 01-09-2013, 06:43 PM   #11
BeachMoto
BeachMoto's Avatar
Oddometer: 588
I have been using an older BMW charger (not the CANBUS type, I think it was around $40 or so when I bought it) connected to a SAE pigtail wired directly to the battery for over three years on my '09 GS. Zero issues. I plug my heated jacket liner to the same pigtail (no, not at the same time )
1970 Honda SL100 (my 1st bike in 1972)
1972 Yamaha Enduro 360 (loved this bike)
1977 Yamaha RD 250
1978 Suzuki 250TS
1982 Kawasaki GPZ 550
2007 BMW F800ST
2009 BMW R1200GS (Current)
BeachMoto is offline   Reply With Quote
Old 01-10-2013, 02:58 AM   #12
mtntrails OP
Oddometer: 317
Thanks guys! I appreciate the input.
Old 01-10-2013, 03:17 AM   #13
freyke
Oddometer: 329
If you're takling DC you are correct, there is no phase involved.
Most homes in the US are 110VAC 2 Phase "Y" 60Hz referenced to ground (208VAC referenced between phases) 150-200AMP service.
Most commercial applications in the US are 110VAC 3 Phase "Y" (208VAC referenced between phases ) 200AMP + service.
Ships (US) and mobile AC platforms are 3 Phase 110VAC "D" 60Hz Referenced between pahaes (AKA floating ground) (220VAC volts is stepped up via transformer).
R,
Kevin
Old 01-10-2013, 08:10 AM   #14
SourKraut
Oddometer: 6,261
I tried to head off the controversy in post #2 but every time this question gets posted it turns into advanced electrical theory and charging algorithm nonsense.
It is just a 12V battery people!
Old 01-10-2013, 01:10 PM   #15
BeachMoto
BeachMoto's Avatar
Oddometer: 588
How else are we going to get our post count up :)
1977 Yamaha RD 250
1978 Suzuki 250TS
2007 BMW F800ST
Times are GMT -7.   It's 08:55 PM.
