01-08-2013, 04:27 PM
#1 |
Oddometer: 75
/5 frame versus /6 frame
Does anyone know the changes between a /5 main frame and a /6 main frame? Other than the battery mount bottom piece and ears, and the tab for the steering friction plate. Can I swap everything from a /5 to a /6 frame without major modifications? It appears the horizontal crossmembers at the rear are a larger diameter.
thanks, dan |
01-08-2013, 04:57 PM
#2 |
Oddometer: 820
I believe the fork locks have different diameter cylinders.
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= |
01-08-2013, 09:33 PM
#3 |
Beemerholics Anonymous
Oddometer: 7,354
I believe everything will swap right over. I think (sort of a dim recall on this) the only real difference between the /5 and /6 was rake angle, but that's nothing to worry about.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
01-08-2013, 09:42 PM
#4 |
Oddometer: 1,116
I believe that at some point they fitted a second tube up the middle of the main spine presumably in an attempt to strengthen it. Mine has this double wall tube.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
01-08-2013, 09:49 PM
#5 |
Oddometer: 7,354
I think they did that in 76. But that doesn't complicate the swap from /5 to /6.
01-09-2013, 04:04 AM
#6 |
Oddometer: 75
thanks so much for the information. I appreciate it!
01-09-2013, 01:43 PM
#7 |
because I can
Oddometer: 6,073
I have read that in glossy magazines but BMW's frame jig test all airhead frames. They all have the same rake. /6? ?6's were constantly changing. It probably depends on what year /6. You at some point got the doubled tubed backbone, the extra cross brace under the steering head and a lot more and bigger gussets. By '81 the frames were a lot stiffer and heavier.
01-10-2013, 03:02 PM
#8 |
Oddometer: 75
this frame is dated 6/74. Sounds like a good strong frame to hold all the torque from my R50/5 power plant
01-10-2013, 04:14 PM
#9 |
Still on 3 wheels
Oddometer: 3,382
As you surely know the rear sub frames changed from the short wheel base to the long wheel base. The late 1973 long wheel base sub frames are a double tube cross brace arrangement and stronger than the 1974 stamped steel cross brace arrangement. When I cobbled together my 1974 framed sidecar rig I sought out a 1973 1/2 rear subframe for that additional strength, plus my old QSL solo seat needed the arrangement for the mounting system.
bmwhacker screwed with this post 01-10-2013 at 04:22 PM |
01-10-2013, 04:30 PM
#10 |
Oddometer: 75
yes, I am keeping the short wheel base subframe and swingarm. Did you weld on the tab for the old front end friction type steering dampner?
01-11-2013, 12:19 PM
#11 |
Still on 3 wheels
Oddometer: 3,382
I ended up with a modified dual disc BMW 60's Earls front end... lengthened a /5 damper rod to fit the Earls, then had to get "creative" for the lower damper pieces to mount.
01-11-2013, 10:49 PM
#12 |
Mad Scientist
Oddometer: 2,966
The battery box is the only major difference. Everything else will bolt on
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
