Thread Tools Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Old 06-12-2013, 08:16 PM   #226
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
For modeling software I have been using openscad. I enjoy the flexibility and simplicity of it, as a programmer.
You write little functions (called modules) which draw shapes using 3d primitives or extruded 2d shapes. And then each module acts as a "group" which can be then be positioned, oriented, subtracted from others. It's clever.
potatoho is offline   Reply With Quote
Old 06-22-2013, 06:15 AM   #227
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
Another filament extruder: http://www.3ders.org/articles/201306...ckstarter.html
Old 06-22-2013, 09:29 AM   #228
garandman
Wandering Minstrel
Oddometer: 6,184
Don't know if you guys follow the industry but Stratasys just bought MakerBot for $400 million in stock. Not bad for a company with revenue of $13.5 million.
Here's my latest glob which I will upload to thing inverse and grabcad. Thule makes end caps for their bars for $10, but they are black. I wanted some light colored ones so I wouldn't brain myself. Ran them in an FDM machine and then smoothed them.
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 06-27-2013, 09:14 AM   #229
garandman
Wandering Minstrel
Oddometer: 6,184
This is my latest little self project. My wife and I have both hit our heads on the [extended] Thule bars on my Outback wagon. The caps they sell are black: I wanted some "hi-viz" versions.
Modeled the outside, then the inside, then made a final design. Build time of the models was between 12 and 53 minutes so I had four iterations done in half a day and all four made that afternoon. I'm planning on putting the model up on Thingiverse and/or Grabcad.
Ran two through our smoothing station and left the other two plain to see how they hold up to extended UV exposure.
Old 06-27-2013, 02:49 PM   #230
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,855
Cool dude! I would need 4 of those as well..
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 06-27-2013, 06:22 PM   #231
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,738
So, anybody building triple clamps?
dirtydeeds is offline   Reply With Quote
Old 07-06-2013, 04:37 PM   #232
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
Anyone building a Morgan?
http://www.3ders.org/articles/201305...ts-design.html
Old 07-07-2013, 06:01 AM   #233
Schmeds
scarce
Schmeds's Avatar
Oddometer: 6,558
Interesing. I'm leaning toward a delta/Rostock.
Hornswoop me bungo pony.
Schmeds is offline   Reply With Quote
Old 07-07-2013, 06:52 AM   #234
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
Yeah I've been also. And I'm thinking for my next printer I want to have multiple extruders with support printing so I can do more shapes with overhang.
Can't remember if this price comparison has been posted http://www.3ders.org/pricecompare/3dprinters/
Old 07-07-2013, 08:16 AM   #235
garandman
Wandering Minstrel
Oddometer: 6,184
I always wondered "Why don't these systems have heated build chambers?" as that makes an imense difference in part quality and strength. Answer: Stratasys has a patent on it.
This is significant in that MakerBot can now build a relatively low-cost ABS system with support and a heated build chamber. When or what they build and how much it will cost remains to be seen.
Old 07-07-2013, 08:34 AM   #236
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
A few days ago I switched from 3mm to 1.75mm filament. I'm disappointed.
I'd been having feed issues with the 3mm, after experimenting I found that most of the issues were positional related to the alignment of the bowden tube and extruder. It was finicky and so I thought 1.75mm would improve it.
Indeed, with 1.75mm I can run a simple guide rather than using the bowden tube. However, I have had to slow my printing down by 50% because the 1.75mm doesn't have enough stiffness to run without kinking up after the knurled bolt.
So I'll be going back to 3mm. On the plus side I did learn a bit because I had to partially disassemble the hotend to change the PTFE tube for the different filament size. And in the process I found that one of the plate screws was loose, so perhaps when I switch back to 3mm it won't be so finicky.
I've ordered a PLA spool so I will try that out soon. Yesterday I was trying to print out some of the Morgan arms in ABS and the damn edges were lifting up no matter what I tried.
Today I will pick up some acetone and wipe down the bed's PE Tape. But I'm also hoping that PLA will fare better with large parts. Usually I have success with adding a brim but my PE Tape is pretty worn and that no longer works.
Old 07-07-2013, 08:36 AM   #237
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
garandman,
Have you taken ownership of that kickstarter parts finisher yet? Just curious.
Old 07-08-2013, 07:58 AM   #238
garandman
Wandering Minstrel
Oddometer: 6,184
Are you building the parts solid? Can you build them with sparse interiors? That will help with the curling along with better adhesion.
Originally Posted by potatoho View Post
garandman,
Haven't seen it yet.
Old 07-08-2013, 06:27 PM   #239
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
I did the acetone/abs solution as a glue, along with a healthy brim. Success!
Old 07-09-2013, 10:46 AM   #240
toanq
toanq's Avatar
Oddometer: 35
Vapor Bath
Has anyone tried the acetone vapor to finish a piece yet?
toanq is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 11:01 AM.
