04-15-2012, 04:20 PM
#1 |
Oddometer: 51
Garmin 665 Sat radio antenna..
Any suggestions on where to mount the 665's antenna for the sat radio? I have seen a couple mounted on top of the brake reservoir. Not sure if that was done with velcro or ?
04-15-2012, 06:36 PM
#2 |
Oddometer: 558
That is what I have done with mine. Heavy-duty double stick velcro and it has sat there for thousands of miles. And...the 665 has been flawless!
04-15-2012, 07:46 PM
#3 |
Oddometer: 606
You might want to fill in your profile, it's kind of hard to offer advice when we don't know what kind of bike you have.
"If you have to ask, You wouldn't understand" 2005 1200GS "The Big Red Pig" |
04-15-2012, 10:22 PM
#4 |
BMW Dirty Dozen
Oddometer: 250
In between the lower windscreen mount. Velcro, no reception problems.
04-16-2012, 03:17 AM
#5 |
Oddometer: 1,001
04-16-2012, 03:40 AM
#6 |
Oddometer: 51
Thanks guys!
04-16-2012, 05:09 AM
#7 |
Still a n00b
Oddometer: 35
I mounted mine in the same place as mikegc, but just used velcro strips instead. It's been holding there with no issues since I bought the bike in January. I was able to tuck the extra wire in behind the GPS as well so that it looks nice and neat.
04-16-2012, 09:40 AM
#8 |
BMWMOA, BMWRA, AMA (Life)
Oddometer: 159
Gxm 40
Garmin says “The GXM 40 antenna should be mounted at a minimum of 10 (4”) cm away from the zumo 665. An ideal distance would be at least 30 (11.8”) cm between the devices. If the GXM 40 is mounted closer to the zumo then you may experience interference that can interrupt the XM signal. “ I did have mine mounted on the front breaker reservoir and I did have problems. So I moved it to the beak on the front fender with Velcro.
Thanks Al Warren, OH 01 R1150GS 00 R1100RT 07 KLR650 84 RZ350 73 R75\5 LWB BMWMOA. BMWRA, AirHead, AMA (Life) |
04-16-2012, 12:59 PM
#9 | |
Blargh!
When I had my Versys I mounted the GXM 40 on the the passenger grab handle on a techmount on my alu-rack and ran the USB cable to the rear. On my GS and threw caution to the wind and mounted the antenna to the GPS mount using a bracket. ![]() ![]() ![]() I'm still fine tuning the adjustment of both the bracket and the mount, but I would like to think that the steel bracket the GXM40 is screwed into, helps shield the XM signal from interference from the Zumo 665 itself. It blocks the bottom of the entire antenna with a steel plate directly between it and the Garmin.
ALL ADDERS ARE PUFFS! 2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold) PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims! Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks. |
04-16-2012, 02:05 PM
#10 |
Oddometer: 1,001
My antenna is 3.5" from the unit and I've never had a reception problem. It works like a champ.
Mike mikegc screwed with this post 04-17-2012 at 02:48 AM |
04-16-2012, 07:01 PM
#11 |
BMW Dirty Dozen
Oddometer: 250
04-16-2012, 08:37 PM
#12 | |
Oddometer: 11
I tried to locate mine similar to the location in post 5 when I first installed it. When driving north, either the GPS, dash, or my gigantic melon would block the signal of the satellites (in the southern sky, presumably, made worse being in Wisconsin). Having it just that little bit higher keeps the signal from cutting out ever. |
04-16-2012, 11:45 PM
#13 | |
Oddometer: 55
Thanks Doug |
04-17-2012, 02:49 AM
#14 |
Oddometer: 1,001
04-17-2012, 08:47 AM
#15 |
Oh shit, not him!
Oddometer: 731
This is how I did it.
