Old 12-27-2012, 05:47 PM   #1
seez0916 OP
Oddometer: 2
Front brake issues R100GS/PD
Help, the front brake on my '95 R100GS/PD is locking on? Trying to bleed it but it is still locking the front wheel up. Ideas?
seez0916 is offline   Reply With Quote
Old 12-27-2012, 06:07 PM   #2
hoss18
hoss18's Avatar
Oddometer: 95
Been wet / salt? - Corrosion on pistons or pin.
How old is brake line? - possible is crap inside line blocking master cylinder / line / piston
BMW - a love hate relationship
hoss18 is offline   Reply With Quote
Old 12-27-2012, 06:11 PM   #3
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 2,945
caliper needs cleaned/rebuilt?
got to get it on the good foot
camgregus is online now   Reply With Quote
Old 12-27-2012, 06:57 PM   #4
Big Bamboo
Big Bamboo's Avatar
Oddometer: 812
Sounds like the return port on your master cylinder is plugged. Pull the cap off and look down at the bottom of the reservoir. You should see two tiny holes into the bore of the master cylinder. Use a toothpick or similar to clean them both.
"No hour of life is wasted that is spent in the saddle." =Winston Churchill=
Big Bamboo is offline   Reply With Quote
Old 12-27-2012, 07:55 PM   #5
supershaft
because I can
Oddometer: 6,061
That's my guess too. I have seen a rash of troubles caused in the last few years from the rubber hoses coming apart on the inside. Especially on oilheads for some reason but still . . . .
supershaft is online now   Reply With Quote
Old 12-27-2012, 10:29 PM   #6
seez0916 OP
Oddometer: 2
Thanks guys, the little holes in the master cyclinder were clogged and the brake lines are also crumbling. Tried to get a new master cyclinder but none available in Oz at the moment so rebuilt it. Will order new lines and a caliper kit and it should be all good. Thanks for the help.
Old 12-28-2012, 09:55 AM   #7
dm635
Oddometer: 125
Agree on that. Been driving old bimmers since around '95 & there's been many a brake problem fixed by replacing the rubber lines. They can even fail by acting as a one way valve holding pressure & not releasing.
1978 R80/7
dm635 is offline   Reply With Quote
Old 12-28-2012, 11:02 AM   #8
supershaft
because I can
Oddometer: 6,061
Originally Posted by dm635 View Post
agree on that. Been driving old bimmers since around '95 & there's been many a brake problem fixed by replacing the rubber lines. They can even fail by acting as a one way valve holding pressure & not releasing.
+1
Old 01-08-2013, 05:55 PM   #9
hoss18
hoss18's Avatar
Oddometer: 95
Yes the rubber hoses do eventually fail on the inside - but lets be realistic - in many cases 20+ years from a rubber hose is not bad. BMW does recommend their replacement at 10yrs.
Times are GMT -7.   It's 03:23 PM.
