Old 04-11-2013, 06:11 PM   #31
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 512
touché Mortimersickle...One more thing, need a qualified educational type to write the grant proposal for their engineering school.
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 04-11-2013, 06:40 PM   #32
mtncrawler
mtncrawler's Avatar
Oddometer: 1,075
Originally Posted by MortimerSickle View Post
NOW we're getting somewhere...
I think I'll load the tires with UHD's, WD-40, and SLIME and call it good..
2007 BMW 650 XChallenge..
2009 BMW R1200 GSA..(Gone.. )
2004 BMW R1150 GSA (Gone.. )
"You think dogs will not be in heaven? I tell you, they will be there long before any of us." Robert Louis Stevenson
mtncrawler is offline   Reply With Quote
Old 04-12-2013, 08:42 AM   #33
triplenickel
triplenickel's Avatar
Oddometer: 2,426
Don't let the drama lamas scare you, I have 70k on this bike alone with UHD's and never a problem like 99% of the others that use them.
With everything else being equal how does a UHD tube generate more heat than a thinny?
07 SE
PG007
Old 04-12-2013, 11:21 PM   #34
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,218
I will also add that I used one particular UHD tube with 2 hot patches on it for over 20,000 miles. No issue. I'm not saying you cant have a high speed blowout on pavement, but my best guess is that low pressure was a more likely culprit than the thick tube.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 04-14-2013, 03:39 AM   #35
syzygy9
syzygy9's Avatar
Oddometer: 297
So the question is why are you running UHD inner tubes? they don't help against conventional punctures and may help resist pinch flats. So the only time to use them would be low'ish speed xcountry running at low tyre pressures, yet lots of people seem to use them for street use where presumably they are being run at high speed and high pressure.
The main disadvantages are that they get much hotter than conventional tubes (unless pumped up hard so no tyre flex) which may cause them to blow out, weigh more (more unsprung weight) and more unwieldy to work with.
bikeless no longer! welcome home, 2011 KTM 990 Adventure!
syzygy9 is offline   Reply With Quote
Old 04-14-2013, 05:49 AM   #36
FakeName OP
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,776
The advantage of a international forum is in the numbers- they stack up interestingly against theory. Leveraging experiences help us gather data with which to make our own decisions.
Foe me, of course if I were riding only on the street, I'd not worry about flats.
But I ride both, with a strong preference for remote off-road, but often ride the highway to get there. Some of that road work includes stretches of freeway that crosses hot deserts.
One needs only one hot-weather tire change without shade to promise oneself to take all possible measure, however small, to avoid a repeat event.
I run the UHDs.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 04-14-2013, 08:17 AM   #37
triplenickel
Oddometer: 2,426
Why? Proof or internet myth? Granted I don't live in a hot climate but I've yet to feel a diff in tire carcass temp with UHD's compared to thinnys. I assume that's where people are feeling this "extra heat" or are they doing some type of internal temp measurement?
07 SE
PG007
Old 04-14-2013, 01:37 PM   #38
mtncrawler
mtncrawler's Avatar
Oddometer: 1,075
Originally Posted by syzygy9 View Post
So the question is why are you running UHD inner tubes?....
Not sure you meant this for me (or the OP)...but I am not running UHD's - just trying to figure out if its the right way to go.
Originally Posted by FakeName View Post
...But I ride both, with a strong preference for remote off-road, but often ride the highway to get there. Some of that road work includes stretches of freeway that crosses hot deserts....
I run the UHDs.
This describes most closely what my riding goals are for the "X" and the next couple years and I tend to think in the same terms as far as pros/cons. It seem like trouble arises with UHD's running higher speeds and low pressures on pavement, whereas if you increase the pressure for the road/higher speeds, it keeps temps down that are created via the tube slipping at lower pressures? Did I just answer my own question then?
I would interested in seeing data as well...maybe not a thesis as suggested above.. (I deal somewhat regularly with statistics, so I have a good idea of what it takes to reach significant, statistically sound conclusions from data). It ain't gonna happen on a forum without some very careful and consistent data collection (probably a stretch at that)..
Old 04-14-2013, 03:34 PM   #39
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,728
We run them front and rear in Maya in CA heat with no issues, we are also loaded two up with house and contents.
Just changed the MT21 front tire at Moto Mundo in Antigua with 10646 km on it and the tube looked like new.
Let you know what the rear looks like in Bogota when we change the rear with a K60 Heidi on.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 04-14-2013, 08:55 PM   #40
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,137
http://www.harborfreight.com/Infrare...ODkwNSJ9%0D%0A
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 04-14-2013, 09:57 PM   #41
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,109
Yes they do. I've had cactus needles puncture UHD tubes and never known until I've changed the tire, I've had similar needles destroy normal tubes.
Sheep Shagger is offline   Reply With Quote
Old 04-15-2013, 01:47 AM   #42
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,538
No real data here just my own usage....
I'll do about anything to not get a flat offroad so my solution is to run Bridgestone UHD's and don't lower the air pressure off road, just leave them at 25-ish psi all the time. I have wide 17 and 19 tires (BMW G650 XCountry) and no rim locks but I'll ride 80 on highway and personally like the tradeoff and don't miss running the lower air offroad even in a little sand but certainly don't miss getting snakebites in rocks.
Now I don't know if anybody thinks 25 is "high" but sure as hell ain't 15, that would be stupid for me without rimlocks anyhow.
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~
FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar!
snooker is offline   Reply With Quote
Old 04-15-2013, 03:57 AM   #43
syzygy9
syzygy9's Avatar
Oddometer: 297
So an item that has penetrated a stiff tyre carcass is than stopped by a soft rubber tube - good luck with that theory.
The value or otherwise of UHDs is very hard to prove. I have just ridden 5,800kms through the Aussie outback on a fully laden 990 with conventional tubes, along with a similarly laden friend on a F800GS also on conventional tubes, 90% dirt roads and tracks, and neither of us had a puncture. Does this prove that conventional tubes are the greatest thing since sliced bread - no. If we had been on UHDs would we now be singing the praises of UHDs - I don't know.
The only true comparison I guess would be a statistically meaningful sample (say 10 riders) on same bikes, weight, time, tracks, etc, and one set on conventional tubes the other set on UHDs, and see whether a statistically meaningful result ensues – ie. 90% of the conventionals got punctures while only 10% of the UHDs did.
Is there such an experiment? I haven't seen one. So we rely on anecdotal evidence mixed in with a healthy dose of common sense. Commonsense says that if something has penetrated the tyre it 'in most cases' isn’t going to be stopped by a much softer tube. Can UHDs help with pinch flats? Hard to say but seems possible and there seems to be some anecdotal support for it.
The downside is heat generated, the thicker the rubber and the more the flex (the lower pressure the tyre) the hotter the tube will get (the extreme example being Michelin Bib Mousse Flat-Proof Competition Foam Tube where even the manufacturer doesn’t recommend sustained high speed running and competitors using these replace them at regular intervals) and they're heavier, increasing (unsprung) weight (worse if your also carrying spare tubes) and just unwieldy to work with.
My thoughts on this are that for relatively low speed, low pressure dirt road and track riding (averaging 80km/hr or less) where you might be running lower pressures for comfort and grip there is a case for thicker tubes which may help mitigate pinch flats. I don’t think I’d like to run these at high speed for extended periods of time. I guess the conundrum than is the slab sections between the dirt sections – what to do then? Frankly, I’ve gotten away with conventionals to date, so they work for me. YMMV
syzygy9 screwed with this post 04-15-2013 at 05:34 AM Reason: splelling
Old 04-15-2013, 05:53 AM   #44
Sheep Shagger
Show me your fleece
Oddometer: 2,109
That's not what I said, I specifically stated punctured (meaning cactus needle went through).
Not really. Take two tubes normal and UHD, blow them up to the same PSI you would use on a ~400lbs bike and put a needle in each. Report back about what happens. You can do the same with (thick and thin) balloons.
The reality (for me and where I ride) isn't that they reduce the number of punctures, it's that they reduce my time in having to stop and fix every puncture.
I've personally run them on 1k road days (miles not km) through the TX/NM/AZ & NV heat, not had an issue. BUT, I do believe the "theory" behind head build up and ultimate failure, so I'd wouldn't recommend it. Although I think there are ways to reduce the risk.
Old 04-15-2013, 07:45 AM   #45
syzygy9
syzygy9's Avatar
Oddometer: 297
I must be missing something here; are you saying that if you 'puncture' a UHD tube (ie. push something like a needle all the way through) it doesn't go flat, self seals or something? I've never heard that before.
Times are GMT -7.   It's 03:27 PM.
