03-15-2013, 09:19 PM
#1 |
CRASHING BORE
Oddometer: 2,673
Tips for the young players
I've had a brainwave...we need a new thread....don't know if one already exhists...don't care....just like the title sez....I'll kick it off...then its over to you lot...ok...tips on the track ..in camp ..in the workshop...what did you do to get yourself out of a bad mess...how did you save your sorry arse....etc..
Today I've been changing the wheel bearings on my trailer..after knocking out the old cones and a clean up ...time to knock the new cones in...get them started with a few light taps with the the hammer and tap them in using a piece of hardwood flat across the hub...when you get the cones in flush with the hub you need something else to be able to keep driving them in easily....so this is where my big idea comes in...which I invented naturally of course.. ![]() ...get the grinder and cut the old ones you've just knocked out and use them to finish driving the new cones home...place the old cones on the new cones the same way up as the new ones and bang the lot in...the cut cone springs back out with a slight tap from the back side of the hub....clear as mud...and keep the cut cones for next time... unc
.. I fixt it...my way....gjr |
03-15-2013, 10:07 PM
#2 |
Farkle Finder
Oddometer: 5,586
& while you've got the grinder out
A Convertible............
03-15-2013, 10:31 PM
#3 |
Oddometer: 355
dont use wood,,bloody dirt and grit and cleaning takes time away from
![]() ![]() I always use a brass drift,,which is a brass bar about 5/8" dia and what ever length you like the idea is brass is softer than steel and therefore will not deform the steel |
03-15-2013, 10:41 PM
#4 | |
tEAM iDIOT
Oddometer: 5,606
I suppose you could lose an eye if you're not careful...
tEAM iDIOT. The original, and still the best.
03-15-2013, 10:48 PM
#5 |
Oddometer: 2,728
Put bearings in a plastic bag in the freezer the night before fitting;
Use a socket, reversed on an extension bar to centre it, to drive in the bearing
"I would like to die on Mars; just not on impact." Elon Musk |
03-15-2013, 11:52 PM
#6 |
Oddometer: 4,295
Just hit the fecking things
03-16-2013, 12:11 AM
#7 |
Oddometer: 1,091
when you buy a new toy
check it today bought new light from aldi part assembled did the other part had a good look at the part that aldi had done was wrong pulled it apart and fixed it morale always check ur work and double check anybody elses cheers |
03-16-2013, 12:25 AM
#8 |
Trouble
my tip
If something's too hard to fix, flash your tits and some poor sucker will do it for you.
dr650: Charlie Paused my round Oz tour.. arghhh Plinkin! Adventure Riding Blog | Adventure Riders Blogs |Bike Gps, bluetooth and much more (Coupon Code= adv) |
03-16-2013, 12:31 AM
#9 | |
Oddometer: 187
DRZ 400 E Aprilia Tuono Avanti Blade C 8 |
03-16-2013, 12:34 AM
#10 |
Oddometer: 1,091
03-16-2013, 12:38 AM
#11 |
CRASHING BORE
Oddometer: 2,673
Yeah..I've used the socket trick before...the new cones were a bit tight to get started and that freezing thing came to mind...couldn't remember whether it was freeze the bearing or freeze the hub...either way I would have been scalded for putting bike parts in freezer...so I just blundered on..
03-16-2013, 12:45 AM
#12 |
CRASHING BORE
Oddometer: 2,673
Nice ti s Na...oops tip Nazza...in the same vain...if you have had a serious accident in a remote area and you dont have a plb, sat phone , spot or the like...if you can make it to your feet..or knees even...just unzip and take a leak...a vehicle will suddenly appear out of nowhere...
03-16-2013, 01:03 AM
#13 |
scrub basher
Oddometer: 980
Tip # 69
worked for me.......................
![]() had me "talk wench" out before ya knew it...................... ![]() cheers matty...............................& ani..............................& nazza....
03-16-2013, 01:11 AM
#14 | |
tEAM iDIOT
Oddometer: 5,606
At 3:30 the bus hadn't arrived like it should have so we waited longer. At 4:00 we were starting to get a bit worried because it was our only way home, the bus had never been that late, and we were a bit late to the bus stop so we thought we may have missed it. At 4:15 I suddenly had the great idea that if I lit up a cigarette the bus was sure to show up, so I lit one, and sure enough the bus turned the corner. My mate turned turned to me and yelled, "You fucking idiot! why didn't you light one up half an hour ago!"
03-16-2013, 01:14 AM
#15 |
tEAM iDIOT
Oddometer: 5,606
If you are getting dodgy looking Philips head screws out, give the screw driver a sharp tap or two with a hammer to help seat the driver and loosen the screw a bit...
I think thats what it does anyway...
