Old 02-28-2013, 09:34 PM   #16
JSkinner
SeattleRider
JSkinner's Avatar
Oddometer: 32
Rigid
I think someone needs to use a 10 inch E Series Rigid Industries light bar in place of the headlight. The stock headlight is exactly 10 inches wide..
JSkinner is offline   Reply With Quote
Old 03-01-2013, 07:01 AM   #17
battlecattle
Oddometer: 271
10.5in last time I checked
http://www.batlecatle.com/
CRF250L Service Manual
2014 KTM 690 Enduro
2014 CRF250L - Totaled
battlecattle is offline   Reply With Quote
Old 03-11-2013, 08:23 AM   #18
battlecattle
Oddometer: 271
A work in progress, but should turn out pretty good.
2014 KTM 690 Enduro
Old 03-11-2013, 09:41 PM   #19
eddyturn
Wannabe
Oddometer: 2,094
Vewy interwesting.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 03-12-2013, 06:22 PM   #20
The Salt
Oddometer: 1
The Salt is offline   Reply With Quote
Old 03-13-2013, 05:09 AM   #21
bastimentos
Oddometer: 105
That's a unique setup you're building there battlecattle. I can see from that shot you are prone to making modications to suit your needs of the bike, what is it about that lighting rig that made you build it?
bastimentos is offline   Reply With Quote
Old 03-13-2013, 07:38 AM   #22
battlecattle
Oddometer: 271
Many things really. The first huge hurdle is the 400watt stator. Under normal use it is plenty but if you add heated gloves, jacket and stop and go traffic it hates you. The headlight alone draws 4.8amps per headlight! and you have 2 of them! In contrast my heated jacket alone draws 7.4amps total with jacket and low beam headlight is 12.2amps now that seems reasonable but 12.2amps * 12V = 146.4 watts we only have 400watts! That is almost half of the available power, add the highbeam and you are over 200watts (204watts).
Now I haven't found a single source that has determined what the bike requires to stay running so I am saying roughly 150watts. If that is the case I have a remaining 4.2amps left. Granted that is a high draw and assuming idle but that is worst case. If I am in stop and go traffic with bitter winds would you want to turn your heated gear down? Not I!
back to the headlight...
My new headlight design will draw .85amps on lowbeam. and 2.4amps for each highbeam. So with all 3 lights on 5.65amps with the ability to turn off each individually. That means I can bring my current draw down by 5.65amps with the flick of a switch (assuming daylight). Also the 3 headlight design gives me piece of mind in case of a failure, hopefully at least 1 will continue to work until civilization.
[history]
A little history, (or skip nothing important) I have been working on this for a few months and originally started off with a .5amp LED headlight replacement which for lack of a better word, shitty. But it also showed me another problem with the bike itself. The headlight blub out light, that little miracle would shut down the circuit if the current was too low. Now after trying to find a device that would produce a variable steady draw I was able to determine (roughly and crudely) that the CANBUS is looking for a current draw of atleast .8amps. On my meter I saw .7 but it wasn't steady so I don't believe it. Now if you remember from the previous part of the post my low beam draws .85amps, how convenient no error light!
[/history]
Now the biggest part of this whole project is to minimize the effect on the "stock bike". I don't want to cut the harness (unfortunately unless a miracle happens I will have to), I don't follow the normal farkles people put on, nor do I want to bring the bike to a point I cannot put the stock stuff back on.
I will answer any questions I can about what I am doing and why. I over think everything and have very high standards about how I do things. As an example wiring everything on the bike, every splice (very very few, eliminating them this year) is done in this manner.
2014 KTM 690 Enduro
battlecattle screwed with this post 03-13-2013 at 07:46 AM
Old 03-19-2013, 06:34 PM   #23
battlecattle
Oddometer: 271
Current progress...and my soon to be dash.
2014 KTM 690 Enduro
Old 03-21-2013, 01:17 PM   #24
MSH
The Salt
MSH's Avatar
Oddometer: 3,231
Rad! What else are you going to add to the dash?
~KTM 640 Adventure R~
"Lately it occurs to me what a long, strange trip it's been"
MSH is offline   Reply With Quote
Old 03-21-2013, 01:23 PM   #25
battlecattle
Oddometer: 271
I am stealing this idea from another inmate.
Each light on a switch but a subordinate switch for the highbeams and master for the lowbeam. Heated gear controllers and, I might also relocated my voltmeter to it.
2014 KTM 690 Enduro
Old 03-24-2013, 06:57 AM   #26
malloy
Oddometer: 772
What is this?
Anybody here know about this setup?
https://lh3.googleusercontent.com/-V...s800/photo.JPG
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Old 05-08-2013, 08:19 PM   #27
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
Nope but I would like too...
BMW F800 GS 2009
Ckeck out my ride reports
Air0ne is offline   Reply With Quote
Old 05-15-2013, 09:04 AM   #28
battlecattle
Oddometer: 271
Stock headlight vs my 3 LED headlight. Everything works as factory (highbeam switch), no "bulb out" and I can turn each light off individually.
2014 KTM 690 Enduro
Old 05-15-2013, 09:49 AM   #29
toro618
toro618's Avatar
Oddometer: 982
Baja Design Squadron light with a KTM shell
toro618 is offline   Reply With Quote
Old 07-19-2013, 05:01 AM   #30
stege
Wonderer
stege's Avatar
Oddometer: 289
Saw this one too... Looks like its inmate "snowy's"
I'm interested in a headlight swap as well, the stock one is a useless piece of crap, both mirrors smoked from using stock bulbs
Can you confirm (with a link) the identity of this bike's owner? Thank you!
the older I get the faster I was
stege is offline   Reply With Quote
Times are GMT -7.   It's 12:36 PM.
