Old 11-17-2013, 08:38 AM   #31
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
I'm pretty sure I will look like a noob but hey... I don't care :)
Is it possible to have low / high beam with a single headlight? Do we need a special bulb or two?
BMW F800 GS 2009
Ckeck out my ride reports
Air0ne is offline   Reply With Quote
Old 11-17-2013, 08:53 AM   #32
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,769
Yep it is. look at most of single headlights. Only one bulb. Classicly H4, now exists H13 but I don't think that they are applied to Bikes yet.
Loutre is offline   Reply With Quote
Old 11-17-2013, 10:05 AM   #33
peteace
Oddometer: 33
In addition to H4 which Loutre already mentioned, many projector headlights have only one bulb (H7, H9, D2S Xenon) and they are switched between low / high beam by internal shutter.
I have seen at least one 1150GS, where headlight unit was replaced with Hella 90 mm projector headlight(s). Those units are used in many new trucks and buses in Europe, and they are available in many combinations. Despite the small size, light output and patterns are very good, but they can be pricey.
F800 should be able to accommodate two Hella 90 mm headlight units in place of original headlight unit.
peteace is offline   Reply With Quote
Old 11-17-2013, 08:26 PM   #34
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
What do you think of that? www.theretrofitsource.com... Do I have enough space inside the headlight to do the same as this guy?http://www.advrider.com/forums/showp...0&postcount=47
BMW F800 GS 2009
Old 11-17-2013, 10:45 PM   #35
dpm
Oddometer: 200
you need to get the glass off the do a retrofit. Let us know how you get on there...
dpm is offline   Reply With Quote
Old 11-18-2013, 08:06 AM   #36
jengel451
1 Cool MotherF#$cker
Oddometer: 802
To dpm's point. I don't believe anyone has been able to successfully get the glass lens off. They are using some voodoo magic that nobody has been able to figure out yet.
jengel451 is offline   Reply With Quote
Old 11-19-2013, 04:02 AM   #37
LukasM
Oddometer: 5,426
I have taken apart 2 housings because of cracks in the glass, and I don't see how you could ever remove it in one piece. The glass is set into a channel with a lot of very strong adhesive, so even if you get it to soften up (will take a lot of heat!) you can't really pry it out without damaging the housing.
Old 11-19-2013, 09:04 AM   #38
zaner32
In over my head
zaner32's Avatar
Oddometer: 651
I can confirm Lukas's comment. I've tried and tried to pry it out, with heat, chemicals used to soften glue (Acetone), try to break down the glue (Ethyl Acetate), and also tried dry ice (to try to make the glue more brittle). No go!.
I kept my old one as i'd like to install a projector light as a main beam, and an LED array as a high beam.
projector light from a unit like this... http://www.protuninglab.com/92bmwe362drc2.html
LED array something like this that would fit where the original high beam is located. http://www.aliexpress.com/item-img/L...665502013.html
Another thought is to find a newer model totalled BMW vehicle with the halo projector unit and cram that into the housing somehow.
2009 KTM 990 Adventure
Just ride!
zaner32 is online now   Reply With Quote
Old 11-19-2013, 08:10 PM   #39
JRWooden
Oddometer: 4,290
Ok ... I'm just thinking out loud ... with ... in hand...
That guy in Europe selling the assemblies on eBay....
I wonder if he could get some that were UN-assembled ...
Maybe s/he has connections ...
Who among us speaks Italian?
That would aid in communicating our wants and needs I think
http://www.ebay.com/itm/FANALE-FARO-...item2ec5f66e51
W
Old 11-20-2013, 12:45 AM   #40
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,769
You wrote that at 05:10 AM . Is that your Canadian version of full english breakfast?
Old 11-20-2013, 03:43 AM   #41
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
W
I tried to buy it but the guy canceled the order (no shipping to Canada)
Edit: oups, no sorry... that was the other link, my bad
BMW F800 GS 2009
Old 11-20-2013, 03:47 AM   #42
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
I was a level 70 Shaman a long time ago... Maybe I would need to learn back my spells :)
More seriously, not possible with that?
BMW F800 GS 2009
Old 11-20-2013, 06:09 AM   #43
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,262
Google "Time Zones" mon petit idiot.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 11-20-2013, 08:10 AM   #44
jengel451
Oddometer: 802
The dremel is an option. I was looking at mine a bit, it could possibly be used to get 80% there and still leave enough material to bond it back on.
Not prepared to try it on my own good one though. Someone have a jacked up one I could try on? a totally wrecked one could be used to experiment on too, just need a bit with the lens still glued to the housing.
Old 11-20-2013, 08:15 AM   #45
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
Mine is over. I will give it a try to see if it's doable. If not, I will buy a new one with a 35W hid kit
BMW F800 GS 2009
Times are GMT -7.   It's 03:41 AM.
