Old 11-20-2013, 04:19 PM   #46
JRWooden
Oddometer: 4,267
Originally Posted by Loutre View Post
You wrote that at 05:10 AM . Is that your Canadian version of full english breakfast?
Yeah... it was only a little after midnight I think .but still ... I knew Reaver would approve!
Old 12-04-2013, 08:08 PM   #47
ferntree
Oddometer: 10
Originally Posted by blksheep View Post
I cut my plug and wired mine to the hi beam wires so I can turn it off. There's just 2 wires each for the low and hi beam lights. The biggest deal is having to cut the frame bracket off to clear the light housing. This is with the baja designs light tho, I don't know if you have to do that with the trail tech light.
baja designs makes good stuff. see lots of them down in mexico.
also. people though LED's were the wave of the future. But then the trophy trucks were outrunning them. So now LED are more of the low beam floods and HID's are still high beam spot lights. So if you were to use a single projector with HID, better to use it for high beam and run LED for low beam.
ferntree screwed with this post 12-04-2013 at 08:22 PM
ferntree is offline   Reply With Quote
Old 07-02-2014, 09:59 PM   #48
Hamish71
Hamish71's Avatar
Oddometer: 409
bringing this one back from the dead....
I understand a single light is obstructed by the head stem mounts....but is it possible to mount say two BD Designs Squadron lights...one in place of each current light, and not cut the frame?
Now: 13 F800GS, Kalamata Olive, with all the fruit!
Previous: 08 F800GS, 09 KTM 300EXC, 05 KTM 450EXC
Hamish71 is offline   Reply With Quote
Old 07-03-2014, 06:51 AM   #49
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
Maybe by putting them in front of the original frame (not inside as it's originally designed). I'm considering that option too
BMW F800 GS 2009
Ckeck out my ride reports
Air0ne is offline   Reply With Quote
Old 04-01-2015, 10:14 AM   #50
bmwroadsterca
RadioFlyer
Oddometer: 165
Headlight Connector?
I am assembling the parts I need to replace the stock headlight assembly (with a melted reflector and fogged lens) with something I'll put together using Hella 90mm high and low beam halogen projectors. I would rather not butcher the stock connector on the bike's harness. Has anyone managed to identify this connector and/or find a compatible plug. I have Googled this to death without luck.
mike
bmwroadsterca is offline   Reply With Quote
Old 04-01-2015, 08:18 PM   #51
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,197
If your old headlight is junk, take the wiring out of it from the plastic side. Use that connector, it unplugs from the inside. Save the glass lens if it's good.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is online now   Reply With Quote
Old 04-02-2015, 05:04 AM   #52
bmwroadsterca
RadioFlyer
Oddometer: 165
Thanks Reaver. That's Plan B.
Mike
Old 04-02-2015, 06:09 AM   #53
ebrabaek
Oddometer: 4,763
When I build the new headlight unit, from Led high, and Hella 50mm HID low, I just bought little pins at Radio shack. They fit perfectly into the stock connector. I then used electrical tape just as you use wood on the exterior of a concrete slab, and filled the void with silicone. I now had a waterproof connector. Ran it like that til I sold the bike, with no issues.
Erling
Old 04-02-2015, 06:20 AM   #54
bmwroadsterca
RadioFlyer
Oddometer: 165
Thanks Erling. That's Plan C. I was hoping that the pin spacing coincides with some standard perfboard so I could similarly mount male contacts on the board and then encapsulate the back side in a similar manner.
mike
Old 04-02-2015, 06:33 AM   #55
ebrabaek
Oddometer: 4,763
mike
Yeppers Mike.
I was looking for a bit as well, but gave up, and went with plan C.....
Erling
Times are GMT -7.   It's 09:34 AM.
