Old 02-19-2013, 03:25 AM   #31
EasyJet_RC
Joyrider
Oddometer: 48
No probs,
I attached the filter to the factory line going to the injectors, added a new piece of 6mm fuel line to the tank (about 40 cm length). This was threaded between the shock & the tank, cable tied to the rigid lines (brake??? Oil return??... Not sure & will have to check) and turned up towards the" nose of the tank... The filter is nestled on top of the nose of the tank just under the injectors....
Apart from a bit of black fuel line that is visible if you know where to look you won't even know its there... & all newly components were routed and secure away from heat sources... For obvious reasons...
Ill try to get some pics as soon as I have a minute...
EasyJet_RC is offline   Reply With Quote
Times are GMT -7.   It's 06:04 PM.
