01-12-2013, 11:51 AM
#16 |
Carbon-based bipedal
Oddometer: 2,028
other thing to consider it reducing your chances of a puncture. you can get either heavy duty or ultra heavy duty tubes. the latter weigh a fair bit but it takes a lot to hole them.
plus they are so bulky it's like having about 7psi and at least with the front you can still ride home if you take it easy and the bead remains unbroken.. |
01-12-2013, 12:00 PM
#17 |
Ex: RideWithMe
Oddometer: 484
I carry the spares and tools, and there's a carton for whoever changes the tube for me.
I couldn't even change my pushy tube without putting a whole in it as a kid.
― George Carlin - “Never argue with an idiot. They will only bring you down to their level and then beat you with experience.” 2013 KTM 690 Enduro R ![]() Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY |
01-12-2013, 12:25 PM
#18 |
Oddometer: 143
I've always carried levers, patches and a front tube for the last 15+ yrs in the bush, but running UHD bridgstone tubes, have never needed them.
Rode the DR home about 70 klms on a flat front once as I didn't think I'd need the bumbag.... Two things that worry me about a flat on the DR are: 1) Breaking the bead on the rear wheel - do most of you blokes carry some sort of bead breaking tool ? 2) Inflating the repair - I only carry a mountain bike hand pump which I doubt will set the bead after a repair. On the enduro bikes, with MX knobbies, it seats itself after a few klms - not sure if the DOT type tyres will do that ? The compact electric pumps, like pictured earlier, would be ideal but how bulky are they and what sort of a drain do they put on the battery. The car type ones can pull a few amps.
'08 DR650 |
01-12-2013, 12:39 PM
#19 |
Oddometer: 93
1. easiest way if you're with another bike is to use their sidestand to break the bead. works a treat
2. after using a hand pump i tend to find the bead will seat itself once you get up some speed Start the bike up and let it idle while you use an electric pump. The DR650's stator is running at full output at idle The below link helped me a lot http://www.ktm950.info/how/Tire%20Sh...re_change.html felixblack1 screwed with this post 01-12-2013 at 12:46 PM |
01-12-2013, 12:50 PM
#20 | |
Oddometer: 143
'08 DR650 |
01-12-2013, 02:04 PM
#21 |
Retired
Oddometer: 319
Most standard tool boxes on bikes won't take much more than the standard tool kit. So you'll need to find somewhere to store the tyre levers at least, usually some hose clamps around them and some bit of the frame that you can get too does the job.
The 'safety' bead on rims is a problem. Some remove it entirely, there was a posting on it here some years ago. IIRC they used a router. An alternative is to remove a section of it, you only need to get it started so a section opposite the valve stem may be the less work and safer? |
01-12-2013, 02:55 PM
#22 |
Oddometer: 18
I pulled the wheel off the Klr last night and had a go at changing the tube ( first attempt)
I got the tyre off Ok and replaced the tube but it looks like I have pinched the new tube with the levers while getting the tyre back on. Any tips for avoiding that ? The tyre had a Horseshoe nail in it....... |
01-12-2013, 02:59 PM
#23 |
(KTM quack)
Oddometer: 1,579
Fit rimlocks so you can decide if you should fix the flat now or when it stops snowing. ( also reduces the risk of the tyre peeling off when you get a blowout at speed)
A couple of years ago a mate rode all the way down mt hotham with a flat front rather than fix it on a cold wet night. I'n not recomending it, but nobody was complaining at the time! Don't expect the tube to survive if you ride with a flat, but everyone carries a spare tube on our rides. It's rocky around here so we get used to fixing flats. I've timed one of the better guys at 3 1/2 mins on someone elses bike ![]() Incidentally, when you're working out how to fit tyre levers to the bike , have a think about fitting a spare clutch lever. Steep rocky country is a bitch without a clutch. Tips to reduce pinched: semi inflate the tube before starting, take small bites with each lever and do a little wiggle after inserting it to be sure no tube pinched |
01-12-2013, 03:07 PM
#24 |
Oddometer: 1,383
Before a ride:
As Philth says do your own tyre changes at home for practice. Fit Ultra Heavy Duty tubes. Put a heap of baby powder in the tyre to help stop pinch flats and chaffing. What I carry: Spare front tube in a tube bag on the front guard (as mentioned does the rear to get you out of trouble) On a big ride or multi day ride I'll take 2 fronts and a rear. ![]() Left to right: C02 bottles and adapter, big patches and patch glue - not for the tube but to use as a gator in case of a split tyre (or cut a piece from the removed tube and use). The red things are 'bead buddies' to hold the bead down one side while you work the levers the other. Tyre levers - I prefer the ones with 'pointy' ends like these Ballards ones. I cut the crappy wheel spanners you get with the bike and welded to the levers. A pump in case I run out of C02's. Lastly, this thingo is brilliant, you can prop your bike up under the footpeg while you fix the tyre. It's not stable enough to use while you're removing the rear wheel but it saves your mate standing there balancing your bike, when he could be fixing the tyre for you . Probably could just use a branch but what if you're on the Nullabour and there's no trees? ![]() ![]() The thingo in action - Thanks to Backonthebike for sourcing these for us. ![]() For the front, prop it up against a tree, fence or old sign while your mate stands there with a dumb look on his face
Jesus loves me, but everyone else thinks I'm a prick "The only true wilderness is between a Greenies ears" Quorn Schnitzel Club (junior member)kipo screwed with this post 01-12-2013 at 03:51 PM |
01-12-2013, 03:35 PM
#25 |
Oddometer: 143
Hi Kipo,
I made a 'thingo' too. Mines a little different as it uses a peice if all thread that you cand wind up by hand, but the same priciple applies. If you drill a small hole in the front area of the bash plate, you can poke the end of your lifter into it to lift the front wheel too !
'08 DR650 |
01-12-2013, 03:38 PM
#26 | |
Oddometer: 1,383
Cheers
Jesus loves me, but everyone else thinks I'm a prick "The only true wilderness is between a Greenies ears" Quorn Schnitzel Club (junior member) |
01-12-2013, 03:41 PM
#27 |
Life Behind Bars
Oddometer: 1,134
Good advice from everyone. I'd be embarrassed to call the RACQ to come fix a tyre for me. Problem with carrying all the gear is that you end up donating it all to your mates who are too slack to carry it (or know you always do!)
01-12-2013, 03:47 PM
#28 | |
Oddometer: 1,383
01-12-2013, 04:24 PM
#29 |
Oddometer: 562
Ha ha! Same price for mine!
Work to live, Live to Ride! |
01-12-2013, 04:26 PM
#30 |
Oddometer: 990
I have always carried two tubes and all the gear andd can change tyres with out too much drama.
. On my last ride I got a flat, I stared at the tire and went, frig it, I can't be buggered doing this in the bush. I'd rather fix it at camp so I can have a coffee first. So I rode some 25 odd K's through the bush and then 10 down the bitumen on the flat. Brand spanking new Geomax too. When I got to camp I spotted an expresso van and while I was getting my coffee spotted a bloke changing tyres for $20 a pop. So I sat in a comfy chair sipping my flat white watching my tube get changed for $20 plus tube. Total gold, The geomax held up well too. So this got me thinking, if someone got a coffee van and put a tyre changing machine in it and went 'On call' they'd make a killing.
