Old 01-12-2013, 03:39 AM   #1
josjor OP
Location: The largest geological formation in the U.S.A.
Oddometer: 2,876
iPad 10w charger to other USB devices
Boy, I typed this question into google and spent 20 minutes reading arguments that started to range into 240v 3 phase instead of getting an answers.
Taking a trip and packing along iPad, Sansa mp3 player, and Motorola phone. Rather than having 3 wall warts in my bag, I thought I'd just take the iPad 10w charger and the USB -- device cables. Any issue with this?
I'm not a techno-geek so I don't know if the USB jack on the apple charger is wired like every USB jack. I'd do a test but I didn't want to fry my non-apple devices just days before the trip.
To avoid this, I figured one of you FF geniuses had tried the same and either had success or let out the magic smoke, allowing me to learn from your success/failure.
Neutiquam erro.
Originally Posted by Stagehand View Post
listen mister, we didnt evolve porcelin shitters just so we could squat to take a shit, like monkeys.
josjor is offline   Reply With Quote
Old 01-12-2013, 05:47 AM   #2
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,489
Short answer - you will be fine. USB is a standard.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 01-12-2013, 06:05 AM   #3
ktm360mx
ktm360mx's Avatar
Oddometer: 223
no problem
No problem- I travel all the time and refuse to have 3 chargers. I use a 2amp charger for everything.
ktm360mx is offline   Reply With Quote
Old 01-12-2013, 06:34 AM   #4
KLR04
Oddometer: 183
AS RomaDakota says, USB is standard, all devices run on +5VDC, the power supply may have different amperage capacity depending on generation of USB, and on application, some power sources are capable of up to 5000 mA (milliAmperes), that is 5 A, or 25 Watts.
See http://en.wikipedia.org/wiki/Universal_Serial_Bus for details
KLR04 is offline   Reply With Quote
Old 01-12-2013, 08:15 AM   #5
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,112
You'll be fine.
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 01-12-2013, 10:11 AM   #6
smoky
smoky's Avatar
Oddometer: 313
Except it won't charge my Sony Book reader.
Damn Sony and their proprietary shit!
smoky is offline   Reply With Quote
Old 01-13-2013, 11:49 AM   #7
cbolling
Here...Hold my Beer.
cbolling's Avatar
Oddometer: 3,122
I use my ipad charger to charge my ipad, 5 iphones, 4 kindle fires, an ipad mini, a Nexus 7, and a Galaxy S3 with no problems at all.
2012 Suzuki Burgman 400
cbolling is offline   Reply With Quote
Old 01-13-2013, 06:39 PM   #8
broncobowsher
broncobowsher's Avatar
Oddometer: 1,721
USB power sources will not hurt USB devices. There might be a power issue, too small of a charger won't charge high power charging systems, in that case it just suts down. I have one charger that can't take high power stuff, it was a car charger. It has been tossed. I plug any device into any charger I have handy. Camera, phone, iWhatever, don't care, just plug it in and it all charges just fine.
broncobowsher is offline   Reply With Quote
Old 01-13-2013, 07:46 PM   #9
NikonsAndVStroms
Beastly Photographer
NikonsAndVStroms's Avatar
Oddometer: 40,499
Yup, it being 2A is the key. Just for future reference for the OP makes sure you always have the iPad wall charger. 2A for the other 2 is fine (though they might get hot from the extra juice) but a 1A wont charge the iPad.
Motorcycles save lives
"It's the game of life. Do I win or do I lose? One day they're gonna shut the game down. I gotta have as much fun and go around the board as many times as I can before it's my turn to leave."
NikonsAndVStroms is offline   Reply With Quote
Old 01-14-2013, 06:01 AM   #10
inyang
5secs away
inyang's Avatar
Oddometer: 414
1A or even less will charge the iPad, just slowly. It may not show charging on the display. It would not (likely) start up a fully discharged iPad though.
If you are stuck with a low power charger (less than 2A), it should charge faster if you plug it in to charge AND then switch off the iPad. Just avoid draining the iPad battery to zero.
'11 - 690R
inyang is offline   Reply With Quote
Old 01-14-2013, 08:31 AM   #11
Sailorlite
Oddometer: 398
Evidently the Apple Stores are now offering a 12 watt charger that looks like the 10 watt version (white block). I suppose this is charges a little faster. I think the white cable that comes with the 10 watt charger is not included with the 12 watt version.
'14 R1200GS
Priors: '13 K1600GT, '08 R1200RT, '04 R1150RT, '05 R1200GS, '73 R75/5.
Sailorlite is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 01:53 PM.
