Old 01-12-2013, 08:51 AM   #1
moto_psycho OP
Nob.
moto_psycho's Avatar
Oddometer: 122
Eh? 640 enduro 2004 rebound clicker... and grease nipple
... on the rear shock..... am I being stupid, I just can't find it? Anyone care to post a pic?
Also, anyone know what thread the grease nipple is? I need to put a 45 in.
moto_psycho is offline   Reply With Quote
Old 01-12-2013, 09:15 AM   #2
Hockeygod
Hockeygod's Avatar
Oddometer: 740
Grease nipple
My grease nipple is at the bottom front of the rear shock. It might have a black cap over it... Mine doesn't. Sorry no pics. Check your manual as it should show it.
2007 KTM 640 Adventure
2001 KX 100
1989 KDX 200
Various mountain and road bikes
No his mind is not for rent
To any god or government
Always hopeful, yet discontent
He knows changes aren't permanent
But change is...
Hockeygod is offline   Reply With Quote
Old 01-12-2013, 11:15 AM   #3
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,398
Look at the bottom of your shock.There should be a round adjustment knob there.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 01-12-2013, 01:34 PM   #4
moto_psycho OP
Nob.
Oddometer: 122
You mean the very bottom? I've looked at shocks on eBay and can't see it either
Old 01-12-2013, 01:42 PM   #5
moto_psycho OP
Nob.
Oddometer: 122
j
cant see it on the fiche either....
Old 01-12-2013, 01:47 PM   #6
moto_psycho OP
Nob.
Oddometer: 122
Is it the grey bit below the spring?
Old 01-12-2013, 02:11 PM   #7
Droptarotter
Oddometer: 1,254
Yes!
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Old 01-12-2013, 03:24 PM   #8
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,398
It has the little grooves in it so you can grip it and turn it.
If you visualize looking up as if you were laying under the bike, turning it clockwise closes it and stiffens rebound resisting the spring from returning the bike up from compression.
If you turn it counterclockwise you are opening it or softening the resistance to the spring to return the bike up from compression.
2001 GAS GAS 321
IBA # 23,716
Old 01-13-2013, 12:16 AM   #9
bmwktmbill
Traveler
Oddometer: 5,147
Rebound on the bottom, compression on the top, the nipple is on the pivot, not the shock, sometimes takes grease hard, warm it GENTLY with a heat gun, hair dryer....
The book settings for suspension are nonsense.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 01-13-2013, 01:29 AM   #10
moto_psycho OP
Nob.
Oddometer: 122
Finally figured it out last night! Never seen one like that before haha!
Is there a thread anywhere with recommended settings?
Old 01-13-2013, 04:27 AM   #11
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,398
Count the clicks or turns and set it in the middle.
Then ride the bike and start adjusting harder or softer till its how you want it.
If you can't get it where you want it, then it needs to be revalved internally.
Before anything though make sure your spring preload is correct by checking your sag numbers.
2001 GAS GAS 321
IBA # 23,716
Old 01-13-2013, 09:13 PM   #12
bmwktmbill
Traveler
Oddometer: 5,147
It's stealthy.
The only way I can adjust it is to lay on my back on the ground and look up at it(when it's on the mc.
As for setting the sag, another PIA to do with the shock on the machine.
Easier to remove it, the axle wrench has a spanner built in for the spring adjuster collar.
b
Bill Shockley
Times are GMT -7.   It's 07:46 PM.
