Old 01-12-2013, 12:48 PM   #1
booniebasher OP
booniebasher's Avatar
Oddometer: 212
should i spring my dualsport loaded up ?
hello
I have a xr600 in which its only purpose will be loaded up with giantloop bag and 5 gallon gas tank etc . I can tell it is not sprung even before i put the load on it. although I dont plan on hitting the big whoops and g outs on a regular basis should i spend the 250.00 or not ?
booniebasher is offline   Reply With Quote
Old 01-12-2013, 12:59 PM   #2
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 1,306
I know it made a huge diffrence in my DR. I'm a light 220 plus adding 70lbs with saddle bags and such made it miserable to ride with stock springs. I got a spring (8.3 if I remember correctly) for the rear shock. Unloaded I have the preload backed off and when I load it down I turn the preload up. Makes the bike feel more "solid" in the loose gravel and such.
Mongle is offline   Reply With Quote
Old 01-12-2013, 02:13 PM   #3
Droptarotter
Oddometer: 832
If that's the way you normally ride it, then yes, set the preload and suspension settings for that.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Old 01-13-2013, 10:11 AM   #4
SportsGuy
icanhazdirt?
Oddometer: 396
Getting the spring right for your load and riding purpose is always money wisely spent! Its a safety issue, a ride comfort issue and a reliability issue.
I'd say yes, its worth the money. Just be sure its not just a strong spring, but that th erest of the shock is built to control that stiffer spring, too.
My Stuff: Jeep News l Online Marketing News
...and my dogs are cooler than your dogs!
SportsGuy is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
