01-12-2013, 10:26 PM
#1 |
Oddometer: 87
Wiring help needed (1977 R100RS)
Hi All
before I ask my couple of questions I think I should give a little bit of history of my project and how I arrived at the problems I have today I bought this 1977 R100RS off a bloke in my local pub, he had stopped riding it when it started making a loud rattling noise and after a quick tear down (he pulled the cylinders off) he had decided "its just f#$@ed mate" he was right, for anyone who cares here is the vin plate ![]() and after a full tear down the cause of the loud noise was immediately evident ![]() Yep thats the two pieces of crankshaft seeing as we have all seen plenty of photos of these being rebuilt I will go straight to what it looks like today ![]() so that brings me to my questions, I need to hook up the wires to the back of the ignition key but need to know what goes where, the terminals on the back of the key look like this ![]() they are numbered 30 , 15 , 56 and 58 and i have four wires to connect to them ![]() two green a red and a grey one in the front of the headlight bucket can anyone help with some advise on what goes where ? next up is a similar question for the alternator , every picture i have seen shows the three wires in a large plug but i have them all seperate can anyone please advise what colours go onto what pin ![]() any help with these two questions would be greatly appreciated as I am at a bit of a standstill until I get these hooked up WANDERING KTM screwed with this post 01-12-2013 at 10:57 PM Reason: making photos work |
01-13-2013, 02:28 AM
#2 |
Old guy
Oddometer: 1,362
![]() This might help
"What could possibly go wrong? " The Jerk2012 TE 250 2010 F 650 GS 1983 R 80 G/S |
01-13-2013, 04:59 AM
#3 |
Airhead Traveller
Location: Ångermanland, Skåne, Sweden, or on the Seven Seas
Oddometer: 65
This is a pic from my '79 100RT, but these wires for the charging should be the same I think.
![]() For the ignition switch it should be: Red wire goes on no. 30, live all the time. Grey one goes on no. 58 for the parking light. One green goes on no. 15 and should also connect to no. 15 on the connection block at he upper fuse. For ignition and starter button, some measuring may be needed here if it's not possible to see wich wire it is. The other green should go on no. 56 for the lights. But this one you might have to test your way, may depend on what switch you have on the handlebar. If it is ligths on always when ignition is on. Well, hope it is of some help.
SvenSenior Airhead Mechanic '79 R 100 RT Smurfen screwed with this post 01-13-2013 at 05:22 AM |
01-13-2013, 05:04 AM
#4 |
Oddometer: 87
Excellent ! Thanks guys that will give me somewhere to start tomorrow
The wiring diagram is slightly different to what I have but I should be able to work something out Thanks again |
01-13-2013, 05:05 AM
#5 |
Oddometer: 1,465
The red wire attaches to one of the center terminals. The grey goes on 58. The green goes on 15. The second green goes on 56.
01-13-2013, 11:49 AM
#6 |
Oddometer: 454
The three wires to the three pin connector, on the alternator, can be connected in any combination......IT DOES NOT MATTER.
Good Luck.
spo 1973 slash 5 toaster |
