Old 01-13-2013, 07:55 AM   #1
buzybraza OP
buzybraza's Avatar
Oddometer: 380
Badly assembled at factory or failure?
So my 950 SE developed a coolant leak after 7k miles. This is what I found :
What do you guys think? Badly assembled at the factory or something else?
I think it is a very obvious assembly mistake by whoever did it at the factory. I am amazed it took 7k miles for the thing to actually start leaking!
It was impossible to see the problem because of the location of the hose. I was only able to see the problem after disassembly.
This is me inside the v of the motor pointing at the back of the forward cylinder:
and here is the "smoking gun"
buzybraza screwed with this post 01-31-2013 at 08:23 AM
buzybraza is offline   Reply With Quote
Old 01-13-2013, 11:51 AM   #2
NKL
Oddometer: 196
Badly installed.
NKL is offline   Reply With Quote
Old 01-13-2013, 02:06 PM   #3
SauceSquatch
SauceSquatch's Avatar
Oddometer: 283
Originally Posted by NKL View Post
Badly installed.
+1
IMO bad install, but I'm no expert.
2010 KTM 990 Adventure
2006 DRZ
1978 Harley FX cut down
SauceSquatch is offline   Reply With Quote
Old 12-16-2013, 11:33 AM   #4
buzybraza OP
buzybraza's Avatar
Oddometer: 380
samco
So I ended up with samco silicone hoses and I used the clamps that came with the kit. Pretty cool stuff. I like it!
I am running evans racing coolant in it too. Never had overheating problems but I like the idea of running the cooling system with less pressure than it was designed for....
buzybraza screwed with this post 12-22-2013 at 11:09 PM
Old 12-16-2013, 03:30 PM   #5
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 996
hose's
Those look real good
dogsslober is online now   Reply With Quote
Old 12-16-2013, 03:44 PM   #6
GrenDesb
Oddometer: 329
Had something similar on my previous bike.
Not a hose but a small diaphragm in one of the carbs. It's the fuel shut off valve that prevent gas to be sucked in by the engine vaccum on decel.
Bike was burping and popping on decel and even a little on steady no load throttle cruising on the highway.
GrenDesb is offline   Reply With Quote
Old 12-16-2013, 06:35 PM   #7
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 576
Very nice hoses thanks. Now on my list. Fit and forget for around £100.
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 12-16-2013, 09:44 PM   #8
ericGSsti
ericGSsti's Avatar
Oddometer: 570
I take it the Evans your talkin about is the waterless coolent. How is it going for you. I am toying with the idea myself for my 950 adventure.
2004 KTM 450 exc, 04 KTM 950 Adventure S.
ericGSsti is offline   Reply With Quote
Old 12-17-2013, 04:43 AM   #9
smitty141
smitty141's Avatar
Oddometer: 647
I had a coolant hose at the plastic "Y" on the left side start leaking at 8000 miles. I removed the factory clamp and added a worm gear style replacement. I like the look of your hose. And will change mine sometime over the winter. Even after replacing the clamp, the hose felt squishy.
Smitty
RIP.. Skinny Dave...RIP.. Chester_______________
2015 KTM 690r Enduro, 2010 BMW 800gs. 2008 Suzuki DRZ400SM, 2004 KTM 450 EXC
smitty141 is offline   Reply With Quote
Old 12-17-2013, 10:15 AM   #10
buzybraza OP
buzybraza's Avatar
Oddometer: 380
evans waterless coolant
It is going well. I run evans "motorsport coolant" both on my 2007 525 EXC and my 2008 950SE. I don't think I will ever go back to using regular coolants with water...
In my opinion there are other benefits as well as down sides, but the fact that evans runs with a lot less pressure is mainly what sold me... I am not 100% sure about these numbers, but from what I can remember the bikes will run with about 20 psi in the cooling system with regular coolants against about 5 psi with evans waterless....
Old 12-17-2013, 05:31 PM   #11
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,665
Air cut valve on the 950. There's a jet under the velocity stacks, too.
unaweep is online now   Reply With Quote
Old 12-17-2013, 10:29 PM   #12
Sumi
Sumi's Avatar
Oddometer: 1,813
I have the same issue on my bike.. Is it possible to only buy this diaphragm, or do I need the complete rebuild kit?
Times are GMT -7.   It's 07:36 PM.
