Old 09-23-2013, 03:59 PM   #16
JR356
JR356's Avatar
Oddometer: 3,990
From the website:
"What are the PC requirements?
The minimum PC requirements are a Desktop or Laptop with WinXP Service Pack 2, 32 bit version (64 bit version supported as of Beta 903.6), 512MB RAM, 50MB open harddrive space and of course an open USB port. If you're running Windows Vista, 32 bit version (64 bit version supported as of Beta 903.6), a minimum of 1024MB RAM and 50MB of open harddrive space is required."
Website does not comment on Windows 7,8
My experience is on XP and Vsta.
Have it loaded on a newer 7 laptop and can open it to the different pages,but have not yet tried it connected to bike,if I get a chance,will report on results soon.
Just get a cheap XP or Vista laptop
JR356
JR356 is offline   Reply With Quote
Old 09-23-2013, 03:59 PM   #17
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,870
Originally Posted by VEGASGSA View Post
Dumb question..but trying to get my 911 on line...
I'm all MAC here..so need to pick something up to run this on..
In looking at there site..Do I need something running XP or Vista?? Or does it run on 7..8?
I was kinda thinking of picking up a Surface..having a lightweight 'pooter to take with..etc..
Then too..is a surface a pile? ?? Should I just grab a refurb Acer with XP on it....??
Thanks in advance...
I can't help with the Mac specific stuff, but it will run any windows from XP to 8.
Jim
Old 09-23-2013, 04:24 PM   #18
200GRLSWC
Oddometer: 107
I'm an all Mac household, as well, but I have VMWare Fusion and Windows XP loaded on my MacBookPro as an alternative setup (actually, now several series of MacBookPros).
GS911 runs in the XP environment fine on the MacBookPro. Same with the BMW RepRom, by the way. Same with my Scala Cardo headset software, also by the way. :-)
If you're a long-term GS owner and do your own wrenching it's hard to see how one would do without a GS911. I love mine.
Now if only I could get a good throttle body balancing set up, without having to have several tens of feet of rubber hose hanging in my garage. (And, no, I'm not going the TwinMax route again.)
200GRLSWC is offline   Reply With Quote
Old 09-23-2013, 05:09 PM   #19
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
Perfect..thanks guys..When I looked at 911's site..it kinda read like it wanted an older version of Windows..
My MAC is a Desktop..so..not so easy to bring with..
And it won't work on thewifes iPad..and she won't let me have her Mac Pro...
So..if I need to get something anyway..I was thinking about using a Surface..
Beers and Bacon all around..
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 09-23-2013, 05:57 PM   #20
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,035
Surface Pro - RT isn't windows 8 like the full version is.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 09-23-2013, 06:31 PM   #21
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
I wondered about that...
Old 09-23-2013, 07:25 PM   #22
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,296
+1, I had a surface rt. It won't work.
You could consider a samsung galaxy android phone. I have used one and it does most things, including logging to file.
roger 04 rt is offline   Reply With Quote
Old 09-23-2013, 07:31 PM   #23
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
Hmmm..I tried my LG it won't log on to download...I'll prolly just grab a refurbished XP lap top.....
Old 09-23-2013, 09:54 PM   #24
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,572
I wish I could find a source for mercury for a manometer...oil is messy and not as well damped.
def is offline   Reply With Quote
Old 09-23-2013, 10:56 PM   #25
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
And not nearly as fun to play with when you spill it all over..
Old 09-24-2013, 03:23 AM   #26
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,068
You want more damping? Try 90 weight gear oil or put a restrictor in line to dampen it down. A small brass plug with a 1/16" drilled hole will do the trick.
Personally I use ATF and it works fine, very sensitive.
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 09-24-2013, 03:27 AM   #27
200GRLSWC
Oddometer: 107
I just used water and food coloring in my set-up, worked fine for my '08 GSA. Set it up as a dual (of course) water column from floor to ceiling in garage, with enough spare tubing to run from ceiling back down to engine, with water level about mid-way to ceiling. Never had more than a foot of movement, quickly settled down to a few inches.
It works fine, precise enough to get a good balance, just a pain in the ass to set up. And, of course, can't do it under load, if that's important to you.
Also, the colored water will stain whatever it is spilled on, takes a long time for the color to fade even from a driveway. DAMHIK.
Old 09-24-2013, 03:37 AM   #28
teomannaskali
teomannaskali's Avatar
Oddometer: 784
If you tubes are clear and have high enough diameter, you could put a small floating ball in there. Like a "ball" of styrofoam or bb pellet type of thingie.
Good illumination will also help.
teomannaskali is offline   Reply With Quote
Old 09-24-2013, 04:22 AM   #29
Pukmeister
Oddometer: 28
I use a Harmonizer, bought on this site. The best throttle balance tool there is.
Pukmeister is offline   Reply With Quote
Old 09-24-2013, 07:06 AM   #30
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
+1 ATF works well..
Times are GMT -7.   It's 01:40 AM.
