Old 09-04-2014, 08:24 PM   #1
c4nuck OP
c4nuck's Avatar
Oddometer: 226
Sidestand spin?
With a 1 car garage, the 10 point turn to get my bike turned around is getting a little old. Looked at a couple of the turntable style gizmos, but would rather not have to put it up on centre stand every time, or, more importantly, drop farkle cash on a fancy disc.
I've done it with sport bikes and lighter MX bikes, not sure if its wise to rotate these bikes with all the weight on the stand.
what I'm talking about: http://www.youtube.com/watch?v=CGcldkQmzw0
What say ye?
BMW F800GS, KTM 200EXC, Backseat of a Crown Vic
IBA #59085
BC-->TX-->Carribean
c4nuck is offline   Reply With Quote
Old 09-04-2014, 08:27 PM   #2
Fudge
Fudge's Avatar
Oddometer: 40
This would be a good solution. I have one and it makes garage maneuvers very easy.
http://www.ridermagazine.com/gear/ha...ly-review.htm/
Fudge is online now   Reply With Quote
Old 09-04-2014, 08:47 PM   #3
thomps000
Oddometer: 40
My neighbor did it to my bike and I originally thought he was dropping it. He did it on blacktop and it left a nice hole in the ground. I wouldn't be spinning mine on the stand, but the video seemed like it's easy enough.
I'll stick to my 10 point turns...but my father has one of the Park N Ride dolly stands. It's nice and moves his K1600, but kind of expensive for what it is at $200+
thomps000 screwed with this post 09-04-2014 at 09:12 PM
thomps000 is offline   Reply With Quote
Old 09-04-2014, 08:55 PM   #4
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,321
1 46 53 8 522 368 side stand $138.01
02 46 53 8 528 633 supporting bracket f side stand $205.90
03 46 53 7 679 105 collar bush 2 $11.45
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 09-04-2014, 08:58 PM   #5
9.5isCanadian
9.5isCanadian's Avatar
Oddometer: 66
I too have a skinny crowded garage.
I've been doing the side stand spin for years.
My current ride is a portly Triumph Scrambler and have zero ish doing the spin.
Peace out
O'
Sent from my iPad using Tapatalk HD
9.5isCanadian screwed with this post 09-05-2014 at 09:17 AM
9.5isCanadian is offline   Reply With Quote
Old 09-05-2014, 07:18 AM   #6
c4nuck OP
c4nuck's Avatar
Oddometer: 226
So i can build a spinner with those part numbers Reaver?
Fudge - Yeah I looked at those HF trays a couple times store, they look like they would buckle or just stop rolling at one point. I guess since its cheaper than the others I'll give it a go.
IBA #59085
BC-->TX-->Carribean
Old 09-05-2014, 07:51 AM   #7
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,458
The side stand should handle the weight and stress, but that's not saying it will. I've had to replace the pivot bolt twice on my '09, the weak link. I've had to have the side stand shaft re-bent after the loaded bike slid backwards down a hill in neutral while on the side stand (without me on it). Therefore, I'm not real excited about spinning my F800GS.
Fred
FredRydr is offline   Reply With Quote
Old 09-05-2014, 08:23 AM   #8
Pangit
Oddometer: 114
Whats the problem bringing the bike out backwards?
Pangit is offline   Reply With Quote
Old 09-05-2014, 09:16 AM   #9
9.5isCanadian
Oddometer: 66
In my case, its an uphill gravel driveway. Right at the garage door. My wide in the hips Scrambler isn't so much fun pushing never mind backwards up hill.
O'
Old 09-05-2014, 10:12 AM   #10
c4nuck OP
c4nuck's Avatar
Oddometer: 226
In my case, its a townhouse garage, right on the corner, backing out on a blind corner with people flying by = close calls.
IF I'm going to get by a car, I'd rather it be while riding, not backing out of my garage....
IBA #59085
BC-->TX-->Carribean
Old 09-05-2014, 10:33 AM   #11
Wicket009
Wicket009's Avatar
Oddometer: 129
Took the PSSOR clinic at the recent Altrider Hoh Rally. Brett showed us the side stand spin on a tight uphill. Never thought of using the technique with larger bikes, but was a great way to get out of a bind. I ended up using it on the route home when exploring a trail that died out. The fully loaded 800 spins with little effort in the dirt. I agree with Fred that I would not use it daily in the garage.
2010 F800GS
2007 F650GS
1998 K1200RS
Wicket009 is offline   Reply With Quote
Old 09-05-2014, 07:20 PM   #12
Pangit
Oddometer: 114
OK would this help:-
http://www.youtube.com/watch?v=fJl92...layer_embedded
http://www.bursigusa.com/
Old 09-05-2014, 07:42 PM   #13
thomps000
Oddometer: 40
This is the one my father in law uses.
If the bike has a center stand, it's a great option.
http://www.legalspeeding.com/products.htm#.VApmUGRdWNs
Old 09-05-2014, 09:39 PM   #14
c4nuck OP
c4nuck's Avatar
Oddometer: 226
Damn Pangit, thats fancy stuff there.
thomps000 - does he use it on a f8? I've heard that the configuration of our centre stands, mostly the foot part, interferes with the park n move. I've email those guys but never heard back, figured it was a "no" from the lack of response.
I'm thinking a fancy disco ball with tethers to lift/spin the bike. dual sport bike, why not a dual purpose spinner?
IBA #59085
BC-->TX-->Carribean
Old 09-05-2014, 10:33 PM   #15
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,629
I throw mine on the center stand and spin it around that way, works great on smooth concrete garage floors but not on asphalt or rough surfaces.
AviatorTroy is offline   Reply With Quote
Times are GMT -7.   It's 06:16 PM.
