Old 01-14-2013, 08:09 AM   #1
timspong OP
timspong's Avatar
Oddometer: 220
Milky Oil, But very foggy this weekend
I just noticed that my oil is very milky today, however, it was very foggy all weekend so I am wondering if it is anything to worry about? I ride a new 2012 vstrom 650.
Cheers
Tim
timspong is offline   Reply With Quote
Old 01-14-2013, 08:16 AM   #2
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,262
If your bike is new, I would call the dealer now and let them tell you it's the fog. A little condensation inside the cases is normal, but probably not enough to make the oil look milky.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 01-14-2013, 08:18 AM   #3
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 5,041
If your oil is milky on a fairly new 2012, I'd get it to the dealer ASAP.
And, I don't think I would attempt to ride it to the dealer with milky oil.
Wasser is offline   Reply With Quote
Old 01-14-2013, 08:21 AM   #4
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,592
What's the situation?
You just walk out there and see milky oil in the sight glass, cold motor?
Is the bike warm? Did you start it and let it idle for 5 minutes and shut it down?
Is this after a long highway run or a hot motor?
How about posting a photo of the sight glass.
Boon Booni is online now   Reply With Quote
Old 01-14-2013, 09:27 AM   #5
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,264
Agreed, we need more details. Did you notice this after a series of short rides where the bike didn't get very warm? Was the bike sitting? Etc. I agree you might want to give the dealer a call...
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 01-14-2013, 09:50 AM   #6
yuu
yuu's Avatar
Oddometer: 122
This has been something that appears time and again on a Monster centric board I'm on. 99.9% of the time it's just condensed water vapor. Of course extra easy to point at that on the air cooled bikes.
Cool weather and short rides where the bike does not get up to temp for a significant period promote this milky appearance.
I'll recycle a little write up I did there - Here goes:
What the hell is that milky crap in my oil sight glass?! OMG is my bike going to blow up?
- Don't freak, you'll be fine (well you hope). That milky stuff is just moisture. Lots of short rides where the engine never really gets above 100 deg C can promote the appearance of this milky stuff. Lots of wet weather, cooler temps etc will also bring it on.
If you have an air cooled Monster, your worries are over as it's not a sign of anything bad happening with your bike. If you want to get rid of it, simply ride you bike until it's nice and hot, say 30min+. Then when you stop for gas/lunch/nose pick simply remove your oil filler plug for 30 seconds give or take. You'll probably see water vapor escape from the open filler port. Do this a few times and the milk should disappear.
IF you have a water cooled Monster follow the steps above - but also keep a close watch on the coolant levels in your over flow tank. Make sure to do any measuring under that same conditions - like bikes cold and parked the same way in the same spot, to prevent mis reads because of fluid expansion, tilt of the bike etc. If you coolant level is mysteriously going down, and you have a persisting milk issue, that's a good sign of a coolant leak and further investigation will be needed.
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-14-2013, 10:57 AM   #7
timspong OP
timspong's Avatar
Oddometer: 220
Cleared up after 45min ride
The bike had been under a cover outside all weekend and it was very foggy all day yesterday. Everything was wet everywhere just from the fog. I didn't notice anything until I got to work and put the bike on the centerstand and had a look at the window. It was completely white and so was the inside of the oil filler hole.
Anyhow I had to ride a few miles to the auto parts store to get oil but by the time I got there it had cleared up some. Then I took a chance and blasted it down one of my favorite roads for about 45mins and now the site glass is completely back to normal.
Cheers.
Tim
Old 01-14-2013, 11:01 AM   #8
yuu
yuu's Avatar
Oddometer: 122
I see you're another NoVA resident - this cool damp weather we've been getting can promote 'the fog' especially on an outside bike.
Old 01-14-2013, 12:15 PM   #9
1P8RIOT
1P8RIOT's Avatar
Oddometer: 388
Short trips in cold weather can cause this. Especially on air cooled bikes.
A ship in a port is safe but that is not what ships are built for. - Mom
'09 F800GS YEAH BABY!!!
1P8RIOT is offline   Reply With Quote
Old 01-20-2013, 09:35 AM   #10
timspong OP
timspong's Avatar
Oddometer: 220
Well just thought I would post this follow up. I went for a 175 mile ride yesterday through 4 states and it didn't clear it up. In fact the site glass became completely white and I couldn't see the oil at all. I changed the oil as a precaution and it was absolutely fine. Apparently, the condensation loves the site glass and builds up to a layer of white gunk. Following the advice of a Ducati mechanic, as Ducati's suffer from this, I just put a heat gun on low and heated the glass and it cleared it right up. Apparently, there is no regulator on the oil cooler so in cold weather the oil doesn't heat up enough to clear the condensation. I guess it's the same with the new v-strom.
Old 01-20-2013, 12:44 PM   #11
1greenmachine
Oddometer: 758
Have you looked to see if your losing coolant, if the oil got milkier the longer you rode then I'd lean towards coolant in the oil
1greenmachine is offline   Reply With Quote
Old 01-20-2013, 04:19 PM   #12
timspong OP
timspong's Avatar
Oddometer: 220
No loss of coolant, as I have been checking it daily. The oil was absolutely clear as it was also quite new when I changed it. It seems that the hot glass attracts the condensation in cold weather and goes white on contact with the oil.
Old 01-20-2013, 05:26 PM   #13
1greenmachine
Oddometer: 758
Okay just would hate to see something happen, I would figure that long of ride would got the oil hot enough to burn out the condensation.
Old 01-20-2013, 07:45 PM   #14
LuciferMutt
Oddometer: 11,264
Tape a piece of cardboard over half (or more) of the oil cooler for winter riding. Experiment, and only cover what is necessary to get the oil hot enough to burn off the vapor.
175 miles and 4 states? Sheesh -- ride 175 miles in the southwest, and you barely clear one county...
Old 01-20-2013, 08:09 PM   #15
timspong OP
timspong's Avatar
Oddometer: 220
Yea good idea. I hadn't thought of that. Thx
Times are GMT -7.   It's 07:39 PM.
