Old 01-21-2013, 06:12 AM   #16
timspong OP
timspong's Avatar
Oddometer: 220
Originally Posted by LuciferMutt View Post
Tape a piece of cardboard over half (or more) of the oil cooler for winter riding. Experiment, and only cover what is necessary to get the oil hot enough to burn off the vapor.
175 miles and 4 states? Sheesh -- ride 175 miles in the southwest, and you barely clear one county...
Guess what? there is no oil cooler on the 2012 vstrom. Basically the oil filter housing is water cooled so I guess it's back to the drawing board.
timspong is offline   Reply With Quote
Old 01-21-2013, 08:03 AM   #17
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,616
The oil cooler is integrated into the radiator.
Old 01-21-2013, 10:04 AM   #18
1greenmachine
Oddometer: 758
What's your coolant temp when riding? You could try blocking off part of the radiator and see if that helps with the milky oil, just keep a eye on the temp gauge.
1greenmachine is offline   Reply With Quote
Old 01-21-2013, 11:29 AM   #19
timspong OP
timspong's Avatar
Oddometer: 220
The coolant temperature is pretty well regulated as it is always 3 bars (? temp) no matter what the conditions are and I have ridden in the teens to over 110 degrees.
Times are GMT -7.   It's 09:55 PM.
