Old 01-14-2013, 09:45 AM   #1
FourG OP
Oddometer: 43
Question Alignment issue 1150 GS
Alright keyboard mechanics, I've got one for you.
Recently my 2000 1150 GS seems to have decided it doesn't want to ride on the straight and narrow any longer.
Symptoms:
  • Since I've owned the bike it's always wanted to stray right when I let off the bars... It was never an issue per say as I felt the bike had tracked straight with my hands on the bars.
  • (Recently) when riding the bike in a straight line on the highway I'm noticing I need to give it a little left bar input which makes the bike lean slightly to the left when trying to go straight.
Things I've tried (admittedly not a lot, yet)
  • I've eliminated the "crown in the road" theory by briefly riding on the opposite side with the same effect
  • Checked the haynes manual for any kind of alignment procedure. What they listed didn't seem too scientific so I haven't really tried it.
  • Loosened the fork clamps and tried to let it naturally find it's resting place, torqued them back up to spec
  • Checked the final drive for play
  • Checked tire pressure
  • Check the front tire for play
  • Checked if the spoked wheels are true
  • Visually inspected both wheels for any camber issues
  • Tried riding without the system cases
Other things to note:
  • Two brand new tourances mounted and balanced by me
  • I ride with the system cases almost 100% of the time, although I've tried riding without them and I have the same issue.
What should be my next steps? Anyone else ever encounter this issue?
FourG screwed with this post 01-14-2013 at 11:16 AM
FourG is offline   Reply With Quote
Old 01-14-2013, 10:21 AM   #2
Spaggy
Spaggy's Avatar
Oddometer: 955
Mine was doing that too. My windshield was cocked to one side a bit. Helped but still have a little pull with hands off.
Spaggy is online now   Reply With Quote
Old 01-14-2013, 10:38 AM   #3
FourG OP
Oddometer: 43
So your windshield was cocked enough to give you the illusion it was leaning? I've suspected a placebo effect like this... I think I might buy a cheap bubble level and attach it to the console to see what physics reports..
Old 01-14-2013, 10:43 AM   #4
M38A1
Type-A Introvert
M38A1's Avatar
Oddometer: 316
Crown in the road?
Riding in the same lane of travel for a tad bit more tire wear on one side combined with the crown?
M38A1 is offline   Reply With Quote
Old 01-14-2013, 10:51 AM   #5
FourG OP
Oddometer: 43
Originally Posted by M38A1 View Post
Crown in the road?
Yeah, I should have put that in the "things I've tried." I know the roads are crowned but this is "new," meaning it feels different than it used to. I've also tried eliminating that variable, still happens.
Also, brand new tires that were newly balanced and mounted by me.
Old 01-14-2013, 10:56 AM   #6
bdarling
Weatherman
bdarling's Avatar
Oddometer: 427
Let's rule out the obvious: weight in your side cases.
I got a new laptop at work that weighs SIGNIFICANTLY more than my old computer and I was shocked by the amount of steering input I needed to keep the bike going in a straight line with the computer bag in my right pannier. Just to verify that the computer was the culprit, I moved the bag to my left pannier and found myself correcting the other way. Solution: leave the damned electronic leash at work!
I suppose your response will be that you don't ride with side cases
-B
SoCal Dual Sport - http://www.socaldualsport.com
bdarling is offline   Reply With Quote
Old 01-14-2013, 11:15 AM   #7
FourG OP
Oddometer: 43
-B
Actually, you've identified another line item I forgot to add to the "things I've tried." I do always ride with the side cases and a laptop in the right side... however it's a tiny little Macbook Air and I've also tried riding without the side cases to eliminate a variable... same issue.
Keep the thoughts coming! We're narrowing in!
Old 01-14-2013, 11:34 AM   #8
SkiFly01
Govna Racepipe
SkiFly01's Avatar
Oddometer: 592
counterbalance, carry a bag of concrete.
Kai
2008 BMW GSA
2000 Kawasaki Super Sherpa
SkiFly01 is offline   Reply With Quote
Old 01-14-2013, 11:52 AM   #9
JRP
Old guy
JRP's Avatar
Oddometer: 1,526
Have you checked to see if the forks were twisted in the triple clamps?
I will assume you have ruled out a bent fork tube, you would remember if you hit anything that hard
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is online now   Reply With Quote
Old 01-14-2013, 12:27 PM   #10
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Brand new tires will do that until the get a flat spot then you should be able to ride hands off no problem.
Started our AK trip with new tires and the bike was all over. I thought it was the load but after a few K miles it road hands off straight for as long as I wanted.
If you ride hands off enough you can trim it straight with body english or a little hand in the wind.
Do you carry more weight in one bag than the other. Maybe you have worn a groove in the tire that is noticeable when the bags are empty.
http://www.framestraightsystem.com/M...me%20Check.htm
http://www.ibmwr.org/otech/whelalin.html
scooteraug02 screwed with this post 01-14-2013 at 12:33 PM
scooteraug02 is offline   Reply With Quote
Old 01-14-2013, 12:28 PM   #11
FourG OP
Oddometer: 43
I'm assuming we're talking about the fork bridge(10)? Yes, I've tried that.
Old 01-14-2013, 02:20 PM   #12
FourG OP
Oddometer: 43
Thanks for these, I'll try it out... The next question however is if my alignment is off... what do I do about it? Does anyone know if you can buy these shims from the dealer for the rear wheel or were they just a factory part?
Old 01-14-2013, 02:23 PM   #13
FourG OP
Oddometer: 43
Also, does anyone know any tricks to checking that your bars are completely straight? I'm assuming the only way is to measure with a micrometer from the bar clamps to the frame?
Old 01-14-2013, 02:40 PM   #14
everycredit
everycredit's Avatar
Oddometer: 272
Have someone else ride it and test for straightness. Do not contaminate his or her judgment by stating which side it drifts to. If he or she determines it is straight, assume testicular cancer. Added weight to one side or another can cause bike to drift.
everycredit is offline   Reply With Quote
Old 01-14-2013, 02:46 PM   #15
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,743
He may not. His insurance co-pay certainly would.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Times are GMT -7.   It's 06:11 AM.
