Old 03-09-2013, 09:32 PM   #1
DougD OP
DougD's Avatar
Oddometer: 21
changed the oil and fuel filter, now i have real trouble!!
as the title says, I changed both of those items on my 02 1150gs (65k miles) and buttoned everything back up and cranked it for a test ride and this is where it stands now:
it runs really rough. idles rough and i have to feather the throttle to keep it from dyeing. Assumed it was the fact that it was low fuel after draining most of it (even though I put about a half gallon or more back in)... went to the station and topped it off. not much difference if any.
it acts like its missing intermittenly??
then I return home and decide to look everything over and see if perhaps I can see a loose something?
and I notice a terrible rattling sound. seems that its coming from the transmission or clutch. when I pull in the clutch lever it goes away. when i let it out....rattling. sounds like marbles in a coffee can.
so is this a terrible coincidence? does it sound like the dreaded input shaft chew. or perhaps a broken friction disc?
please advice!!!
DougD is offline   Reply With Quote
Old 03-09-2013, 09:40 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,828
One of your throttle cables is pulled loose from the throttle body!
So comon everyone should know about it by now.
Jim
Old 03-09-2013, 09:46 PM   #3
DougD OP
DougD's Avatar
Oddometer: 21
you're correct. the cable housing on the right side appears to be broken loose at the base.... i just assumed it had been that way....
thanks.
any ideas on the trans.?
Old 03-09-2013, 09:48 PM   #4
JimVonBaden
"Cool" Aid!
Oddometer: 53,828
thanks.
Believe it or not, that is pretty normal. It will be less noisey once the motor runs smoother, but it will still rattle some.
Jim
Old 03-09-2013, 09:48 PM   #5
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,007
Chorus "The cables on the bikes go in and out, in and out."
Repeat monthly
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 03-09-2013, 09:53 PM   #6
DougD OP
DougD's Avatar
Oddometer: 21
no kidding?
so is it sending two different throttle positions to the computer?
man i hope you're spot on. so tempted to go try it at midnight!!! or actually 1am if you consider the time change this weekend.
Old 03-09-2013, 10:00 PM   #7
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,007
The throttle plates are not syncronizyated when one is yanked up and the other is just doing the normal thing.
Old 03-09-2013, 10:43 PM   #8
Jazz62
Jazz62's Avatar
Oddometer: 1,036
Post a pic of what you mean by this ^
In the "incorrect" pic JVB posted the cable end is not broken, it's just not seated inside the knurled adjuster they way it is in the "correct" pic.
ps - I PM'd you about your windshield parts.
Jazz62 screwed with this post 03-10-2013 at 01:01 AM
Jazz62 is offline   Reply With Quote
Old 03-09-2013, 11:26 PM   #9
vagueout
vagueout's Avatar
Oddometer: 1,743
no kidding?
Nothing to do with the computer. Because the cables are pulling on the butterflies unevenly, hence way out of sync, the engine is not turning and pulsing smoothly and thats why your transmission suddenly sounds like a bucket of loose bolts. This little episode you have experienced has been shared by many before you!!
i just seek clarity
vagueout is offline   Reply With Quote
Times are GMT -7.   It's 03:05 PM.
