Old 01-14-2013, 10:55 AM   #1
Elkster88 OP
Oddometer: 42
R1200RT battery access
Sorry if this is in a FAQ or if I am in the wrong forum. I did search around a bit.
I'm going to rent an R1200RT in February, so I plan on bringing my Gerbing heated jacket liner and heated gloves with me. On my FJR I have a Battery Tender style SAE 2 pin plug that I use to connect up to the Gerbing heat controller.
After hearing about how problematic it is to power heated gear from the CANBUS connected accessory socket from my co-worker who has gone on a number of Edelweiss tours, I want to bring my own battery tender harness and hook it directly to the battery.
My question: is it difficult to get at the battery or not? Bike will be either a 2010 or 2011 R1200RT. I was told by some it's straight forward, just take off the seat. But one guy with an R1150RT said it's a bear to get at the battery because you have to remove the gas tank, etc. Obviously the R1150RT and R1200RT are different bikes.
Thanks.
Elkster88 is offline   Reply With Quote
Old 01-14-2013, 11:55 AM   #2
LaurelPerryOnLand
Oddometer: 3,481
If you can turn a KEY...you can get the seat off!
Just be mindful that there is an electrical connector and short connecting lead for the heated seat under EACH seat.
+1 on the direct connect to the battery. No problems using a Battery Tender.
Forget any discussions re: gas tank removal.
LaurelPerryOnLand screwed with this post 01-14-2013 at 12:30 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 01-14-2013, 01:54 PM   #3
oldspice1972
oldspice1972's Avatar
Oddometer: 386
Very easy on the newer RTs. Pop the seats off (be mindful of the heated seat leads, as mentioned above) and the battery is right there, under the driver seat. Hook up your connector and you can easily dangle it out either side of the seat.
"Looks like I picked the wrong week to stop sniffing glue...."
2012 BMW R1200RT
oldspice1972 is offline   Reply With Quote
Old 01-15-2013, 10:41 AM   #4
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,028
Get a BMW plug and you'll be able to plug right in.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 01-16-2013, 07:52 PM   #5
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,536
Isn't OP concerned about Canbus rejecting his heated gear.
Call the rental place they may already have the wires set up especially if they rent bikes in the cold WX.
scooteraug02 is offline   Reply With Quote
Old 01-17-2013, 08:20 AM   #6
cliffy109
cliffy109's Avatar
Oddometer: 1,736
From the factory, the BMW plug runs through the canbus and that would be a problem with heated gear. Most BMW dealers routinely re-route the wires so the plug is direct wired to the battery. Check with the tour company and ask if they direct wire the accessory socket.
If not, the battery on the 1200RT is VERY easy and involves nothing more than using the key to get under the seat. The 1150 was a completely different situation and your friend was right about difficult access. You're fine on the 1200 though.
cliffy109 is offline   Reply With Quote
Times are GMT -7.   It's 07:44 AM.
